Question about Mitsubishi WS-65909 65" Rear Projection Television
Mitsubishi model WT-A42 MADE IN 2002
LOCKED PANEL KEYS NEED CODE OR WHAT TO DO TO UN LOCK THEM WHEN POWERING UP GREEN LIGHT BIKNS AND GOES OUT WHAT DO I DO TO FIX THIS SO I CAN POWER UP
  • 1 more comment
  • Anonymous Dec 16, 2007
    I have no remote and I locked the front panel from the front panel menu buttons. how do I unlocked the front panel without a remote
  • tvtime Feb 07, 2008
    Just purchased this tv today, preowned. Have turned it on and watched it a few times today. Shut it off this evening and now it won't power back on.
    The green light comes on for a second and then it shuts itself back off. Any help is appreciated.
    thanks
    Mitsubishi WS-65909 65 in. Rear Projection..purchased this today, preowned. Has worked fine all day. Shut it off and now it won't come back on. Green power light comes on for a second and then it shuts down. Any help is appreciated.
    Problem Solver:
  • 9 Answers
I bought the mitsubishi black diamond gray 65819 is under warranty and had same problem , turns off like after 2seconds ,it can be fixed people but u need a sears tech, I had one come out and was told they no longer can get the part ,but he had to take it to repair it and yes its was a steal for me ,depending where u live the cost for me would have been $350 for part,$200 labor its the board that the power cord is connected to in tv... I live in s.a. texas , the unit that set up the service is 9905 ,the repair unit is just down the street from them off culebra so if u get tech says cant repair it this one does,it helps if u have the warranty or protection agreement
Posted on Mar 26, 2008
  • 934 Answers
You can restore the function of the front panel buttons by pressing and holding the MENU button on the front panel
for more than 8 seconds. You may have to reset the button lock in the menu to reactivate or deactivate.
Hope this helps!
Bill
Posted on Dec 09, 2007
When I turn the tv on,,it just turn off,,
do the self check this model has. When green power light goes out on the front of the set press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then let go of both.
Power light (green) should blink a two digit code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Sep 14, 2011 | Mitsubishi WT-46809 46" Rear Projection...
My Mitsubishi WT 46807 will not power up. The green light on the front stays on for approximately 2 seconds and then goes out with no audio or visual. I tried unplugging the set for about 15 minutes but...
yes!
When you turn set on and power light goes out do the self check this set has.
On front of set when light goes out press and hold both the Menu and Input (device) buttons at the same time and hold both for at least five seconds and then release both.
Power light will blink a two digit error code like 2 blinks,2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means. Make a comment here and I will assist you.
SD TECH
Nov 27, 2010 | Mitsubishi WT-46807 46" Rear Projection...
I have a mitsubishi wt-42315. when i turn it on it shuts down right away. any thoughts?
Do the self check this model has.
When you turn it on and green power light goes out:
on front of set press and hold both the menu and input (or device) buttons at the same time for at least 5 seconds and release both buttons.
The power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what problem is.
If this helped rate this solution as very helpful as I do this here for free.
SD TECH
Sep 20, 2010 | Mitsubishi WT-42315 42" TV
Tv WONT STAY ON
When the power light comes on and then goes off perform the self check feature the model you indicated has:
On the front of the press and hold both the MENU and INPUT (DEVICE) BUTTONS both for at least 5 seconds and release both buttons.
The green power light should blink a two digit error code--most common is 2 blinks, a pause and 2 blinks.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Mitsubishi WT-46809 46" Rear Projection...
When I turn on my tv it will shut off
Model number is WT-46809?
If set comes on for a moment and then goes off(green power light)
ON THE FRONT OF THE SET PRESS BOTH menu AND input at the same time and hold both buttons in for at least 5 seconds---then release both buttons.
Watch the power light---it should blink a two digit code---ERROR CODE---
The most common is 2 blinks, a pause and 2 blinks-----set will repeat the error code about 10 times.
If you find this error code let me know the blinks and I will tell you what it means and may be able to tell you what is needed to correct it.
SD TECH
Oct 20, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi Model VS-5061
Go to the V-chip settings menu. When prompted for your password, hold "9" and "QV" buttons on the remote at the same time. You will then be prompted to enter a new password.
If you need to unlock front panel buttons that were locked under a forgotten code, hold the menu button on the front panel for 8 seconds.
As far as I know this applies to all Mitsubishi rear projection series WS, VS, and WT Tvs from 1999 to 2002 and probably newer as well.
Jul 03, 2008 | Mitsubishi WS-55809 55" Rear Projection...
2-2 code
convergance ic are bad:
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Nov 02, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WS-65909 65" Rear Projection Television Logo
238 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
