Question about Garden
My husqvarna mondo will only run with the choke on and even then it's not great. I just replaced fuel filter. do i need to make any adjustments?
  • 155 Answers
Hi there is a fine gauze filter inside the carby which may be blocked as well, Also if the diaphrams have gone hard it wont pump enough fuel.
Posted on Sep 08, 2009
Have husqvarna 1542. When pushing in the choke it dies. Have replaced battery, solenoid, fuel filter, cleaned carburator. Will not run when pushing in choke. Need assistance
this 15 hp Kawasaki engine needs lots of gas to run , and taking the choke off and engine speed falters is a sure sign that you have a fuel delivery problem (choke richens fuel mix)
id start with the simple things and move to the more difficult ones
(1) fuel tank - valve on , fuel in tank, hose not broke or crimped
(2) fuel filter replace or clean out fuel filter look for cracks in fuel lines as well
(3) fuel pump - if im not wrong these engines use a vaccume operated fuel pump , these are critical to have good hose for vac supply on (correct type as well)
(4) good working carb - this should have a factory minuki carb , these work very well and don't require a lot of maintence as others might , but they do get stopped up with fouled gas and they do eventually wear out as well requiring rebuilding or replacement , also lots of folks forget that the other part of a working carb is the air , air filters need to be clean enough for sunlite to penetrate thru them ,if you cant see lite thru then air cant get thru either
Jul 19, 2015 | Husqvarna Garden
My husqvarna chain saw will run only if choke is at least half way out
this is a sure sign of a fuel blockage some place !! id start with fuel filter and air filter and then look closely at fuel lines for signs of collapsing when running (CAREFULLY!!!!!) then move on to cleaning and resetting carb jets
remember choke richens fuel/air mix so if it needs choke to run then it's being restricted in fuel supply
Jun 17, 2014 | Husqvarna Chain Saw 20" Bar
My husqvarna yth2348 riding mower is havering carb issues not getting fuel
Here are a few tips to look at, I would first check your inline fuel filter to make sure its not clogged up. See Page 26 of the Manual for additional help.
http://www.husqvarna.com/ddoc/HUSO/HUSO2010_NAen/HUSO2010_NAen_YTH2348_532441716.pdf
PROBLEM
Will not start
CAUSE CORRECTION
1. Out of fuel. 1. Fill fuel tank.
2. Engine not "CHOKED" properly. 2. See "TO START ENGINE" in Operation section.
3. Engine flooded. 3. Wait several minutes before attempting to start.
4. Bad spark plug. 4. Replace spark plug.
5. Dirty air filter. 5. Clean/replace air filter.
6. Dirty fuel filter. 6. Replace fuel filter.
7. Water in fuel. 7. Empty fuel tank and carburetor, refill tank with fresh gasoline and replace fuel filter.
8. Loose or damaged wiring. 8. Check all wiring.
9. Carburetor out of adjustment. 9. See "To Adjust Carburetor" in Service Adjustments
section.
10. Engine valves out of adjustment. 10. Contact an authorized service center/department.
Apr 15, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Help husqvarna 372 chainsaw will not run
check with a husq.dealer,they had some crummy carbs that may need replaced not rebuilt
Mar 06, 2014 | Husqvarna Garden
I own a Husqvarna 128LD. My trimmer works on full choke, half choke, and when in the run position...it runs...but when the trigger is on balls to the wall throttle, it goes dead. What is my next move?
The next step is to richen the fuel mixture on the H screw on the carb, there is a special tool required to turn the adjuster screws because they have a splinr rather than a screw driver slot, the tool is part np. 530035560 unscrew tthe H screw 1/4 turn anti clockwise.
Aug 07, 2012 | Garden
My husqvarna 178 keeps cutting out on full throttle have tried to adjust the L and H settings with no success any ideas?
As far as i remember Husqvarna never produced a model 178, however if adjusting the mixture screws does not help there is either a fuel blockage in the fuel filter in the tank ( replace filter ), or the fuel screen in the carb ( strip clean and service carb ), check the fuel hose hose for splits or cracks, asthis will greatly effect the running
Mar 30, 2011 | Husqvarna Chain Saw Models 51, 55
Husqvarna 142e will not stay running. Going through the sequence of full/half choke it will start and run at high rpm when choked. Even after warmed up, it will die within a few seconds after dropping the...
If it is only running high at full choke - then it is not getting enough fuel.
You've cleaned out the whole thing - so it's not air that's the problem. It's running - so it's not a spark problem - it's a fuel problem.
If you have a fuel filter - change it out or clean it properly. If the fuel line is clear, then you need to adjust the running setting of the carb - there are usually 2 setting knobs -one for idle - one for running / mix.
You need it running richer till you get it going - then trim it back to stop it smoking and get a good rev.
Aug 28, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 55 chainsaw won't stay running.
It has a crack in the fuel line between the body and the tank. The crack lets air in the line. Replace the line.
Jun 03, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My husqvarna GTH2448T has to be choked to run
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes.
Oct 06, 2008 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
340 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
