Question about Whirlpool Washing Machines
Whirlpool model# lsc8244bqo, agitator niether spins nor agitates.
  • 641 Answers
SOURCE: Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sound like a belt issue. Open machine's cover and check that belt is not broken. Good luck!
Posted on Aug 04, 2007
aborcass
  • 2651 Answers
SOURCE: Agitator not working
you can put a serch in you tube for" motor coupling repair" simple enough procedure, easier to watch then explain... part number 285753
Posted on Nov 10, 2008
lenwest
  • 150 Answers
SOURCE: Whirlpool washer will not agitate
For a whirlpool kitchen aid,kenmore and inglis.The top section(clothes mover) of the two piece agitator is removed by first pulling off the agitator cap then removing the inner cap. Underneath those there is usually a 7/16? bolt which will need to be unscrewed. Once removed, the top agitator half can usually be pulled straight up to access the agitator kit components.
At this point you can make the repair of the defective parts.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 01, 2009
  • 130 Answers
SOURCE: Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Posted on Feb 16, 2009
jsrock516
  • 5911 Answers
SOURCE: Will not Spin or Agitate. Whirlpool washer came
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Now...a washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing. That way I can provide you with better assistance. I hope this information is helpful to you.
PS The age of the washer is determined by the Serial Number on the appliance. If you post back with the number I can tell you the year it was manufactured.
Posted on Jul 10, 2009
Simpson encore 605
Yes its a top loader and cloths are distributed evenly at the moment. My problem is it will not agitate. Its like the brake is locked on. It spins fine but niether the drum or agitator move. the motor is trying but its cant over come the brake (i think). I have had the brake arm off but I am unsure if it needs alinging with the brake tang when putting it back together ?
Jan 05, 2014 | Washing Machines
Whirlpool heavy duty super capacity plus washer will not agitate or spin. I replaced the agitator dogs but still have the same problem, is this a transmission issue?
Your model may have a flexible (break able) drive component between the motor and the transmission. Check that, it is a pretty easy replacement.
Jan 22, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool A5380XTWO will not spin or agitate. Is
check the "wig-wags" that shift the transmission in the washer,they are 2 coils(solenoids) located adjacent the motor on the transmission,if they get no power they wont shift transmission into next cycle of wash mode
Feb 03, 2010 | Washing Machines
Whirlpool top loader model #LA9500XTNO won't agitate
the agitator dogs need replaced sounds like.4 little comma shape pieces underneath the top of agitator
Jan 15, 2010 | Washing Machines
Agitator does not turn ..... you can hold on to & it doesn't turn in wash cycle
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
If you move the timer to the spin cycle and the washer drains and spins, the motor coupler (A common replacement part) is OK.
This points to one of two possible solutions.
First, I'd remove the agitator(s) and look inside at the splines inside the agitators and at the splines on the main agitator shaft.
Here is a description of how to remove the agitators. Your washer may be a bit different but the Sears site should help to determine how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=7a980a8b05b84ff3b7ee1c8ba46e2ae8
If yoy have a two piece agitator and only the top section doesn't agitate, the problem is likely the agitator "dogs" as described in the illustrations.
If the Agitator splines are worn or damaged, You'll have to replace the agitator.
If the splines on the transmission agitator shaft are worn, you'll probably need a new or rebuilt transmission.
In addition, see the following Whirlpool / Kenmore service manual and parts list for their commercial washers (consumer models are basically the same).
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Oct 28, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not spin or agitate. Pump works.
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
First, see the following Whirlpool Kenmore installation and service manual for top load, direct drive washers.
If it drains and you can hear the motor trying to turn the transmission for the agitate mode, the obvious first answer is the Motor coupler. I'd replace it just to be sure.
If it's not the Coupler, the problem points to the transmission itself.
There are only two components of the gearcase that are used for both agitating and spinning.
One is the Agitator shaft which drives the agitator and holds the spin pinion that drives the clutch for spinning.
The other is the main "Bottom and pinion gearcase" itself.
Please see the following Whirlpool parts list for commercial top load direct drive washers although the consumer models use the same transmission parts.
Oct 24, 2009 | Kenmore Washing Machines
Agitator stops while in spin cycle
Assuming that this is a basic Whirlpool top load, direct drive, neutral drain washer, the agitator is supposed to stop during the spin cycle.
Please see the following Whirlpool installation and service manual for top load machines.
If you look at the description of how the transmission works, there is an "Agitate Cam" that lifts the "Agitate Gear" out of contact with the main "Agitate Rack" when the machine goes into spin mode
I have found though that because of the friction between the agitate gear and main drive shaft, including the oil itself, the agitator may move while in spin mode.
Oct 14, 2009 | Whirlpool Washing Machines
Top agitator won't spin
Your agitator dogs must be replaced.
With a flat blade screwdriver pry off the top cover on the agitator.
Remove the 7/16 bolt inside.
Pull up on the agitator and remove it.
Purchase the agitator dog kit from the appliance parts store.About $10.00.
Mar 10, 2009 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
153 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
