Question about Alpine CDE-102Ri CD Reciever, iPod and USB Controller Car CD/ MP3 Player
Just hookep up alpine cde-102 to 06 toyota tundra with jbl system> had to use tato pak to wire with the factory amp. my problem is as soon as i turn on the radio,aux, cd. every minute or so it fades out a little and comes right back. not sure if it's radio hookup, or radio itself. please help
simplemitch
  • 752 Answers
SOURCE: Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
will advance one hour.
Posted on Aug 05, 2008
  • 3 Answers
SOURCE: Installing Alpine CDE-9852 CD Reciever In A Ford Mercury Sable LS
well most commen tool is a phillips head screw driver (+) to remove components to get the old deck out you'll need a dash kit to mount the new radio in 15 buck from canadian tire or audio shop...
the easyest way to wire this up would be getting a harness to plug into the factory harness too get the color code and then u just make the connections red to red yellow to yellow makes it real simple that way... the other way is to get the hanes manual for your vehicle then find out what color each wire is then yu have to cut the factory harness wire up from the book takes alot longer but can be done its worth the 12-20 dollars to get the job done if you need more help ask
Posted on Nov 08, 2008
JustJeeps
  • 74 Answers
SOURCE: Alpine CDE 7853 removal
remove the face and then the trim ring for face you should see 2 little pins on either side of the radio slide them up and it should slide right out
Posted on Nov 28, 2008
gpgab97
  • 77 Answers
SOURCE: On my Alpine CDA 7892 i have the aux cables right
I believe you need the Alpine KCA-410C - Ai-Net multi-changer/versatile link adapter before you can input from an external source directly.
Posted on May 08, 2009
  • 5 Answers
SOURCE: plug the radio on my toyota camry 1995
go to alpine.com
Posted on Aug 14, 2009
Alpine CDE 9845 ---> Pioneer DEH-P3900MP
Hi
It is no problem for replace your alpine stereo and you can get read review Pioneer AVIC-Z140BH . It has Touchscreen In-Dash, Navigation AV Receiver, iPod,Sat radio,Bluetooth
Read more review or check from Amazon.com
Nov 01, 2013 | Pioneer Car Audio & Video
How to connect aftermarket radio into 2002 toyota camry JBL radio (the standart wiring doesn't work).Thanks
Your aftermarket radio should have color-coded wires which identifies power, ground, speakers, etc. most depaetment stores carry a radio harness adapter kit. This will connect to your radio's exact color coded wires, and will plug right in to your factory's wiring plug. And don't forget electrical tape.
Aug 28, 2011 | 2006 Toyota Camry
Alpine head unit CDE-9870 will not play sound through speakers of a 2003 pontiac vibe. what could be some issues to cause this?
This generation of Vibe may have the upgraded audio system installed from the factory. In order to get the audio from an aftermarket radio to play through the factory amp, the factory remote turn-on lead must be located. If you are using an adapter harness, it may have the wire installed, just attach the blue/white stripe wire from the Alpine to the blue or blue/white stripe wire on the aftermarket harness adapter.
Mar 01, 2011 | Alpine CDE9870 CD Player
Alpine 9845 cde head unit car stereo i Cannot figure out how to access the Fader not the balance,altho i havent seen that function either. ive been to the alpine site and they dont even mention it. im sure...
Press the Rotary encoder (CDE-9845/CDE-9843
only) or press MODE (CDE-9841 only) repeatedly
to choose the desired mode.
Each press changes the modes as follows:
BASS → TREBLE → SUBWOOFER* → BALANCE → FADER
→ DEFEAT → VOLUME → BASS
BASS: -7 ~ +10
TREBLE: -7 ~ +7
Subwoofer : 0 ~ +15
Balance : L15 ~ R15
Fader : R15 ~ F15
Defeat : ON/OFF
Volume : 0 ~ 35
Feb 11, 2010 | Alpine CDE-9845 CD Player
I am trying to install a Alpine CDE-7822S stereo into my 1996 Toyota T100. What do I need?
ok here is what you need to install>>>>you will need an install kit which is for the after market stereo to fit in the space your factory one was in also you will need the WIRE HARNESS for that year and model of vehicle...sometimes when you buy the insatll kit it will come with one....once you get that all you have to do is remove the stock radio and then wire the wires from harness to your wires on aftermarket radio and just plug the harness into the black picece behind dash
Jun 04, 2009 | Kenwood KDC-MP228 CD Player
Alpine 9881 cd will not play sound
If you had to connect the remote amp turn on lead from the headunit to the factory amp turn on lead you may find your problem there.
On many headunits there are 2 blue remote wires 1 for antenna and one for amp turn on. The antenna remote only supplies power when the radio is playing not when playing CD's. If you hooked the antenna wire to the amp trigger then the amps shut down when you play a cd. If that's not it let me know and I will research further.
Jan 04, 2008 | Alpine CDE-9881 CD Player
Alpine CDE-102Ri CD Reciever, iPod and USB Controller Car CD/ MP3 Player Logo
424 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
