Question about SanDisk Sansa c240 MP3 Player
How to fix a broken headphone jack on mp3 player
I can only listen on the right side of my headphones. I have a Sansa Fuze 4GB mp3 player.
    President:
  • 1,996 Answers
Have you tried another set of headphones? Normally the headphones wire is what goes, instead of the jack itself.
I've never opened one of those up, but I guess you could re-solder a new jack into it if you were adept at that sort of thing...Finding the right jack is the trick, I'm afraid.
I'd repost your question to the sandisk forum board here. Also see this list. It sounds like yours is a common complaint, and you may have good luck contacting sandisk technical support and getting it repaired...
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Sep 07, 2009
The head phone jack is causing crackles and static noise and not a clear reception. I move the earbud jack around to get the right sound. Is there a way to permanently fix the headphone jack port?
It is very possible that the problem lies with your headphones and not the player. Have you tried to use a different set of headphones to see if that fixes the problem?
Jun 17, 2011 | SanDisk Sansa Fuze MP3 Player
Sansa fuze mp3 4gb radio does not have any sound!!!
Check your headphones with another system, check your ipod with another headphone if the fault is now confirmed you may have a conection fault with the jack usually if another type had been pushed in. If you are electronics savvy then use right tools to slowly open device, use a good soldering low wattage iron with emi protection to solder up the output jack side. and still if no sound comes the audio amp ic. If not you have a damaged ic. Hope you have tried to reset the device. check this out! helpful? Good day
Jul 04, 2010 | SanDisk Sansa Fuze MP3 Player
Sansa fuse radio does not work
is the little speaker icon red? pless the play/pause button. It mutes the radio.
Sep 10, 2009 | SanDisk Sansa Fuze MP3 Player
Headphone Jack issue Sansa View 32GB
Buy a broken one with the headphone jack intact off Ebay and switch the jacks.
Sep 08, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Sound only in right ear
Its either the jack or the connector in the device is the problem. You can try connecting other headphone, if this works, then the problem lies on the jack of the old headphone.
May 03, 2009 | SanDisk Sansa e200 MP3 Player
Sansa Fuze wont work with home stereo
The Sansa doesn't play music through the USB port. You can connect the Sansa to your stereo via the Sansa's headphone jack.
Feb 22, 2009 | SanDisk Sansa e250 MP3 Player
AHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!
The internal cable of your Headphones is broken somewhere ....replace the Headphones
Oct 18, 2008 | SanDisk Sansa c200 MP3 Player
Only hear out of one side of headphones with sansa player - tried 5 pairs...
i had the same problem, the headphone jack on the sansa is loose. I opened it all up, and saw that one of the connections on the headphone jack was loose. you can sauter it and it should work clearly again.
Mar 20, 2008 | SanDisk Sansa e250 MP3 Player
I can only hear out of one headphone i ve bought new headphones it just want work
Hate to tell you this, but most likely the headphone jack on your player is broken. It happens alot. If it's under warranty return it to the store. I don't believe the jack is user replaceable on this player. Try inserting the headphone jack only partway and see if you get both sides. Your cheapest solution if it's out of warranty may be to just insert the jack to the point at which you get both sides to work. It's a crappy solution, but it's probably your only hope. It's not a software problem or anything that can be fixed without tearing the player apart. Sorry for the bad news....
Aug 01, 2007 | SanDisk Sansa c140 MP3 Player
SanDisk Sansa c240 MP3 Player Logo
1,363 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
