''Q'' key not stricking paper
''Q'' key not stricking the paper and causing the carriage to move for the next letter.
  • johndbritt Sep 08, 2009
    Your options did not incluce model. It is a Royal Apollo - 12.
  • Jay Blair
    Jay Blair May 11, 2010
    What is the model?
  • 3,594 Answers
MAKE< MODEL?
Posted on Sep 08, 2009
  • 328 Answers
All the keys on this model have metal links connecting them to cams or levers. The q key has a disconnected link or is gummy. Look down inside as you strike the key for any movement . You may be able to reconnect the link or spray some lubricant in side.
It's stuck in place and won't move either left or right. When I hit a key it types that letter, but the paper doesn't move to the next space
If it is stuck in the middle of the page it probably has a carriage lock usually just below the carriage on the R. or L. side.
DickyO
Oct 12, 2011 | Olivetti Lettera 35 L Typewriter
Dora 204 SP Olivetti Typewriter I have an intermittent sticking returns key Causes paper to run on. Can I do anything about it, or can you tell me of a Service Centre in Hampshire n UK.
hello
take Q-tip cotton , apply small portion on hammer letter keys and carriage -- moving parts only
dip and smear into vasaline, wipe off excess. apply to the keys sticking or to carriage return key . this is amechanical sticking , so apply to where the part (carriage or moving part) applies. Also, take a plain paper , keep tapping the key and then return key carriage , until sticking stops and until the vasaline dissipates . repeat the typing for about 1-2 mintes until excess vasaline is no longer present on paper after typing.
repeat this process anytime the keys stick
hpe this helps
Nov 14, 2010 | Office Equipment & Supplies
My typewriter carriage doesn't move along as I type.
I just have an underwood 18 typewriter and when I type the carriage doesnt move the margins are in the end and when I press the tab key It is moving but if press the space bar it doesnt move..what should I do?
Sep 18, 2009 | Royal Office Equipment & Supplies
IBM Selectric II Will type letters, but will
Several possible causes. Needs lubrication most commonly. Sometimes the velocity cable is hung up on the left side and under the carriage. remove the ribbon and shine a light down on the left side and look for a cable hung up on the pulley, make a hook with a paper clip and lift the cable up and past the pulley
Aug 31, 2009 | Office Equipment & Supplies
The keys don't type the correct letter
Loosen the screws that hold the silver guide, one on each side of the carriage. Adjust to touch platen with 2 sheets of paper installed. When you reset next time it will reset to the right letters.
Jul 01, 2009 | Brother GX-6750 Typewriter
Carriage jam on hp photosmart printer
The print carriage may get stuck on either side or in the middle of the printer. The Carriage Jam: Open Door, clear carriage jam, and then press OK to continue error message may display on the front panel of the all-in-one.
Solution
The print carriage is the device which contains the print head and moves left to right during printing.
Figure 1: Carriage Assembly
To resolve this issue, follow the steps below in the order presented.
Step one: Print a Self Test
Follow the steps below:
1. Press the Setup button.
2. Select Print Report and press OK .
3. The self-test page should print. If it prints a test page, there is no need to follow the remaining steps, as the error message may be false. Make sure the printer now prints from the computer (if installed on one). If it does not print, proceed to the step two.
Step two: Clear the paper path
Follow the steps below to clear the printer of any jammed paper and reset the printer.
1. Leave the printer on and then disconnect the power cable and the USB or Ethernet cable from the back of the printer. Do not reconnect them until instructed to later.
NOTE: Make sure the printer is on before disconnecting the power cord. Failure to disconnect the power cord from the rear of the unit can cause damage when removing jammed paper.
2. Open the top access door.
Figure 2: Opening the top access door
3. Make note of where the carriage is stuck and look for jammed paper. A paper jam can cause the error message and the carriage stall. Some paper may be jammed in different locations than those shown in the photos below.
Figure 3: Paper jammed on the left side
Figure 4: Top view of paper jammed on the left side
Figure 5: Paper jammed on the right side
Figure 6: Top view of paper jammed on the right side
NOTE: Do not use any tools or other devices to remove jammed paper. Always use caution when removing jammed paper from inside the unit.
If the carriage is stuck on the right side:
a. Check for any paper or object that may be restricting the carriage.
b. Move carriage all the way to the left side.
c. Check the paper path all the way to the right side and remove any paper still in the printer.
If the carriage is stuck on the left side:
d. Check for any paper or object that may be restricting the carriage.
e. Move carriage all the way to the right side.
f. Check the paper path all the way to the left side and remove any paper still in the printer.
If the carriage is stuck in the middle:
g. Check for any paper or object that may be restricting the carriage.
h. Move carriage all the way to the left side.
i. Check the paper path all the way to the right side and remove any paper still in the printer.
j. Move carriage all the way to the right side.
k. Check the paper path all the way to the left side and remove any paper still in the printer.
4. Remove the rear access door or duplexer (if installed) from the back of the printer.
5. Check for and remove any paper still in the printer.
6. Replace the rear access door, and close the top access door.
7. Reconnect only the power cable. If the printer does not automatically turn on, press the Power button.
NOTE: The printer may go through a warm-up period of up to two minutes. Lights may flash and the carriage may move. Wait until this warm-up period is complete before going to the next step.
8. If the Power light is on steady, print a self-test page as done in Step one.
If the Power light is not on steady and the carriage is still in a stalled position, proceed to the next step.
Step three: Plug the printer directly into a wall outlet
Verify that the printer is properly connected to a suitable power source by following the instructions below.
1. Verify that the computer and the printer have a three-prong power plug.
2. Remove the printer cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
3. Try the print job again to see if this step resolved the issue.
NOTE: If the printer prints when plugged directly into a wall outlet while disconnected from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
4. If this did not resolve the issue, proceed to the next step.
Step four: Service the product
If you have completed all of the steps listed above and are still experiencing a problem, service your product.hope this helps
Jan 05, 2009 | HP Office Equipment & Supplies
Paper jam
Solution
Step one: Remove any lose paperRemove any lose paper from the paper tray. CAUTION: Do not remove jammed paper at this stage. Step two: Clear the jam from the back of the product
  1. Remove the paper from the paper tray.
  2. Press the power button (c00636182.gif ) to turn off the product.
  3. Disconnect the product power cord from the electrical outlet.
  4. Remove the rear access door. Press the handle to the right, and then pull out the door.
  5. Remove any paper that is inside the printer by pulling the paper out from the back of the printer.
  6. Replace the rear access door.
  7. Load paper in the paper tray.
  8. Reconnect the product power cord to the electrical outlet.
  9. Press the power button (c00636182.gif ) to turn on the product.
  10. Try to print. If the product prints successfully, the issue is resolved. If it does not, proceed to the next step.
Step three: Open the top cover and clear the jamIf the paper jam cannot be removed from the back of the product, try to remove it from the front.
  4. Raise the product cover, remove the paper jam from the front of the product, and then lower the cover. CAUTION: Remove the paper jam carefully because it is possible to damage the printer when removing paper from the front.
  5. Load paper in the paper tray.
  6. Reconnect the product power cord to the electrical outlet.
  7. Press the power button (c00636182.gif ) to turn on the product.
  8. Try to print. If the product prints successfully, the issue is resolved. If it does not, proceed to the next step.
Step four: Make sure that the carriage can move freely
  1. Press the power button (c00636182.gif ) to turn off the product.
  2. Disconnect the power cord from the back of the product.
  3. Raise the cover and try to move the carriage from side to side by hand. 1 - Carriage holding ink cartridges
  4. If the carriage does not move, the product needs to be serviced. If the carriage does move, proceed to the next step.
  5. Make sure that the ink cartridges are locked into the carriage and have not come loose. Make sure that there are no obstructions under or around the carriage to prevent it from moving.
  6. Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left and to the right.
  7. Close the product cover and reconnect the power cord to the back of the product.
  8. Press the power button (c00636182.gif ) to turn the product on.
  9. Try to print. If the product prints successfully, the issue is resolved. If it does not, proceed to the next step.
Oct 22, 2008 | HP Office Equipment & Supplies
Selectrik II sat for years. No escapt to next space after typing a letter or number
Be sure to put WD40 on the escapement (under the platen and paper tray) and the escapement drive mech. (rt. rear of machine) and the correction latching mech (under the rt. dust cover).
DickyO
May 31, 2008 | Office Equipment & Supplies
IBM Wheelwriter 5--Carriage advance problem
Try code (lang) key either the X or L depending on when it was made
DickyO
Dec 31, 2007 | Lexmark Wheelwriter 5 Series II Typewriter
IBm Wheelwriter 5--6 keys won't advance after typing
Press and hold the code key while pressing the lang key Either "X" of "L" key.
DickyO
Dec 31, 2007 | Office Equipment & Supplies
37 people viewed this question
jasbo
jasbo
