Question about Asko Washing Machines
My Asko W6022 goes through the wash cycle but wont
My Asko W6022 wont open/unlock after its done with the wash cycle. Help!
5 Suggested Answers
  • 3 Answers
SOURCE: Asko W620 washing machine not spinning
Sounds like the motor brushes need to be cleaned or replaced. Take the back off the washer, remove the motor and gently scrape the excess carbon or debris off the brushes with a pocket knife. I did this and it ran well for about 50 loads before building back up. I am ordering new brushes now because when I checked the brushes last week they were obviously worn more than 4 weeks ago.
Posted on Jan 21, 2008
  • 49 Answers
SOURCE: asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
Posted on Mar 06, 2008
Macmarkus
  • 2605 Answers
SOURCE: ASKO W6461. Washing machine won't unlock and my
Welcome to FixYa.
Have you checked the pump to insure the filter isn't clogged, or do you know where it is and how to check it ? In the event it is clogged or the filter obstructed, will prevent the door lock from releasing.
This is by design, but it's easy to confirm or dismiss.
Check as follows...
Let me know if any of this isn't clear and I'll attempt to help you move forward. Once you've cleared the pump filter or ruled out it was indeed blocked or not, you can now pull the manual door lock release located in the same area.
i.e.
Let me know how you make out. Thank you for choosing FixYa and good luck. Please take a moment to rate the info provided for you here today at FixYa.
Regards,
Macmarkus :)
Posted on Nov 10, 2010
Testimonial: "Feedback was excellent. Instructions easy to follow and we have just started our first load. And we probably have over $2 in change from our pump!"
SOURCE: samsung J1045AV door wont open, finished wash
My samsung front loader do wont open , cleaned the pump nothing there , What next ?
Posted on Apr 24, 2011
My Asko washing machine wont go into spin cycle it just keeps on washing after 3 hours I had to turn it off now what
call a technician in
the problem is most likely in the program board not progressing the wash cycle
Jul 12, 2016 | Asko W6021 Front Load Washer
My Asko W6022 quattro 1200 rpm is giving me trouble. The delicate cycle doesn't work and just soaks the clothes. Please help.
may have defective timer (burned points at the delicate cycle mode) can but may be difficult take timer apart and sand paper clean the point contacts on timer DONT IT BEFORE BUT NOT EASY
Dec 16, 2014 | Asko Washing Machines
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
Asko 10625 washing machine wont drain or open
Take the bottom panel off and there is a large drain under the drum. There will be a lot of water that comes out, so be prepared. When you take the drain off, there should be a debis trap in there. Clean this out look to make sure there are no socks or anything in there.
Nov 27, 2013 | Asko Washing Machines
ASKO W6903 spin cycle not getting to speed
Again it could be the carbon brushes or a faulty motor tacho
hope this helps
Mar 09, 2013 | Washing Machines
Asko 10505 runs through was cycle in approx. 30 seconds, then wont drain. Simply stops. It doesnt matter which cycle I start with, the dial moves quickly to stop. It fill with water and spins. ANY HELP...
hi sir' start the wash machine empty and see if it happens when nothing is in it.
2. When machine is off, open the top grab the centerpiece inside the wash machine and pull and push it slowly, does it move? (For safety unplug the machine)
3. Make sure machine is 100% level (front to back, left to right)
The most common thing is bad drum bearing, which force the wash machine out of whack when in spin / wash. Which are common and the best thing is to call Maytag.
thank u .........................................please rate
__________________
Sep 11, 2008 | Asko Washing Machines
My ASKO washing machine will not go through its regular cycle
it may need the carbons in the motor replaced part no 8801195, is it pumping out the water if it doesnt the door wont release.
Sep 06, 2008 | Asko W6021 Front Load Washer
Asko w 6021 still having issues
does it keep draining on any cycle and with the door open if so have you done anything with the pressure switch or the pressure sensor(red and black) it sits behind the pressure switch you may have to replace them.also check the board for any burn marks,i think you said you replaced it last time?if you have pressed down on the top of the pressure sensor you will have to replace it.am able to give you my mobile no or not.not sure how this site works.Ian
Mar 27, 2008 | Asko W6021 Front Load Washer
Asko 1585 wash cycle goes continuously until manually shut off
it may be a heating problem,does it get hot at all, or over heat.may be a thermistor fault.remove the door skin and see if rinse aid has leaked onto the wiring.or the board itself cauld be faulty,but are very expensive.hope this helps.
Mar 22, 2008 | Asko 24 in. 1585 Built-in Dishwasher
Asko 10505 - wash finished, door won't open
Mar 06, 2008 | Asko W6021 Front Load Washer
Washing Machines Logo
1,133 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
