Question about Whirlpool Dryers
DRYER doesn't turn on. - Whirlpool Dryers
    President:
  • 1,776 Answers
Check for a blown thermal fuse. Unplug the machine. The thermal fuse is about an inch long and is right inside the rear of the dryer, usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a blown fuse. Hope this helped and best wishes.
Posted on Sep 07, 2009
Logik tumble dryer gdz 60-10sw heard clanging noise now dryer still goes on but drum doesn,t turn.
Sounds like the drum has fallen off of the support rollers. Will need to open up cabinet to verify
Jul 04, 2016 | Dryers
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Dryer drum doesn't spin
If the motor runs and the drum doesn't turn then most likely the belt is broken.
Oct 23, 2012 | GE DBVH512EFWW Dryer
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
I have a Kenmore front loader - when I turn the knob to start the dryer, it make a noise like it wants to start but doesn't. I have tried to move the knob which indicates what drying time you want to...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 20, 2011 | Dryers
My dryer squeaked for awhile no it hums but the drum doesn't turn
heatman101
Sep 08, 2011 | Roper REX4634KQ Electric Dryer
My dryer still heats but doesn't turn, can it be fixed?
heatman101
Aug 07, 2011 | Dryers
When I try to turn on my dryer it just buzzes for about 5 seconds and doesn't do anything else. The heater doesn't turn on and the drum doesn't turn. Help!!!
heatman101
Jul 09, 2011 | Electrolux EIED55H Dryer
My dryer makes noise but doesn't turn. is it an easy fix?
heatman101
Jul 07, 2011 | Whirlpool LER4634J Electric Dryer
Clothes dryer don't run
sounds like a bad cycle timer switch
Apr 22, 2009 | General Electric Clothes Dryer Knob -...
Dryers Logo
37 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
