Question about EliteGroup P4VMM2 Motherboard
I get beeps on start up and the computer wont run
It goes 1 beep , break, 2 beeps ,break,1 beep
    Sergeant:
    Champion:
  • 255 Answers
Check bad memery chip, remove everthing from the board.
power mem cpu should be only things on board. see if it still beeps
Posted on Sep 07, 2009
  • 916 Answers
What you are describing is a memory error check your RAM modules and if you have only one you may want to replace it and check with a new one. It could also be caused by a bad RAM socket on the motherboard.
Compaq presario C700 continous beep when starting up
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
1. Remove battery + disconnect power
2. Hold down power button for 20 seconds
3. connect power only (no battery)
4. Turn computer on.
If the beeps stopped.. get a new battery, if the beeps continue..
ABANDON SHIP!
Apr 27, 2014 | Compaq Presario 1200,1600, Series CD...
6 beeps what dose it means
Dell beep codes:
If your computer beeps during start-up:
Run Dell Diagnostics to identify a more serious cause.
Beep Codes Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. One possible beep code (code 1-3-1) consists of one beep, a burst of three beeps, and then one beep. This beep code tells you that the computer encountered a memory problem.
Contact Dell for technical assistance.
Code Cause 1-1-2 Microprocessor register failure 1-1-3 NVRAM read/write failure 1-1-4 ROM BIOS checksum failure 1-2-1 Programmable interval timer failure 1-2-2 DMA initialization failure 1-2-3 DMA page register read/write failure 1-3 Video Memory test failure 1-3-1 through 2-4-4 Memory not being properly identified or used 3-1-1 Slave DMA register failure 3-1-2 Master DMA register failure 3-1-3 Master interrupt mask register failure 3-1-4 Slave interrupt mask register failure 3-2-2 Interrupt vector loading failure 3-2-4 Keyboard Controller test failure 3-3-1 NVRAM power loss 3-3-2 Invalid NVRAM configuration 3-3-4 Video Memory test failure 3-4-1 Screen initialization failure 3-4-2 Screen retrace failure 3-4-3 Search for video ROM failure 4-2-1 No timer tick 4-2-2 Shutdown failure 4-2-3 Gate A20 failure 4-2-4 Unexpected interrupt in protected mode 4-3-1 Memory failure above address 0FFFFh 4-3-3 Timer-chip counter 2 failure 4-3-4 Time-of-day clock stopped 4-4-1 Serial or parallel port test failure 4-4-2 Failure to decompress code to shadowed memory 4-4-3 Math-coprocessor test failure 4-4-4 Cache test failure
Aug 12, 2013 | Dell Gx620 Gx 620 Sff P4 Ht 2.8ghz 1gb...
Cmos beep codes
do you know which bios your computer is running ?
AMI BIOS beep codes 1 beep - DRAM refresh failure
2 beeps - Parity Circuit Failure
3 beeps - Base 64K RAM failure
4 beeps - System Timer Failure
5 beeps - Processor Failure
6 beeps - Keyboard Controller / Gate A20 Failure
7 beeps - Virtual Mode Exception Error
8 beeps - Display Memory Read/Write Failure
9 beeps - ROM BIOS Checksum Failure
10 beeps - CMOS Shutdown Register Read/Write Error
Phoenix BIOS BEEP codes. 1-1-3 CMOS write/read failure.
1-1-4 BIOS ROM checksum error.
1-2-1 System timer failure. (Programmable Interval Timer PIT)
1-2-2 DMA (direct Memory Access) failure.
1-2-3 DMA page register failure.
1-3-1 RAM refresh failure.
1-3-3 64K RAM chip or data line failure.
1-3-4 64K RAM odd/even logic failure.
1-4-1 64K RAM address line failure.
1-4-2 64K RAM parity error.
2-?-? Any beep series starting with 2 beeps indicates a 64K RAM chip or data line error.
3-1-1 Master DMA register test.
3-1-2 Mslave DMA register failure.
3-1-3 Master interrupt mask register failure.
3-1-4 Slave interrupt mask register failure.
3-2-4 Keyboard controller failure.
3-3-4 Screen (video) memory failure.
3-4-1 Screen initialization failure.
3-4-2 Screen retrace failure.
4-2-1 Timer tick interrupt test failure.
4-2-2 Shutdown test failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure above address 0FFFFh (64K +)
4-3-3 Interval timer channel 2 test failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port test failure.
4-4-2 Parallel port test failure.
4-4-3 Math Co-processor failure.
BEEP codes may vary dependent upon the revision of BIOS. This list is for reference only
hope this helps
Oct 10, 2012 | Intel Mother Board S5520HCR (988889365963)...
When I turn on my dell 9200, a beeping sound starts from the CPU and nothing comes up on the screen
how many beeps you have?if three short beeps its you RAM failure..try to reinsert you RAM or replaced it a new RAM..if theres a long beep..its your video card..
Jul 27, 2011 | Dell Dimension 9200 PC Desktop
Everytime i start up the computer it beeps 3-4 times, and the monitor says vga input not connected...whats could be the problem?
here are the beep codes for your exact dell model. this should give you a starting point on finding out what the problem is.
Reseating the memory modules may fix the beep code errors in the following table. If the problem persists, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
Code
Cause
1-3-1 through 2-4-4
4-3-1
If you hear one of the following beep codes, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
Code
Cause
1-1-2
1-1-3
NVRAM
1-1-4
1-2-1
1-2-2
1-2-3
3-1-1
3-1-2
3-1-3
3-1-4
3-2-2
3-2-4
Keyboard Controller Test failure
3-3-1
NVRAM power loss
3-3-2
NVRAM configuration
3-3-4
Video Memory Test failure
3-4-1
3-4-2
3-4-3
4-2-1
No time tick
4-2-2
Shutdown failure
4-2-3
Gate A20 failure
4-2-4
4-3-3
4-3-4
4-4-1
4-4-4
Cache test failure
Jan 01, 2011 | Dell Dimension 4600 PC Desktop
I get beeping when I start the computer, and it wont start?
This is called a beep code. It is used for troubleshooting when you are unable to boot your computer. Here is a listing of the Dell beep codes, depending on the sequence of beeps that you are hearing, you will find the problem listed here. How many beeps are you getting and what model of Dell do you have?
1-1-2 Processor Register Failure 1-1-3 NVRam 1-1-4 ROM Bios checksum failure 1-2-1 Programmable Interval Timer 1-2-2 DMA Initialization Failure 1-2-3 Direct Memory Access Page Register Read/Write Failure 1-3-1 - 2-4-4 Memory/RAM Not Properly Identified or Used 3-1-1 Slave DMA Registration Failure 3-1-2 Master DMA Registration Failure 3-1-3 Master Interrupt Mask Registration Failure 3-1-4 Slave Interrupt Mask Registration Failure 3-2-2 Interrupted Vector Loading Failure 3-2-4 Keyboard Controller (Input) Test Failure 3-3-1 NVRam Insufficient Power 3-3-2 Improperly configured NVRam 3-3-4 Video Memory(RAM) Test Failure 3-4-1 Screen Output Initialization Failure 3-4-2 Screen Retrace Failure 3-4-3 Failure Finding Video Read Only Memory 4-2-1 Lack of Time Tick 4-2-2 Shutdown Failure 4-2-3 Failure in Gate A20 4-2-4 Unexpected Interruption in Protect Mode 4-3-1 Memory Address Failure above 0FFFFH 4-3-4 Non Functioning Time Of Day Clock 4-4-1 Serial And/Or Parallel Port Test Failure 4-4-4 Cache Test Failure
http://www.bioscentral.com/postcodes/dellbios.htm 1-1-2 Processor Register Failure 1-1-3 NVRam 1-1-4 ROM Bios checksum failure 1-2-1 Programmable Interval Timer 1-2-2 DMA Initialization Failure 1-2-3 Direct Memory Access Page Register Read/Write Failure 1-3-1 - 2-4-4 Memory/RAM Not Properly Identified or Used 3-1-1 Slave DMA Registration Failure 3-1-2 Master DMA Registration Failure 3-1-3 Master Interrupt Mask Registration Failure 3-1-4 Slave Interrupt Mask Registration Failure 3-2-2 Interrupted Vector Loading Failure 3-2-4 Keyboard Controller (Input) Test Failure 3-3-1 NVRam Insufficient Power 3-3-2 Improperly configured NVRam 3-3-4 Video Memory(RAM) Test Failure 3-4-1 Screen Output Initialization Failure 3-4-2 Screen Retrace Failure 3-4-3 Failure Finding Video Read Only Memory 4-2-1 Lack of Time Tick 4-2-2 Shutdown Failure 4-2-3 Failure in Gate A20 4-2-4 Unexpected Interruption in Protect Mode 4-3-1 Memory Address Failure above 0FFFFH 4-3-4 Non Functioning Time Of Day Clock 4-4-1 Serial And/Or Parallel Port Test Failure 4-4-4 Cache Test Failure
Oct 18, 2010 | Dell Dimension 3000 PC Desktop
On startup it beeps and wont startup. i hit F12 and it works fine now. thats all i did. so what could be the problem? i've already replaced a power supply about a year ago. and also my dvd player is kinda...
On startup beep how many beep do you hear?
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Hope it Help you out ^_^
Jun 29, 2009 | Dell XPS 200 PC Desktop
Wont boot correctly
Typically, a system that won't pass POST (Power On Self Test) will beep in a pattern indicating what the problem is. Here's the beep codes for Dell systems:
Beep Codes Possible Causes Corrective Action 1 - 2 No video card detected Reseat the video card 1 - 2 - 2 - 3 BIOS ROM checksum error 1 - 3 - 1 - 1 DRAM refresh error Reseat the memory modules 1 - 3 - 1 - 3 8742 Keyboard Controller error Reseat the keyboard connector 1 - 3 - 3 - 1 Memory defective or not present Reseat the memory modules 1 - 3 - 4 - 1 RAM failure on line xxx Reseat the memory modules 1 - 3 - 4 - 3 RAM failure on data bits xxx of low byte on memory bus Reseat the memory modules 1 - 4 - 1 - 1 RAM failure on data bits xxx of high byte on memory bus Reseat the memory modules
Jul 08, 2008 | Dell Dimension 4500 PC Desktop
My computer it wont start!
the three beeps mean there is a problem with your RAM module or modules either check that they have been installed properly or if they have then maybe replace it or them because they/it could be faulty. thanks
Jun 01, 2008 | Lenovo Computers & Internet
EliteGroup P4VMM2 Motherboard Logo
111 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
