Question about Haier XQBM22-C Top Load Washer
Drain problem my xqbm22-c washer can not drain all water out, so the cloth are still wet (but no water dropping) when the sequence is finished.
  • 46 Answers
Chek you water pump may have some staff inside
Posted on Sep 07, 2009
    Problem Solver:
  • 14 Answers
Sounds like the pump is not workin or blocked
I have a maytag centennial washer MVWC400XWO it is 3 years old. The washer has stopped after the initial wash cycle leaving the cloths wet in a tub full of water. The washer will not go to the spin/drain...
For saftey the lid lock and lid down switch must be activated before the machine can advance to the next cycle. This has been the sequence for all top loaders..
Check the switch for the lid it is likely defective.
Make sure that the power is removed.
Simple repair by a qualified technician.
Hope this helps?
Jun 14, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Water doent stay in the washer for washing it gets drained out
Is the standpipe/Drain hose higher than the machine? If not, this will cause the water to drain.
May 08, 2012 | Haier XQBM22-C Top Load Washer
My washing machine does not spin the water out of the clothes. The clothes are wet when it is finished
is the load to big for the washer? have you checked the drain tube for partial clog ? dose washer give any codes
May 06, 2011 | Whirlpool Washing Machines
The washer did not drain and won't forward to rinse. After removing all the wet clothes and scooping out the water I set it at rinse and it began to fill but I wasn't able to forward it to spin though it...
Check the lid switch first. It will not drain or spin if the switch is not closed. If the switch is ok check the pump for a foreign object or frozen bearing. If dropping the hose allows water to siphon out the blockage may be a small object.
Eric
Jul 17, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Clothes washer will not finish spin cycle.
maybe something in the drain pump take bottom panel remove pump by turning filter and remove debris dont forget to vacuum out water from drain hose or your gonna get really wet.
Feb 21, 2010 | Washing Machines
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 24, 2010 | Kenmore Washing Machines
Clothes as still wet when it is finish after washing is done
Hello Sassylips,
Clothes will always be wet after a wash but if you are saying that they are soaking wet rather than just damp from a frontloadre like yours then you may have an obstruction in the pump system.. That could be anything from a screen preceding the pump, some obstruction in the pump itself, a pinched or clogged drain line exitting the washer or restrictive flow in your home drain system. A simple check that can be done would be to take the drain line out of the house drain and put it in a barrel. Watch the flow of water when the washer cycles thru a standard wash and see if it appears to be a reasonable level. A trickle would indicate one of the problems I mentioned previously. Have you ever cleaned the drain screen? Those are a few potential issues that could cause your clothes to remain wetter than they should be after a wash cycle. Also, you might try washing a few articles of clothing and then check to see if they are as wet as larger loads when the cycle is complete... Hope these ideas help you identify the cause and are able to resolve your problem...
Regards
Nov 29, 2009 | Frigidaire ATF6000ES Front Load Washer
Clothes wet at program finish
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Apr 01, 2009 | Bosch Washing Machines
Final spin cycle issues
Clothes are too wet after spin cycle This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
HOPE THIS MAY HELP YOU;
Regards,
VOTIT
Sep 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
When cyle is finish clothes are still soaking wet
Sounds like a slow drain. Recheck the drain hose if it looks ok get a bucket to put the hose in to see how fast it comes out. If it comes out slow the drain pump impellor may be broken.
Apr 17, 2008 | Frigidaire GLWS1233A Top Load Washer
Haier XQBM22-C Top Load Washer Logo
146 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
