Question about InFocus IN35W Projector
Infocus IN35 Power Problem
My Infocus IN35 projector won't power up, at all. I have a friend who is an electronic engineer, he has fixed projectors for me in the past but he can't seem to get any further with this one without the schematics (which I guess are impossible to get!) The board is made by Power-One, I can't seem to see a model number anywhere.
Is anybody familar with this brand or have any suggestions to what I could try? I have a photo of the board if this is any help?
Any help would be greatly apreciated
Best Regards
Simon
  • Richard C Cohen
    Richard C Cohen May 11, 2010
    How old is the projector? I used to work on Infocus and they are notorious for making parts 5-7 years out. After that, a discontinued unit is good only till the parts run out...No schematics exist unless you were an authorized repair facility and it was just finding out which board was bad and replacing it--I assume they didn't want the risk of having partial repairs floating around out there. JUST A NOTE: There is a nasty little bugger on the power supply section called a THERMISTER! Its bright blue, looks like a fat capacitor, has NO markings on it and will cause the problem you have! It liked to have driven us CRAZY trying to find a suitable replacement. (remember--no markings, right?) Heh, try one of the major electronics parts houses like Newark or some such...Figure on 5 amps working current--that's what the fuse is rated for. In the lab, we used to laugh and call the thing (the automatic *break* device). Hope I helped you some!---Rick
  • 2,237 Answers
Check the interlock switch for the lamp door (on the fan bracket). if the switch doesn't work, the projector won't turn on. also check to see if the ribbon cable for the top case buttons is connected well. if still a no-go, it is the power supply (part # 510-2189-00). if you want to try and fix it instead of purchase it, start with the caps. some of them bulge and some tend to dry out prematurely without physical damage showing. start with the large one in the middle. you should at least get 5v from one of the points. you won't get any more unless you get a signal from the main board turning the rest of the power supply on. and there's where the problem may lie.
Posted on Sep 09, 2009
Infocus in15 temp and lamp indicator flashing
In attempts to get your IN15 projector working, please try the steps below.
Disconnect AC power from the projector and wait for 10 seconds for supply to properly discharge.
While holding down the Menu, Select and Input buttons simultaneously, plug in the main AC power until
the LEDS stop flashing (approximately 7 seconds)
Jul 15, 2012 | InFocus IN15 DLP Projector
I have a InFocus IN35 w360, I have no idea how old it is, do you? The bulb had dimmed the other day and now it will not power up, is replacing the bulb the only thing I need to be aware of with this type...
More than 5 years old. After replacing bulb you have to reset the lamp hours as follows. To reset the lamp timer, navigate to the Settings>Service menu and select "Reset Lamp Hours"
Aug 15, 2011 | InFocus IN35 Projector
I have a infocus IN35 that at 100 hours burnt out a bulb. Thinking that it was just a bulb problem I bought a new bulb and it lasted 20 minutes. a t.v.repair shop said its probably the ballast that is the...
It is not a common problem. Ballasts rarely need repairs. Have you reset the lamp hours to zero after installing new bulb? If, yes to confirm about ballast please ask the TV repair shop man whether previously he had repaired any DLP projector. There is lot of difference in technology of DLP projector & TV (except DLP Projection TV). The problem could be in the projector main board. The lamp lights after getting Lamp ON signal from the projector main board. As the lamp ignites the ballast sends the signal of Lamp Lit. If the projector board senses that any blower/exhaust fan or colour wheel is not running then it will send a signal to Switch OFF the lamp. If you are tech-savvy then do as follows to check about lamp & ballast. Remove 5 pin connector from the projector. Connect projector to mains supply. Get a 5V DC power supply. Connect +ve to pin 3 & -ve to pin 4 of the ballast connector from this supply. The lamp should light. If it does not light then there is problem in the ballast (if the lamp is new). To give a chance you can check it for your lamp which lasted 20 minutes. Generally ballasts are made by OSRAM. You can get the ballast from OSRAM dealer. You will need the part number for that. Take out the ballast, it is there on it.
Apr 14, 2011 | InFocus IN35 Projector
My infocus lp120 shakes - can I fix this?
your description of the shaking still is too vague. The best idea I have for you is to replace your cables if the picture is noisy/grainy. If that doesn't fix the problem it is likely the power supply not grounded properly and possibly not enough shielding between the power supply and light engine. If your image is jumping and flickering, it is also going to be the power supply.
Jun 15, 2010 | InFocus LP120 / 1000 Lumens / XGA / DLP...
My Infocus projector powered down suddenly while in use and now it won't power on at all. What could the problem be and could I possibly fix it myself?
do the fans come on at all? if no, you need a new power supply. if they do, do you hear a high-pitched whir? if not, the colorwheel needs replacing.
the colorwheel and power supply can be purchased through an infocus authorized service center. try av solutions in ny. they're pretty good.
Oct 29, 2009 | InFocus LP70+ Multimedia Projector
My infocus lp650 won't power up no lights nothing
One way of telling if its the power supply is apply power to the projector and look at fans on the side. If they don't move then its a power supply issue. I can fix this for you for less then it cost to send to infocus or to a repair shop. Ebay Id is Gtitubro
May 11, 2009 | InFocus Work Big LP650 (Refurbished)...
InFocus LP530 projector not powering on
the power supply needs to be replaced. it goes after a while in this model.
Feb 09, 2008 | InFocus LP530V Video Projector 2000 ANSI...
InFocus IN35W Projector Logo
495 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
