Question about Samsung SCH-i760 Smartphone
The screen is stuck on the align screen i reset the phone and attempted to reload windows mobile and when the align screen came up i tapped it but it wont go away
  • jamie20078 Sep 12, 2009
    i did the hard reset a number of times and afterwards it says tap screen to set up windows mobile and the align screen pops up. its still wont go away after an hour of tapping the screen
  • 20 Answers
Did you perform a hard reset? To do this:
  1. Slide open the device to expose the QWERTY keyboard.
  2. Press and hold the center of the 5-way navigation pad.
  3. While holding the center of the 5-way navigation pad, use the stylus to gently press and release the reset button.
  4. When Clearing Data... appears on the screen, release the center of the 5-way navigation pad.
  5. When prompted, tap the screen to setup the device.
Posted on Sep 07, 2009
Pocket PC 2003 Pro unable to align screen
the touch screen plug on the motherboard is disconnected
Sep 06, 2009 | HP Computers & Internet
My i-mate pocket pc screen does not get aligned
Hi. You should tap the screen with the stylus carefully and with a little bit more pressure, accurately on the cross sign evertime it appears. When you successfully tap each cross sign once, you would be able to pass to the other settings, but in case there is a problem passing though the screen aligning, here is a small tutorial about how to bypass that screen through your PC: (http://goatechno.blogspot.com/2008/12/windows-mobile-stuck-at-screen.html) Hope this helps.
May 27, 2009 | i-mate Pocket PC
Reset problem
The best thing to do is to take your cell phone to your provider and they can try to trouble shot it, or even fix it.
Jan 20, 2009 | T-Mobile Wing™ Smartphone
Xda mini S Pocket PC problem
your phone is being reset if the situation is like that. get your pen and push the button beside the charging socket and press the power button also simultaneously.
May 22, 2008 | O2 Xda II mini
Stuck On Align Screen
This happened to me also. Drain the battery completeley and then do it again. You may have to do it a couple times but it will finally take.
Mar 20, 2008 | T-Mobile MDA
RESET phone solution.. pls help..
hi,
   u just do one thing..restart ur phone again..& when it asks u to set up ur windows..than tap on the black spot firmly ...u just need to tap on than spot only..nthing else after that leave..it will start processing..& ur phone will be on.
Thanks
Gizmo1
Oct 22, 2007 | O2 Xda Trion Smartphone
K jam screen align does not work after hundred or so attempts
Well, folks i had the same problem with the damn i-mate K-JAM model but i have figured out its solution. Well screen alignment options will always come on ever reset whether it is hard or normal and further more it would be nail biting for most of us because it doesn't work at all. It seems like some sort of a bug either in Windows Pock PC edition or HTC manufacturing bug. Whatever u call it only we would be the victim of it. Here is the solution.
When the alignment screen comes Just Tag the {+} << in the exact centre it will then move to the top let corner of the screen again tag it from the middle and it will then jump to the lower left corner now don't tag it from the middle instead tag the lower left corner of the screen. It will then move to lower right corner of the screen now tag it again in the middle and finally it will fly to the top right corner now again instead of clicking in the middle just hit the top most right corner of the screen and now u r done. Screen is finally aligned whoops!
Sometimes even when the screen is aligned the touch pad malfunctions if this is the case with you u need to update the firmware like i did just search through Google the i-mate k-jam windows Pocket edition update.
Thanks
Jun 25, 2007 | i-mate K-jam Smartphone
Samsung SCH-i760 Smartphone Logo
747 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
