Question about Fuji Finepix A610 Digital Camera
Broken LCD on FujiFilm Finepix A805
I have a FujiFilm Finepix A805 digital camera. The LCD is broken. I have read online about how to replace it and think I can handle that myself...if I can get a replacement LCD and the proper camera opening tool. From my manual, it indicates that the 2.5 in. LCD is the same one in both the A805 and A610. Where can I get this replacement part and opening tool economically? If it's more than $20-40, it's hardly worth the trouble when you can find the cameras on clearance at WalMart and other places for around $100. Any ideas? ~Mark
KellyBundy
SOURCE: Fujifilm A610
Try this solution: http://www.fixya.com/support/t143152-fuji_zoom_error_message
Posted on Jul 09, 2007
  • 39 Answers
SOURCE: Fuji Finepix F450 broken LCD
Possibly search ebay for broken cameras of the same make or replacement parts. Fuji's contact center may sell parts or possibly fix your camera for free.
http://www.fujifilmusa.com/support/ServiceSupportRepair.do
Posted on May 26, 2009
  • 244 Answers
SOURCE: When FinePix V10 digital camera is switched on the
Hi, When you say the screen is "blank" Is it totally blank or do the icons appear on screen? can you review any previous pictures etc?
As the camera still powers up it is possible that the ribbon for the screen has popped out of it's socket.
My email is listed in "the only way i know how.." In my tips n tricks section on my profile if you would like more advice.
Posted on Aug 15, 2009
  • 11967 Answers
SOURCE: I have a Fujifilm FinePix A610 camera. This
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 28, 2010
Tri3mast
  • 747 Answers
SOURCE: i have a Fujifilm finepix S1600 camera and it has
The yellow icon is a warning that a slow shutter speed has been selected and to use a flash or tripod for the picture otherwise it could be blurry. An explanation can be found on page 27 and 28 of you user manual. A similar icon but in red and the letters AF will be seen if the camera has failed to auto focus.
Posted on Dec 26, 2010
Outer body, battry door
You should contact Fujifilm. They are your best bet for locating a replacement part. The Digital Camera Parts and Accessories phone number is 1-866-289-3854.
Mar 24, 2014 | FUJIFILM FinePix JX250 Digital Camera
I have a Fujifilm Finepix A805 digital camera, an when i insert my SanDisk 4GB SDHC Card it says '!CARD ERROR' on the left hand side of the screen. I have no idea why it doesn't work. Please Help, many...
Try reformatting the SD Card. If you have a computer with an SD card slot, insert it in there, right click on the card, and click "Format..." If you use a Mac, use Disk Utility to format the card.
Feb 28, 2011 | Fuji FinePix A805 Digital Camera
Lcd broken.Any chance to change lcd.
yes LCD's are a pain to replace on your own but luckily I'm here to help... please remember to rate me for helping you
the easiest way is to buy a new LCD
such as here:
finepix-f30-digital-camera-repairing-lcd-display-screen-replacement.html">http://www.ownta.com/fujifilm-finepix-f30-digital-camera-repairing-lcd-display-screen-replacement.html
or on ebay:
http://cgi.ebay.com/FUJIFILM-F40-REPLACEMENT-LCD-DISPLAY-REPAIR-PART_W0QQitemZ320283316623QQihZ011QQcategoryZ64352QQcmdZViewItem
Follow link to ebay vendor: Most lcd display screens are available
or you could build your own but without a ton of experience, this is more of a challenge than it's worth.
I hope this helps :)
Jan 04, 2011 | Fuji Cameras
Replacement screen for finepix J10.
ask at a camera store they can probably order one in for you if not try kijiji
Dec 28, 2009 | Fuji FinePix J10 Digital Camera
The LCD is broken. I can still use it, it makes good pictures, but it is broken. Can I change it? How much will it cost me? Thank You!
If it is still working then only the casing is broken. Have it replaced. Visit their website and locate a vendor near you.
Aug 02, 2009 | Fuji FinePix A920 Digital Camera
FUJIFILM FinePix A820
Google local representative first then if not available order from factory
Jul 29, 2009 | Canon PowerShot A550 Digital Camera
Fuji Finepix A610 Digital Camera Logo
304 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
