Question about Dell PowerEdge 2600 Server
Unable to boot to anything external.
Server details:
Home Use
BIOS rev A14 and a floppy drive.
Floppy is only drive (besides HDD's)
No OS (HDD's wiped clean before it was auctioned off)
I've been trying to install from an external (USB) DVD burner and a bootable flash drive.
I prepared the flash drive in the same manor I used to upgrade both my other computers to Windows 7 (trying to install Win Server 08).
Every time I boot, it goes through the various BIOS steps and ends at a message similar to "Unable to find a bootable device."
I've tried changing many different settings in the BIOS. I remember reading something before about someone booting and installing an OS through a flash drive, but I cannot find the web site anymore, figures!
Any help would be greatly appreciated!!
  • 922 Answers
Save yourself some trouble. Pull a CD/DVD drive out of another computer or just buy one. They are very cheap. Connect the CD/DVD drive to the server and install the OS as usual.
If you are lucky WS2008 will already have a compatible SCSI/RAID driver. Otherwise, you will need to press F6 and install the driver from the floppy.
If this helps please vote for my solution.
Posted on Sep 14, 2009
  • 37 Answers
First of all you need to setup the SCSCI hard drives' do raid 5 if you have the drives once the drives are configured then install your OS 32 bit
Dell may bave onboard raid or a raid contoler card Great things about servers they do not setup like PC's I use Dell servers and a few HP. not too fond of HP now
Posted on Oct 03, 2009
Starting up i get PXE-E61 media test failure some people tell me its the hard drive some say the cddrve others say it could be trying to boot from a LAN
PXe Boot is used by the computer to boot to a network DOS-type environment.If you are receiving a PXe failure message on bootup check that your PC is set to boot from the CD Rom, Floppy, and Hard Drive BEFORE network or other boot device.
That's where you need to check to get solution to your problem, if not... try these
1. your settings in your bios
2. faulty cable/wire to your media device (hard drive, cd/dvd rom, etc)
3. The cmos battery (which indirectly points to your bios settings)
Hope this helps!
Jul 18, 2011 | Toshiba Satellite L455D-S5976 Notebook
On my pc monitor appears " Floppy diskette seek failure"
To remove the message just go to bios, press f2 when you turn on your computer, press enter in boot menu, set first boot in hdd and second boot in cdroom (using + - key)and disable boot from floppy by pressing the space bar
Go to advance and if there is any setting about swap or seek from floppy make it disable
Hope it helps
May 28, 2011 | Dell OptiPlex GX280 PC Desktop
I kep getting an error on bootup about A: configuration in bios I can not boot the machine due to this problem. Also, I need to boot from UB drive, FINALLY got into bios, but it is still giving me the...
Is there a floppy disk in the A: drive? That "port" is usually reserved for a floppy disk, either 3.5 or 5.25in. You probably need to disable the floppy drive in the BIOS.
Jan 24, 2018 | AOpen Computers & Internet
Configure & install two scsi disks scsi disks in ML 150 G2
The SCSI driver is required to installed during the initial boot up for installation when additional drivers are asked .the new models dont come with a Floppy drive so an external floppy drive can be used .The detection of HDD s must be at the startup by the Bios os SCSI card.
Feb 24, 2010 | HP ProLiant ML150 G2 Server
Firmware update interupted, server out
If you have jumpered for BIOS recover it should be able to boot from floppy. I think you will have to install a floppy drive, boot from floppy. Jump the MB for BMC update (if ness) and flash the BIOS and BMC that way.
Jan 16, 2010 | IBM x3400 Server
Trying to boot from external dvd drive
u must either have one of the foll...to boot and install OS...also the seq in BIOS must be availabe and enabled
1 Floppy
2 CD Rom Drive - internal
3 CD Rim Drive - External connected thru USB
4 You can also try to connect a USB pen drive having the OS install program and try - I have not tried that so not sure if this option works...sorry
5 If u can open the machine then u can connect another internal HD(this can contain ur OS install files) to the cable (connector points in the flat cable) that connect your internal HD to the Motherboard.
if i can think of anything else i will post
all the best
Dec 31, 2009 | Dell PowerEdge 2600 Server
Hello, I'm trying to update the bios on a Gateway solo 1450 laptop.Ive copied the files to a floppy disc but the computer won't boot with the disc in the drive. The message insists I remove any discs from...
you need to make a boot disk then copy the bios files onto the disk if you can not make a boot disk you can go to bootdisk.com and there you can find the correct boot disk for your OS.
Oct 30, 2009 | Computers & Internet
Unable to get the computer to boot up completely.
1. Check the floppy cable; you may have disturbed it when you swapped HDD.
2. and the power connector to the floppy...
3. You could always reset the BIOS....
3A. short-out the two "reset" pins next to the BIOS chip or near the mobo battery.
Sep 22, 2009 | ECS 945P-A (V3.0) Motherboard
Please help
Try pressing F2 / Del key during startup. That should bring the bios setup. Now Restore that defaults & install OS on your HDD. If you are not using Floppy drive, disable the onboard floppy controller from BIOS.
Jun 20, 2008 | ASUS P4SP-MX Motherboard
Regarding the hdd size and bios update
The issue with your board is that it can't see drives above a certain size. This does require a BIOS update, usually involving a floppy drive. Look in your BIOS - there may be an option for you to be able to boot from other devices. Check to see if "USB Floppy" is one, as it means you could potentially use an external floppy drive, which are cheap at most electronics stores.
Alternatively, if you or a friend has another computer, you might try borrowing a floppy drive to do the update.
Alternatively, you could go to the manufacturer's website and check the information they have for your particular board. Many now let you download an executable file with the recent BIOS updates that you can use without having to use a floppy drive. Some also have methods that you can burn to a CD.
Mar 14, 2008 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Dell PowerEdge 2600 Server Logo
783 people viewed this question
Alun Cox
