Question about Indesit W 123 Front Load Washer
My indesit wia101 is stuck on wash cycle tried turning off and back on but just carries on any suggestions on how i may be able to fix it pls
  • 6277 Answers
SOURCE: i have an indesit wil133,
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 18, 2011
informatica
  • 1114 Answers
SOURCE: INDESIT WIA101 INSTRUCTION MANUAL
Hi - You can download the manual from the link underlined in blue below:
WIA101
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Aug 09, 2008
SOURCE: indesit washing machine will not drain and carry on with full cycle
Already posted previous comment. Thermistor measured resistance of c 30K ohms on meter - that seems OK. However one of the wires on to the thermistor plug looked faulty and came away when touched. Needed carefully soldered - it looks like a "punchable" connection eg BT phone socket but it ISNT <grin> Washer now working fine. (Had previously a broken front concrete block under warranty so drum shaking about more violently than usual due to that had obviously weakened this thermistor connection....)
Posted on Aug 23, 2008
grandadfixer
  • 99 Answers
SOURCE: Indesit washing Machine W93
Pump or hoses still blocked,Or pump has had it,Can supply new pump by post if req.
Posted on Oct 11, 2008
SOURCE: indesit washer/dryer wd10
I have an indeset WD10 washer/dryer. When I put the programme on, it just clicks round and keeps clicking round until I turn it off. Does anyone know how to fix this problem?
Regards
Sharon
Posted on Mar 11, 2009
I have an indesit washing machine model WIA101 that needs draining in prep for disposal and i don;t know what to do
front loader direct drive
drop the drain hose to the ground let gravity empty the water
can be dumped as is
no oils or asbestos in its design
Jan 22, 2017 | Indesit Washing Machines
Indesit wia 101 stuck on one part of cycle and won't move on
check pump for blockage remove plug for 15mins re try
Apr 19, 2015 | Indesit Washing Machines
WON'T SPIN,WON'T DRAIN,WON'T SHUT OFF!
is it an indesit wia101 by any chance?
Aug 19, 2013 | Washing Machines
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
WIA101
Aug 09, 2008 | Indesit W 123 Front Load Washer
Indesit DG6100W problem...please help!
Hi, I have the same dishwasher and it fills from the cold supply, not the hot and it doesn't have a cold cycle as is previously suggested, as you will know kellyemb :-)
The Indesit DG6100W does a fill from the cold and heats as it washes, so if it's sticking part way through, it could be the heating element. Have you tried opening the door when it sticks and seeing if the water is hot? The heating element went on ours and it kept tripping the electric whenever the it tried to start to heat the cold water. If it is the element, they don't cost much to replace, even cheaper if you know someone who can fit it for you! Ours cost us around £12 and hubby fitted.
The only other thing I can think of is it might be the timer, like someone has suggested but how to reset it, I have no idea. I have seen on another website that a replacement timer is around £55 plus VAT, which is a little expensive.
Hope you get it fixed.
Jul 01, 2008 | Dishwashers
Indesit washing machine will not drain and carry on with full cycle
Same problem - changed module with no result. Looks like the water temperature thermistor...
Jun 12, 2008 | Washing Machines
INDESIT 167 Stuk on DENO
take the lid off the machine.remove or disconnect the wires off the main board giving them a small spray with a water dispersent or silicone based soloution.by the way turn the power off at the mains before carrying out this procedure.
Jun 29, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
308 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
