Question about Samsung DVD-V3650 DVD Player/VCR
I need to convert VHS to DVD
I have a Samsung Progressive Scan V3650 DVD/WHS combo. I was wondering how to convert my old VHS' to DVD's. Can anyone help me?
    Guru:
  • 74 Answers
Hey!
You can use a video to dvd burner software which can help you convert your VHS' to DVD's. You can have a try of this Wondershare DVD Converter Studio which can help you burn DVD from VHS'. For more detailed info, you can get it at: http://www.dvd-ripper-copy.com/dvd-converter-studio.html#181.
Posted on Sep 22, 2009
SOURCE:
Samsung DVD-V3650 Combo Player ejects most videotapes without playing them
You can only compensate for minor scratches. As for the vcr side the rollers could be dirty or the brake worn out. The tensioner may be too sensitive as well. Basically the mechanism probably needs servicing.
Sep 06, 2016 | Samsung DVD-V3650 DVD Player/VCR
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
I have lost my instructions for my Samsung DVD Player
Find the manual at retrevo site by copying and pasting the following link into the internet URL window:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Follow instructions at the site
Oct 02, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have a HD TV with cable and a go video DVD/VHS player hooked up. I went to change the time and accidentally changed the setting on the DVD player from auto scan (I think) from off to on and now when I...
It sounds like you may have enabled the progressive scan output on your DVD-VHS combo. This is a correct setting if your TV support it. However most DVD players that support progressive scan will not support an interlaced signal and a progressive signal at the same time.
It would appear that you are using a composite type cable (3 RCA ends. 1 for video and 2 for audio) for this hook up. This means you have two choices.
#1 Look in the manual for the unit for the FACTORY Reset option. Its usually a combination of plugging the unit in while holding the power button or something similar to that. Without a model # I can't help any further with this option.
#2 Use a component video cable (3 RCA red/green/blue) to plug your DVD/VHS player into a compatible input on your HD TV. Your TV will pick up the progressive scan output from the unit and give you back your on screen display. At this point you can go back into the menu and disable progressive scan. And now just reverse the process to plug the DVD player back in using the composite cable.
It should be noted that if you have a progressive scan TV which HD TV's support you will get a better picture if you use the Component video cables instead of switching back to the composite cable. If you decide to use the component cables you will still need to run audio cables though.
Best of luck.
Trevor
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
Prgressive Scan
Check with this turn on the combo check there is no disc on the tray push the stop button for 6 seconds
Aug 03, 2009 | Daewoo DV-6T955B DVD Player/VCR
Progressive scan
I had the same problem once and the solution is to reboot the DVD player. to do this you need to unplug the unit for 3 or more minutes and then you will have to go through the setup process again but everything should work fine and interlaced (not progressive) should be the dvd format again.
Feb 05, 2009 | Toshiba SD-V392 DVD Player/VCR
Split screen on DVD player
This sounds like a progressive scan issue (unit in P.Scan Mode) here is a C&P from the manual
Set "Alt Video Out"
Highlight "Alt Video Out", then press the RIGHT button to select
one of the following options:
• S-Video - Select this if you are using the S-Video OUT jack on
the rear panel to connect to a TV.
• Component - Select this if you are using the COMPONENT
VIDEO OUT jacks on the rear panel to connect to a
Progressive(480p) or Interlaced (480i) TV.
• See your TV owner's manual to determine what type of TV you
have.
- Interlace : Interlaced Scan mode will work.
- Progressive : Progressive Scan mode will work, and Video
and S-Video will not work.
• Press the Progressive button on the front panel if you have a
Progressive scan TV only. Otherwise, the picture will be
disturbed.
Feb 04, 2009 | Samsung DVD-V3650 DVD Player/VCR
Brand new DVDs will not play in Samsung Progressive Scan v3650
If you're trying to play through to your TV through the RF out on your combo unit, it's probably the copy protection that's stopping the playback. Try through the composite/audio jacks.
Jan 04, 2009 | Samsung DVD-V3650 DVD Player/VCR
I have a V3650 DVD Player, can i copy my old VCR tapes to DVDs ?
this player will not record copy garded material (this will not work! and yws the life of a VHS Tape is only about 15 years!
Dec 09, 2008 | Samsung DVD-V3650 DVD Player/VCR
Does this burn dvds of vhs movies
A CD has less than a quarter of the data capacity of a dvd and so a video CD is only suitable for short films unless the movie is converted into another format; Ogg or Mp4 for instance. In such a format a CD will hold a movie but often the quality is poor and disappointing.
Nov 07, 2017 | Sanyo Cinematic Progressive Scan DVD...
Samsung DVD-V3650 DVD Player/VCR Logo
211 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
