Question about Sony PlayStation Portable (PSP) Console
How to fix fat psp battery the light keeps on blinking
You can kiss a girl
Posted on Sep 10, 2009
I bought a 2gb memory stick for my psp, once i insterted it in an orage light keeps blinking and while i put it on usb mode it says there is no memory stick insterted when there is
If the MS light keeps blinking continuously, that means that the PSP cannot read the MS you inserted. That happens normally. You just need to take it out, then put it back in. That's the simple fix there.
To pull it out, open the MS slot first. Gently push the exposed part of the MS, inward to pop it out.
When putting it back in, make sure that it's perfectly aligned and that the light blinks fast only for a couple of seconds (2 to 4sec) and then immediately stops. That means, the MS is properly placed and can now be read.
May 15, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
Tip
Pandora's Ultimate Magic Stick 3.80M33-5
New version of UPMSv3 - universal PSP Unbricker/Downgrader/Upgrader, also known as Pandora's Ultimate Magic Stick, Now work with DC ver4 (Dark_AleX’s), for installing CFw 3.80M33-5 and creating memory stick into a “Ultimate Magic Stick” for use with “Pandora’s battery” (jigkick). Works for both PSP, Slim and/or Fat, and 1 stick for all functions for Unbricker/Downgrader tools. Also available is the “UPMS_v3.pdf Guide” to help you get started and usage.
The Ultimate Pandora’s Magic Stick is the simple solution to easily accomplish any of the following:
  • Recover any bricked PSP (Fat or Slim) and install sony firmware or CFw M33.
  • Upgrade Fat-Slims PSP to CFw 3.80M33-5, with 1.50 kernel patch-Fat Only.
  • Upgrade Fat-Slims PSP to CFw 3.71 M33-2, with 1.50 kernel patch-2 -Fat Only.
  • Update to 3.71M33-4 are installed to the ‘GAME’ folder from the XMB.
  • Downgrade Fat PSP to Fw 1.50.
  • Upgrade Fat PSP straight to CFw 3.52M33 from Extended Boot Menu then install update 3.52 M33-4 from XMB, without need to downgrade to 1.50.
  • Boot up PSP using Ultimate Loader with support for choosing which Pandora’s you reach V1, V3 or V4.
  • Boot up PSP to XMB with UPMS inserted-Fat Only.
  • Boot up to a full FW 1.50 from Memory Stick-Fat Only.
  • Use PSP Filer and other tools (If it requires 1.50, can’t for Slims).
Note: This software is free, and comes with no warranty. Despite it has been tested and it has worked, there is some risk with any PSP operation that involves flashing, so please try this at your own risk!.
Only Memory Stick "Pro Duo" are compatible. Memory Stick Duo are not supported. Read more... for installation
here.!
on Mar 06, 2008 | Sony PlayStation Portable (PSP) Console
I engaged the alarm on my 2001 Fat Boy and the
i'm no expert on new Hogs but try this.In car alarms disconnecting the neg.lead resets the computer.when you reconnect the neg.lead the alarm goes off.In your case turn the alarm off by turning the key on.Your alarm light keeps blinking like it's still on because it is.The blinking and ticking should time out so your battery won't go dead but the anti theft feature should still work.locks out the ign. or locks fuel pump if your injected.Since your battery saver doesn't work the system might be shot.If you have a chip in the key the system may not recognize it ,doesn't know it's you.Try unlocking the bike with the remote if it has one.I vote for the bad system,pull it out an wire around it.Good luck.
Mar 18, 2010 | 2000 Harley Davidson FLSTF Fat boy
Have a psp with ofw 3.96 it a psp 2001 eny help trying to put cfw on it ?
Pandoras battery is the safest way to get CFW on your psp you need a CFW psp (borrow from friend) and a psp 1000 (FAT psp) battery when you make the pandoras battery on the CFW psp you stick the fat battery and magic mem stick into your psp and upgrade voila CFW look up pandoras battery EZ installer you could make the battery in bassicaly 5 steps
Nov 24, 2009 | Video Game Consoles & Games
Ihave a problem with my psp i can't see nothin in the screen but i can hear the sound
You have a semi brick psp, if your psp is scph-100x fat or scph-200x slim (not ta088v3), you can fix its under recovery menu. hold right button while turn on psp then, goto advance and select format flash1 and reset setting.. or by unbrick your psp using pandora battery.
otherwise, you might to send it back to sony if your psp ta088v3 or psp scph-300x
Aug 27, 2009 | Sony PlayStation Portable (PSP) Console
Psp power failure
maybe the main problem is the battery, change your old battery and buy a new one. thanks
May 26, 2009 | Sony PlayStation Portable (PSP) Console
Black screen malfunction!!??Help!!!!
it sounds like you have bricked your psp there are ways around this but its to do with changing settings and adding a recovery program to your psp (in other words hacking) but i aint the expert on this but if you search it up on youtube you can find some great videos that people have uploaded with the same problem as you and they show you how to get around your problem, im stuck with a problem with a region code not been correct and i dont know if i need to use the recovery program to help me through it.
Aug 23, 2008 | Sony PlayStation Portable (PSP) Console
Psp
There are batteries that at 20% of charge left go off and keep blinking if thats your problem, just connect ac cable den put battery and restart manually. I have a similar battery
Dec 12, 2007 | Sony PlayStation Portable (PSP) Console
Psp pro duo card
try formatting it on your computer first
use the FAT file system
Oct 19, 2007 | Electronics - Others
Sony PlayStation Portable (PSP) Console Logo
246 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
