Question about Maytag Dryers
Dryer got very hot and smelled burning..
My maytag dryer got super hot and smelled like something was burning. It also had been making a humming noise that is louder than normal. It's 10 yrs old.
  • 26 Answers
This is usually a result of a stalling idler pulley or drum, causing a burned spot on the drum drive belt.
The situation will only worsen. The belt is best replaced before it breaks.
Items to pay attention to, when the drum drive belt is replaced, are:
(1) Clean and lube the idler pulley and drum roller shafts.
(2) Confirm that the drum glides will yield additional service life.
(3) Check motor condition and de-lint the blower housing and blower intake pathways.
Posted on Sep 08, 2009
GE DPXH46GA6CC gas dryer makes large humming noise in heat cycles and burning smell
Two things are likely going on here,1- something is dragging down your motor check for a twist in the belt, idler pulley bad, belt installed wrong or wrong belt. Also check your front drum felt and glides if the felt is bunched up that will drag down the motor. Now the smell you probably have some felt or lint in the burner clean it carefully you do not want to damage your igniter.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gary_58e9c3508cafe590
Aug 04, 2013 | GE Dryers
The dryer makes a lound noise like grinding and smells like something hot or burning. I see no smoke and it started ok after a couple of turns or so the first time but the second time was when I smelled...
my daughter had a maytag dryer doing the same thing. I took it apart and the bracket that holds the drum broke off. it is cheaply made. what happens it that this causes the drum not to spin freely and causes a lot of resistence on the motor. the motor will get over worked and also the belt will slip causing smell and heat. my daughter ran hers for a while it was doing this and it also messed up the motor. we just bought a new dryer. all these parts are available, but it might be cheaper in the long run to get another one.
rick
Jul 18, 2011 | Maytag Dryers
My dryer isnt working all of a sudden, although i have noticed that it would get super HOT almost like a burning hot smell??
Open up the dryer and take a look at the fluff inside. Clean all of that out and check the blower housing. Remove all air restrictions.themobilian_347.jpgthemobilian_348.jpgthemobilian_349.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 02, 2010 | Maytag MDE308DAYW Electric Dryer
Dryer smells like something is burning and making a slight humming sound
check tub bearings and/or rollers or for anything that could impede the turning of the tub. Sounds like something is stopping the tub enough
to make the drive motor turn on the belt causing it to burn and smell.
If you fix the problem with the tub be sure and change the belt
Leo Ponder
imufo2@sbcglobal.net
Jul 28, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Wont start, smells like something is burniing
if its electric burning smell,its either a overheating motor,capacitor or both or burnt connections,sounds like a motor problem,it will be very hot to touch if its failing,check capacitor though as it could be causing motor to overheat,rating of cap is on side
May 27, 2009 | Maytag Dryers
Maytag dryer mod #mde600ayw only makes a humming noise when start switch pushed will not turn.
a hum with a burning smell means the motor winding has failed.
you can try this: open the door and hold in the door switch, have another person hold the start button. You manually roate the drum by grabbing a fin and moveit while the unit is humming.IF the dryer starts, you need a motor.
Good Luck!
Feb 28, 2009 | Dryers
Dryer making loud noise
the humming noise is most likely your motor. does it overheat or shut down on you? do you smell anykind of burning? Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
264 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
