Question about HP Pavilion dv6000z Notebook
I go to turn on my laptop and it keeps beeping.
The screen stays black. and a little white line like it typing just blinks.
  • 241 Answers
This is usually a corrupt Widows software problem, but it could also be a failing harddrive issue. What you're seeing is a DOS prompt meaning Windows hasn't loaded yet.
If you know how to boot from a Windows installation disk, do that and go past the first "do you want to repair" offering until you reach the point where the system says it found a previous installation of Windows and would you like to repair or install new. Select repair and let the process run. It will eventually reboot and load the repaired Windows. It it doesn't, your harddrive is probably failing. Replace it and install Windows and all of the appropriate drivers for your laptop.
If this is beyond your ability, take the laptop to a reputable shop and they will do the repairs. No amount of restarting is going to fix the problem. The repairs noted above must be done..
Posted on Sep 07, 2009
  • 916 Answers
Check you hard drive connections and make sure the drive is connected properly. If it is load your windows disc and run a repair installation of windows. If it does not show a windows partition or will not load the repair it means the hard drive needs to be replaced.
Laptop was beeping with screen black on start up
Your battery is perhaps out of charge. verify it is holding charge.
The Dell Inspiron 15r n5110 battery appears to be notorious.
Check step 5 in the video below.
For the newer ones that have the battery on the bottom, look on the battery for a little white rectangle with 5 lights on it. There will be a button next to them. Push it. The lights will come on. The number of lights will give you an estimation on how much it has left.5-Full. 4-80%. 3-60%. 2-40%. 1-20%. None-0%. If it is a half, the lights will stay on and the last one will blink. 4+1=90%. 3+1=70%. 2+1=50%. 1+1 =30%.
Please go ahead and power off this system and when you power it on at the Dell logo, keep tapping the F2 key repeatedly for 3-4 times this will take you to the system set up. Please check the AC adapter type and Battery health under Advance tab.
Please follow the steps below within operating system (assuming windows) and let us know the status:
1.Click on start button and navigate to Control Panel>Hardware and Sound\Power Options
2.In the left pane of the window, Click on "Dell Battery Meter"
3.Click on "Battery Life " tab
4.Click on "Disable Battery Charging" and click OK
5.Reboot your laptop.
http://www.wikihow.com/Check-the-Charge-of-a-Dell-Laptop's-Battery
Mar 15, 2016 | Dell Inspiron 15r n5110 Laptop
MRI ER710 only gives black screen after hitting the power button
try removing one by one components and then try to start.
if there's some beep code or flash pattern then do tell !!
that might take long process of troubleshooting..
do contact me to solve it.
Jan 23, 2013 | MSI Micro Star International Computer - 17...
My t42 laptop's screen froze the other day so i turned it off and when i turned it back on the screen stayed black and beeped four beeps then pause then four beeps then pause then four beeps then pause...
keep pushing f2 now youll see the page use arrow keys change your boot log f12 now restart it back up on a f12 now it going ask you do you want run windows go there.
Feb 05, 2011 | IBM ThinkPad T42 Notebook
Laptop turns on but screen stays black with a blinking white cursor and wont boot up
Hi. Turn on the computer then keep on tapping the F12 key while computer is starting up. Once you are prompted with the boot menu select the harddrive (ussually the first item) then press enter.
Oct 13, 2010 | Computers & Internet
Dell Inspiron 1545 Booting Problem [Black Screen].
Insert the original Windows CD-ROM into the DVD-drive, and see if the computer will "boot" from that disk. If so, then it could be your 'C:' drive which is having the problem, and thus not "booting" your computer from it.
Jun 15, 2010 | Dell Inspiron 1545 Notebook
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
EMachines E19T5W Flat Panel Monitor - keeps blinking red, green, blue white lines
On the monitor below the screen has these fine pink and green lines blinking across the screen all the time on my laptop. Can you tell me how to fix it or solve this problem?
Aug 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Television
tbrace, your picture tube is getting a little tired, the "IK circuit" is causing the blanking of the video because the tube is not returning a large enough signal back to the IC that monitors it. Theres only one fix (besides replacing the tube) for your set and that is to turn up the screen control. You have to remove the back from the set and on the right hand side there is a large plastic part called a flyback transformer, with a heavy wire coming out of the top which goes up to the picture tube, mounted on the front of this transformer is 2 black blastic "philips type" controls, one over the other look closely and one will be marked focus(do not turn that one) and the other is the screen control, turn the set on and SLOWLY turn the control clockwise until you see a bright picture with white lines in it, once you see the lines turn it back until they disappear, (check several channels to be sure they are gone) your done, may last 3 weeks, may last a year, it`s all you can do, BMW Rider
Dec 14, 2007 | Televison & Video
Will not go past startup screen
I think u need to updrage ur bios and RE-INSTALL UR WINDOWS
Oct 26, 2007 | Dell Inspiron B130 Notebook
HP Pavilion dv6000z Notebook Logo
87 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
