Question about Hotpoint Aquarius WF220 Front Load Washer
Aquarius 1100 - door won't open
Hotpoint aquarius 1100 washer/drier - door won't open - tried switching off and leaving for several minutes; rewashing on different cycle; using dryer to finish cycle but still locked.
  • Anonymous Mar 27, 2014
    machine runs through programs but stays on 1 for several minutes usually finishes but has come up with F02 Also leaves some soapy residue
    Problem Solver:
  • 14 Answers
Lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Posted on Sep 07, 2009
  • immune Sep 07, 2009
    lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Door will not lock on my Hotpoint Aquarius WMA35 1100 Spin
i would get a new door or catch from the hotpoint website hope this helps
Jan 24, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Aquarius Hotpoint.. keeps doing rewash after rewash.. door won't open when i switched the washer off its like its trying to either empty water, but making a noise when its trying it.. what wrong and can it...
Unplug First!!!!
You Can Pry The Top Off With A Big Flat Head Screw Driver Where The Seam Meets The Casing.
Then You Can Check The Belt Thats What Is Most Likely Your Problem. Take The Broken Belt To Your Local Auto Part Store And Tell Them you Want One That Size And Replace.
Jan 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Removal of door seal on hotpoint washer drier wd420
You will achieve nothing by removing the door seal .
Depending what is in there, better to leave alone and trust it will find its way into the filter.
If it is anything substantial then it involves major work.
Dec 14, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius
I have a hotpoint aquarius washer/drier. I don't know if this will solve your problem but I know with mine, this almost always happens, the only way I can get it to start is by firmly pushing the door a few times around where the lock is, once I hear a little click inside it will start ok. I presume its because it wont start as it isn't registering that the door is closed, the only time it does not do this is if I literally slam the door really hard. Hope this helps you!
Sep 13, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius 1100 washer dryer
probably not door switch, but to access, remove door gasketf rom cabinet in area of door switch and door switch is only held by 2 screws. more likely to be the suppressor capacitor. remove top and look at suppressor - they sometimes go pop
Aug 17, 2008 | Hotpoint Aquarius WF000 Front Load Washer
did you check the plug top fuse? Try plugging a reading lamp in to check you have power. If you have, suspect the on/off switch or the door interlock micro switch, or a burned out wire to either
Oct 20, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Oct 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF220 Front Load Washer Logo
556 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
