Question about LaCie Computers & Internet
Hi! I have an external LaCie drive. It has worked fine with my mac. Suddenly yesterday, I tried connecting it and it sounded like the drive was unable to spin or something...no icon appeared on my desktop...and I couldn't use it...
    Champion:
  • 435 Answers
Of course no icon will appeared on ,because there is no electric signal coming in the drive ,that the main problem you have to the search for it ,it can be the cable is not good ,it can be defected ,see for it ,once it receive the electric signal ,you will hear sound its spinning ,hope that clear your mind and help you
Posted on Sep 07, 2009
Suddenly, my 500GB Seagate external hard drive couldn't mount on my iMac. It was working fine till yesterday. I connected them to the Mac USD port, and the light in the seagate is blinking... Any
I can only comment generically:
I would try to uninstall the drive on the OS. Then re-start the computer. After the re-start, connect the drive and see if the drive re-installs itself.
If the error persists, then the drive is indicating failure. To absolutely verify if it has failed, take the drive to a store where there are MAC computers and try the drive on one of their computers to see if it works.
A continuous flashing LED on most devices where the LED does not normally continuously flash is an indication of a failure of the device. Some devices will flash an error code when designed to do so, and if possible.
Jerry G.
Aug 14, 2012 | Apple iMac 17" Desktop
My mac wont find my lacie external hard drive
do u connect it in the keyboard? if yes then that doesnt work cause it doesnt have enough power to go through the keyboard. if u connect it in the back of mac then it should work
Aug 11, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
My lacie external drive wont transfer my data from a mac to a pc
Basic Troubleshooting:
-Check all connections (Ethernet, Power, USB, etc)
-Install the appropriate driver for the device, usually included on a CD
-Double Check compatibility with your system (system requirements usually on packaging of product)
-If you haven't rebooted since you set it up, then reboot, this fixes a lot of things
-Try the product on another computer
-Try different cables/ports on the comptuer.
If nothing works, then send it in if it's under warranty or contact a professional service.
Feb 13, 2010 | LaCie Hard Disk 750GB with Hi-Speed USB2.0...
My Mac suddenly cannot find my Lacie external storage device. I have turned off, unplugged, restarted... etc. and it is still not finding it. The Lacie seems to be on, at least the blue light is...
A continuous flashing light on a Lacie drive is a notification of a problem. I do wonder if the light is flashing the same if the drive is plugged in to the Mac or unplugged.
Lacie external drives tend to have power-supplies which become weak/bad. Most users replace the supply and it will work again for awhile until the supply dies again. Try bringing the drive to a retail dealer with Lacie drives -ask them if you can just test your drive with another power-supply (if you do not have another). You can also try calling Lacie, it's always slightly possible they will be aware of this problem.
Alternately, IF the light is only flashing when the drive is plugged-in to the computer, try using a different USB or Firewire cable.
Aug 31, 2009 | LaCie Computers & Internet
XP doesn't recognize 500GB external Lacie after almost 2 years
try it on different usb ports on your system
try replacing the cable which connects the hard drive with the usb port
if this does not works the problem lies in the portable hard drive and i think it would be under warranty period so get it checked
Jul 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie BIG HD suddenly invisible to my Mac
from the description either th drive or the 1394 logic board has failed. Try having the technicians at you local PC shop swap the actual hard drive from the Lacie enclosure into a new enclosure and test it. If it works, buy the enclosure and you're back in business, if it oesn't and you need the data on the drive comment back with your Country, State & City and I'll refer you to a good Data recovery specialist in your region.
Hop this helps FixYa,
Chris
Jun 27, 2009 | LaCie Big Disk Extreme with Triple...
Macintosh computer not recognizing the LaCie external hard drive
1. If you have another firewire device test this device with the same firewire cord you are currently useing for the LaCie. (if there is no reasponse form the other device then it is the cord it's self) If not then 2. Check the Leads on the back of the LaCie where the firewire plugs in if the copper looks tarnished use a ear swab dipped in Lime Away or CLR to clean it then wait for it to dry and try the cord again. 3. if these physical connections are in good connection with each other and the firewire in port on your computer and on the LaCie are good then. Run a "Permissions" verify and repair through the disk utility program on your Mac with the LaCie turned on and plugged in.
FINALLY if none of these options repair the LaCie you may have to open the LaCie up and check to make sure the soldering from the firewire to the chip set is still in tact. I hope this helps Happy Macing.
Mar 28, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Is my LaCie External USB 2.0 500GB fried/dead???
You're not missing any step at all, because with SATA hard drive if its really working your computer should
automatically detect it and since this hard drive suddenly stop working there's a possibility that its already
fried but if you want you can try this hard drive again to a different computer and if still not detected by
second computer its already dead.........
Nov 07, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
Computers & Internet Logo
26 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
