Question about HP DesignJet 1050c plus InkJet Printer
My 1050c plotter has come up with error code 0B00D 0000002 can anyone advise on this
    Scholar:
  • HP Expert
  • 123 Answers
This is a Power On Self Test (POST) error. It indicates a missing 24VDC. The probable cause is an over current condition from a motor (24 volts is used to drive motors). The power supply has circuitry that shuts it down in over current conditions to protect itself. There is probably a bind in a mechanical mechanism causing extra stress and over current in one of the motors. The motors are: carriage belt drive, paper drive, and service station motor. Remove the covers and move each mechanism manually to check for binds or broken parts. If nothing is found, replacing the motors is the next best bet. Replace them in this order: Carriage motor, Paper motor, Service station. If that does not cure the problem, replace the Power Supply and finally the Formatter Board. The manual can be downloaded from: www.lpscomputer.com/ec/manuals.htm and parts can be purchased at: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Posted on Apr 16, 2010
Error code :0a00100000001 what is this
Hello. The error 0A0010 indicates an air pressure system failure. The APS is located under the ink supply station on the left side of the plotter. The assembly can be ordered from: C6072 60387 Designjet 1050C 1055CM APS Air Pressure System
The service manual with replacement instructions can be downloaded from: HP Designjet 1050C 1055CM repair parts and accessories
Aug 13, 2015 | HP DesignJet 5500PS InkJet Printer
What is system error 0B0006 on Hp design Jet plotter? I have replaced the power cable but no luck
The Trailing Cable has been incorrectly connected OR the fuse in the Electronics Module has been burned.
Corrective Action: Turn the Printer OFF and disconnect the trailing cable. Check that the ends of the Trailing Cable are flat and are not damaged or bent. Reconnect the Trailing Cable correctly, making sure it is pushed in firmly. Do the resistance test. Power ON the Printer and check if the Error Code disappears. If the Error Code continues, replace the Main Logic Board
Note: The logic board is a direct replacement for the Designjet 1050C Plus and 1055CM Plus. If the plotter you are repairing is the Designjet 1050C (not Plus) you will also need to replace the memory and the firmware.
If you are repairing a Designjet 1055CM (not Plus) you will have to replace the Hard Disk Drive also. The firmware is identical for the 1050C Plus and 1055CM Plus
Note: The aerosol fan is not used in the Designjet 1050C Plus or 1055CM Plus. Coil the cable out of the way or completely remove the fan.
WARNING TAKE CARE WHEN CONNECTING THE TRAILING CABLE TO THE ELECTRONICS MODULE OR CARRIAGE. INCORRECT INSTALLATION WILL BURN THE FUSE IN THE ELECTRONICS MODULE, CAUSING THE COMPLETE FAILURE AND REPLACEMENT OF THE LOGIC BOARD. 100 OHMS OR HIGHER MUST BE SEEN AT THE TEST POINTS. CONSULT THE SERVICE MANUAL FOR CORRECT PROCEDURE.
Continuable and Non-Continuable Error Codes
Some of the Error Codes are continuable, which means you can press Enter on the front-panel and continue working with the Printer. Non-Continuable Error Codes do not allow you to continue working with the Printer, in this case power the Printer OFF and ON again and see if the System Error disappears. If the Error Code reappears, then the Printer requires service in order to resolve the problem.
System error codes are hexa-decimal based numbers generally caused by internal system errors. Only try one recommended action at a time and check if the error code has disappeared.
thanks and regards
kindly rate this solution
Feb 12, 2011 | HP DesignJet 1050c InkJet Printer
System error on plotter screen
Follow-up to previous message... ended unexpectedly.
Enter the test mode and run the ELECTRONICS test. The plotter will tell you in plain English what the problem is. If it hangs up, power down.
Jul 06, 2010 | HP DesignJet 1050c plus InkJet Printer
HP Designjet 1050C Pluss - Error Code Question
Hi there only can try.
This is a firmware error, meaning your f/w simm is probably bad. You can try reseating the simm. It is behind the small panel in the back of the plotter, that is held on by 4 torq screws. Reseat all the simms that are present and see if that helps. If not, you probably need to purchase a new firmware simm.
Also try looking at
pulling the JetDirect card and then re booting it
Feb 10, 2010 | HP DesignJet 1050c InkJet Printer
What does this mean on an HP Plotter 1050c?
the electronics module is in the rear of the machine and controls the printer. you have had a catastrophic failure and your e-mod needs to be replaced. these parts are becoming harder to find. check for local service. if you intend to keep this printer it is worth the fix.
Oct 14, 2009 | HP DesignJet 1050c InkJet Printer
HP 1050C Plus shuts down prior to plotting
09Bxxx is an internal error. Probably a bad Hard Drive or Main PCA board. Hopefully it's that Hard Drive because the main PCA board is EXPENSIVE.
Try replacing the Hard Drive, check to see if that fixes your problem. If not, then try replacing the Main PCA.
Sorry, and Good Luck
Sep 22, 2009 | HP DesignJet 1050c plus InkJet Printer
Error code showing on my HP 1050c plotter
The error stands for : 24V source test failure.
And i'm sorry to say but the service manual then tells you to try the following:
- Replace the scan-axis motor assembly.
- Replace the paper-axis motor assembly.
- Replace the service station assembly.
- Replace the main pca.
- Replace the ISS pca.
- Replace the power supply unit.
- Replace the electronics module.
(only replace one component at a time)
Yeah then you have to guess which part to start with.
Maybe anybody else on this forum knows more about the error and has a better idee about the part you should start with.
Just take a good look at the machine, and check which sections of the start up works before the error is prompted.
e.g. If the carriage moves then you could say that the scan-axis motor is probably ok.
Good luck....
Sep 07, 2009 | HP DesignJet 1050c plus InkJet Printer
Configure of hp designjet 1050c
Manuals for the driver and plotter setup can be found here:
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=24023&lang=en&cc=us
Jul 24, 2009 | HP DesignJet 1050c plus InkJet Printer
HP Design Jet 600 Plotter
The problem the 'alignment error' this causes is car desalignment, is need repair phisical.
May 29, 2008 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 1050c plus InkJet Printer Logo
302 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
