Question about Brother MFC-440CN InkJet Printer
Printer is linked tolaptop but when the print is sent an error apears and will not print
  • 46 Answers
Uninstal you software and instal it back this the easy way there some other way but again si to much to deal w/it good luck
Posted on Sep 07, 2009
Paper jam error
This error apear usaly on this machine , when the cloutch sistem of paper feed roller are obsolete , to fix this issue you must clean the sponge out the clutch or replace-it becouse this is already sticky
Feb 02, 2014 | Kyocera Mita FS 1010 Laser Printer
A document was sent to the 5110cn color printer. it is a full color duakl sided brochure. Keeps trying to print but errors out before loading all images so all that gets printed is one or two of the...
The reaason it keeps trying to print is because it's in the print queue on your network.
Have whoever sent this to the printer open the print queue and delete it.
Only the originator or the print queue admin can delete the job
Jan 06, 2011 | Dell 5110cn Laser Printer
DI181 ERROR C1300
The motor in side the print head error the print head houses a motor which scans the LASER across the drum, can't get just a motor you get the entire print head try this site if they still have them you have a legacy Minolta machine now Konica Minolta. Open close the front door to reset.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
May 25, 2009 | Minolta DiALTA Di181 Printer
Service Printhead Error
this problem come whene printer fuser chamber have faulty ,
fist of all do service of fuser and check
after than change pressure roler and teflone slive if problem not solve
Apr 22, 2009 | Lexmark E450dn Laser Printer
Nothing prints when documents are sent to printer
You didn't mention whether the error was given by the printer or by the PC but I'll give you a couple of tips for troubleshooting this...
Switch the cable to another port on the PC to see if the OS identifies it (if you're using Windows you'll get an audio sound when it gets plugged in). Try to print to it from the new port.
Worst case scenario follow this link to download and re-install your print drivers.
Feb 21, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother 2140 Printer Problem
It is most likly not linked to word. Word is likly sending the prints to the wrong, obsloete or wrong copy of the printer.
When printing check to see where the doc is being sent to print.
Then go to printers to see which printer is your 2140 active and ofcourse do a test print. If the test print is good this is the correct link to your printer.
Dec 19, 2008 | Brother HL 2140 Laser Printer
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
My printer doesnt work at all
try printing documents in notepad... if it worked then reinstall your printer driver. and make sure you have ink.
Jan 08, 2008 | Epson Stylus C43SX InkJet Printer
Printer error
What make of printer, what model. Under what conditions does the error occur? Please give at least some detail.
Oct 10, 2007 | Office Equipment & Supplies
Brother MFC-440CN InkJet Printer Logo
22 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
