Question about GE JE1460 Microwave Oven
Wire Diagram Have a GE JES831WB002 and the turntable motor went out. Bought a replacement, no big deal, but I can't remember which way the wire harness plugs in. The motor is 21V/AC and the harness is (1) orange wire on one side and (1) orange wire and (1) white wire on the other. Thanks in advance for the help!
  • otter588 Sep 07, 2009
    That's what I was thinking... Thanks for the help!!!
  • GE Master
  • 8,404 Answers
If the plug is not keyed and you cant tell from the wires, it probably doesn't make a difference. You are telling me it is 21 VAC ... AC dont care - and you dont appear to have a common ground situation.
Posted on Sep 07, 2009
    Brigadier General:
  • 4,088 Answers
Plugs and sockets are usually 'keyed' so that they can't be inserted backwards. If wires go out of the motor side, the colors usually continue through. Hope this helps.
Why wont my GE Spacemaker JVM1650 turntable wont work?
replace the turntable synchronous motor
look to ebay search for
ge jvm1650
then add turntable motor or browse down youll find a new motor
the coils inside may be duff
Aug 12, 2014 | GE Profile Spacemaker Over-the-Range...
The turntable on our Ewave KOT 170SW Microwave oven has quit rotating. Other than that the oven works fine. Any troubleshooting tips? If the turntable needs to be replaced, how big a job is it? I'm not...
i went to replace lite bulbs but didnt unplug it..removed cover and shorted out...now no lite and no turntable but does come on & heats food is it fixable.......ewave microwave kot-131uw....
Feb 28, 2011 | Kenmore 80412 Microwave Oven
Turn table stopped turning
It sounds like the turntable motor has failed. It is a synchronus motor with a plastic gearbox reducing the RPM to about 5. The gears fail when the turntable dish is turned as the motor stalls the shafts.
Replacing the motor is no big deal.
There is usually an inspection cover that can be removed on the underside of the cavity.
Remove the cover and remove the motor.
Replace with the same type and the reverse procedure will fix it.
You may however require a self tapping screw to affix the cover back on. A bit of a puzzle but not too difficult to work out!
Hope this helps.
Dec 30, 2010 | Emerson 025806092806 Microwave Oven
Microwave makes noise when turning only in one direction
It sounds like the turntable motor is failing or the turntable requires its wheels cleaning. If it is the motor, it is a synchronus motor with a plastic gearbox reducing the RPM to about 5. The gears fail when the turntable dish is turned as the motor stalls the shafts.
Hope this helps.
Dec 29, 2010 | KitchenAid KCMS1555R Microwave Oven
Turntable stopped rotating. Everything else works fine.
Hope this helps.
Nov 29, 2010 | Whirlpool MT4155SP Microwave Oven
My turntable will not rotate. I've checked the piece underneath and it appears to on correctly.
it could be be bad turntable motor.to chk this open up the bottom plate by removing the screws around it.then disconnect the wire connector from the motor.start the unit and chk the voltage with multimeter.if u read voltage then motor needs to be replaced.make sure turntable function is on and not off at the control.if there is no power at the connector then it could be control.chk for any loose wires etc.
Aug 16, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave turntable motor or belt?
I assume you don't have an illustrated parts list try and Google one up using make and model number etc. It is also a good guide on what needt to be removed and in what sequence.
As far as the novice part, the turntable is a basket case now what can you hurt, this is how we all learned, try to fix it if you cant then call someone who can, not a big deal.
Feb 28, 2009 | GE XL1800 1100 Watts Microwave Oven
Question re: installation of turntable motor
If its an AC motor, the wiring will not matter. Look at the numbers on the motor. You will see a voltage rating, RPM rating and if you see the text "50/60 Hz" it is an AC motor and the wiring will not matter.
If its a DC motor, you will see a voltage rating, RPM rating and a + & - for the wiring. If you reverse the wiring, the turntable will turn in the opposite direction.
I'm not sure about all microwave ovens, but the ones I have worked on, the turntable turns in the clockwise direction.
Most likely, its an AC motor. Look for the "50/60" text. If its an AC motor, the wiring will not matter.
Please let me know if I can be of further assistance to you,
- Jim
Feb 20, 2008 | GE JVM1640 Microwave Oven
Turntable repair? GE Profile model JVM1660BB
IF EVERYTHING IN THE OVEN IS WORKING BUT THE TURNTABLE YOU HAVE TO TAKE THE BOTTOM COVER OFF THE OVEN THE MOTOR HAS TWO WIRES ON IT, BE CAREFULL
WHEN YOU TEST IT AS THERE IS 110V ON THE WIRES.IF THE 110V IS THERE BUT THE MOTOR ISN,T RUNNING TAKE THE
TWO WIRES OFF,AND TAKE THE MOTOR OUT AND BUY A NEW ONE. YOU CAN DO THIS BUT DO BE CAREFULL.. YOU
MAY HAVE TO PULL ON IT A LITTLE TO PULL IT APART FROM THE PEACE INSIDE THAT TURNS THE GLASS TRY NOT TO BREAK IT!
Jan 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JE1460 Microwave Oven Logo
153 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
