Question about Tascam US-144 Sound Card
Phantom power ive got one of these for a c03 samson condensor mic and the phantom power doesnt work, the switch is on.. any suggestions? thank you
  • 1,512 Answers
Are you using the xlr connection socket. There should be 48 volts dc bwtween pins 2 aqnd 3 on your xlr connection. check for this and that the mic cable you are using is decent quality and has 3 internal conductors - some cheapies dont. the unit the require some repairs If there is no voltage on its input sockets.
Posted on Dec 14, 2007
Hallo .i have a problem with this: microphone condenser electret toshiba EM-220 how should it work?? it need a phantom power 48+??? i have just a normal audio jack on the mic.to plug into my mixer with...
If it is a condensor mic, it will need phantom power, some mixing desks have specific inputs that have phantom power and there is usually a switch to press. Also some mics use a battery instead of using the phantom power on the mixing des.
Good luck
Aug 09, 2011 | Toshiba Audio Players & Recorders
I have set-up M-Audio microphone recently but I can't seem to figure out HOW to begin using it. I've tried every drop down and clicked every recording button while I was using the software. . . is there...
Without knowing your setup or the mic model, my guess is that you need to run a phantom power supply to the mic to get it to function. This is done either by using an outboard analog mixing console or mic preamp with a phantom power switch, or using an inline phantom power supply. The microphone plugs into the mixer or mic pre with the phantom turned on, and then into your DAW system.
The phantom power works with condensor microphones like the one you have. It sends a 48v signal to the microphone element, which in turn energizes the element and makes it function. Dynamic mics, like a Shure SM 58 for example, do not need the phantom power and will even ignore it if run on a phantom powered channel. condensor mics however must have it to function, otherwise there will not be any sound. Hope this helps. Good Luck.
Mar 19, 2011 | M-Audio Producer USB Microphone with...
I got a 35 mm cable on my c01 and it won't work on my pc does someone know the problem..cuz when i put another mic in it just works fine
You Samson microphone requires phantom power to operate. PC's don't have phantom power. You need to run your mic thru a mixer that has phantom power.
Apr 14, 2010 | Samson C01U Consumer Microphone
How to make my co3 mic work
You will need a pre amp that supplies whats called phantom power which is power that feeds the mic .. This will come from either mixers [small cheap ones..but check it has XLR mic input with phantom power] or from a stand alone pre amp or audio interfaces with built in inputs for mics with phantom power.. Also you will need an XLR mic lead..Buy a good one with neutrik plugs or similar..
Mar 19, 2010 | Samson CO3 Microphone
I have connected the samson mic to my computer. input not detecte
A condenser mic. requires "phantom power" usually supplied by a mixing desk. Without this, there will be no output signal from the mic.
Jan 12, 2010 | Samson C01U - USB Studio Condenser...
SAMSON CO1U recordings sound like they're underwater on my MAC
The behavior you describe suggests that the mic is not getting power. Since it is a condenser mic, it requires what is usually called "phantom power". This should be provided thru the USB port. Check to be sure that the USB port is supplying that power. Check with another port for example. If that fails, you may have a defective mic.
Keep us posted.
Dan
Feb 10, 2009 | Samson C01U - USB Studio Condenser...
MXL 990 doesn't work
Your other preamp does not have phantom power to supply power to the microphone. All condensor mics like this need phantom power. The Audio Buddy provides phantom power, which is why it was shipped with those condensor mics
Jan 16, 2009 | M-Audio MXL 990/991 Recording Mic Duo and...
MY JOB DEPENDS ON THIS!!! SONY DSR PD170 AUDIO PROBLEMS
Appreciate the direct "Ask Me".
The Sony PD170 is not an everyday equipment, nonetheless, I will assume that on the Sony DSR PD170:
  • the Samson UHF M32 receiver is plugged to Audio 1;
  • boom mic is plugged to Audio 2; (or vice versa) and
  • Both Audio 1 & 2 are using the XLR connectors.
Assuming that your boom mic is a conventional dynamic, on the Audio Control Panel, pls set:
  • INPUT 1 -
  • MIC CH SELECT CH1&CH2
  • INPUT LEVEL MIC
  • +48 OFF
  • INPUT 2 -
  • INPUT LEVEL MIC
  • +48 OFF
This is of course assuming that both the boom mic and the output of the Samson UHF M32 receiver are set to MIC level. In some instances the Samson UHF M32 receiver requires a LINE setting. The only time the +48 is set to ON is when the mic that is used/plug in requires phantom power such as condenser types. If the mic or the Samson UHF M32 receiver requires power then this should be switched ON otherwise, there will be no audio coming in. Though most M32 uses a 9 volts battery.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 11, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Samson CO2 Pencil microphones
The CO2 is a condenser mic (also called capacitor mic), and as such, requires phantom power to operate. Ensure that your system is providing phantom power to the microphone, usually accomplished by flipping a switch near your mic input on your sound board.
Dec 19, 2007 | Samson CO2 Professional Microphone
Connecting samson co2
The Samson CO2 is a condenser (also called capacitor) mic, and thus requires phantom power to operate. In order to apply phantom power, you must have a board capable of handling an XLR connection, and supply phantom power. Usually there is a switch located near the XLR-input jack on your board - if you post your sound board type, more help can be given.
Dec 16, 2007 | Samson CO2 Professional Microphone
Tascam US-144 Sound Card Logo
Top Tascam Computers & Internet Experts
Ben Armstrong
vincent_hear
Level 1 Expert
Computer Links
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
