Question about Kenmore Refrigerators
Kenmore Model #70162990 the icemaker is not getting water, the supply line to the refrigerator is good.
  • dishdlr Sep 07, 2009
    Thawing doesn't help. There is water going into the valve at the rear near the bottom, but nothing is coming out.
    I by-passed the filter, removed the valve that feeds the water, tested the solenoid, blew air through the valve, it opens and closes, still no water to the ice maker, what next ???
  • 2,418 Answers
You say you have good pressure to the supply line? Follow the line into the back to a valve, One of tow things is going on. the valve is bad, or the control circuit is not supplying voltage to it. You can check the Ohm's of  the valve by - unpulging the wires and reading the spade term's with a volt/ohm meter. or you can try to make the ice maker cycle take a small screw driver and hold on top of the valve if the valve is working the screw driver will stick to the valve - magnetized. Some have a screen to catch junk in the water and that can be stoped up. turn off the water and uncrew the line at the vavle. try that.
Posted on Sep 08, 2009
  • John Fourteen Six Sep 08, 2009
    It would have to be in the control circuit. Some of the Kenmore's have a set of gears that time the water valve and the ice tray. It will have a timer that turns the gears to open the valve then turn the tray to dump the ice. Its a matter of removeing the unit and checking for striped teeth.
  • 3,741 Answers
The ice and water dispenser system for refrigerators is very complicated. There are many components working together that provide your ice and water. Make sure the household water is turned on to the icemaker, and make sure that there are no kinks in the water line.
Next, inspect the feeler arm of the icemaker and make sure that it is down and not blocked by any ice cubes. If it's raised, it has turned the icemaker off. This arm needs to be in the lowered position to activate the icemaker. An over-abundance of ice in the bin will make the arm stay up as a safety feature to keep the icemaker from making more ice than the bin can hold.
The water filter may be plugged with sediment, or you may have low water pressure. The water pressure for icemakers needs to be at least 40 psi, and up to about 120 psi for proper operation. Water filters need to be changed every six months. If you would like to test your water pressure, we have an Icemaker Water Flow Tester available from our website. This will help you to determine if the water pressure at the supply line is high enough for the icemaker to function properly.
To determine if your filter is plugged, look for water both before and after the filter. It may be hard to determine if there is water flowing through the filter. Sometimes it is necessary to pull the filter out of the feed line to see if water is flowing from the exit of the filter into the refrigerator or freezer. You can do this over a bucket to catch any dripping water. Some models have a filter bypass plug to help determine if the filter is clogged. If so, you would remove the filter and replace it with the filter bypass plug. Now test your water flow.
If your refrigerator has a water dispenser, you can hold a large cup or glass under it for 20 seconds. You should have poured about 13-14 oz. of water in that 20 seconds. If the amount is less, try removing the filter and bypassing it. If you now get the 13-14 oz. of water, the filter was clogged and it's time to replace it. If not, you have low water pressure in the line, and your icemaker may not work properly. You can also purchase this Icemaker Water Flow Tester to determine if the water pressure at the supply line is high enough for the icemaker to function properly.
On occasion, the water inlet tube will freeze where it enters the icemaker. This can happen because the water is dripping slowly, or the freezer is just set too cold. A hair blow dryer can be used to thaw this, but be careful around the plastic tubing. You don't want it to crack or deform. You may want to turn the thermostat up a little bit if this is a regular occurrence. If you have a constant, regular drip, you may want to invest in a new water control valve.
this will help.thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on Sep 07, 2009
We can't get our icemaker to work in our Kenmore bottom freezer refrigerator-model 795.7160. It is not making ice-you can hear it go through the steps and even dumps, but there is no ice.
check your water line and filter. Defrost the freezer in case its frozen. Also check the water line where it enters. Check for leaks under the valve. Otherswise you may have a bad icemaker.
Jan 10, 2018 | Kenmore Refrigerators
Water to icemaker overflowing; won't stop
you have a defective fill valve controller and only a repair service can fix it properly .
Feb 28, 2018 | Kenmore 21.7 cu. ft. Top Mount...
My Kenmore refrigerators (model #79177990) ice
Ice inlet tube may be frozen up inside of Fridge. Thaw it out with a hair blower. Shut of water supply and disconnect the water line that goes into the back. Use a flexable item at the connection to see if will go all the way through to the icemaker. I used a zip tie.
If you still don't have water going to the icemaker, you may need to replace the "Water Inlet Valve" at bottom back right of your Fridge. Easy to Do.
Jun 02, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
No water is going to the icemaker.
Seems like the water valve solenoid is not closing the circuit to allow water into the ice bin.
Jun 30, 2009 | Kenmore 55212 / 55214 / 55216 / 55219 Side...
Difference in waterline hookup between old and new icemakers
this is so often the case with some of the larger companeys. there are only two types of connections for these water lines. 1st is a compression fitting 1/4 inch 2nd is a push lock style also 1/4 inch. Both styles can be purchased at any large hardware store. they should be with pipe supplies. Hope this helps and good luck.
May 07, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore Coldspot Model 70162990 - not making ice
You've either got a bad timer on the ice maker or the water valve is defective. You need to verify that the timer is moving first. If it isn't try pushing in on the dial on the end of the ice maker. It is under the white square cover at the end of the ice maker, usually towards the door, but in some units it points to the left side wall. If it begins to run when you do that, then the timer is broken. If not then I would say that the valve is defective.
Feb 01, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore refer #70162990 ice maker leaking into storage tray
Please confirm you have given the complete model number.
If the icemaker has a bail wire to control how much ice is in the bin, there is a fill switch inside the front cover of the ice maker which allows you to increase or decrease the amount of fill.
You may also have a cracked or corroded ice mold. Check by filling the icemaker with water manually, and watching to see if it drips once the initial overfill stops dripping. This would also be indicated by the ice cubes being smaller than usual.
Jan 04, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Whirlpool refrigerator stopped making ice.
If there are ice cubes in the icemaker sitting there waiting to be dumped then the problem is in the icemaker. If the icemaker is dry then you have a water supply problem, even if you have a water in the door working.
1.Check the fill line inside the freezer at the icemaker, if it is clogged with ice then remove this ice and replace the water valve.
2. Check the water supply. Turn the water supply off, disconnect the water line from the Ref, turn the water back on an fill a small glass. If the water supply is good the solenoid on the water valve should be checked. This is done with an OHM meter.
If you got this far and need more info to DIY - ronbuice.com
Dec 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore ice maker
yes you need to hook up a line froun the cold water supply of the house to the water valve that is located at the back of the ref to the water valve that is down at the botton right corner
follow the water line from the top going into the icemaker down to the bottom there is where the valve is located behind the back cover
Apr 11, 2008 | Refrigerators
Refrigerators Logo
50 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
