I have to install a mic jack approx 150 ft from mix board, do I need any special equip to do this
  • wlk7dv May 11, 2010
    Don't know what you are playing with, but #1. Audio/live projection-wise, it sounds like you may be on the edge of 100' + snake-cables, mixers, and somebody that knows how to operate them. #2. If it is an isolated micro (you didn't state wheather it was high Z or low Z...), just install amphenol (high Z) or XLR (low Z) to connect point A to point B. Check for signal loss/degeneration and take appropriate steps to compensate (amplify) until you reach desired response level.........
    Novelist:
  • 169 Answers
Not really justhe usual high quality shielded mic cable and connectors.
are you using xlr on balanced line i/p if not then noise might be an issue
Posted on Sep 15, 2009
How do you repair a sennheiser sk100 jack socket
I assume you mean the mic plug/jack. Bent pins or broken connectors will require a new jack and/or plug installed and they are not easy to do. These 3.5 mm jack connectors require both a light touch during install and soldering. If you're a pro then start shopping for a replacement 3.5 mm mono jack but be warned. The jack may solder directly to the PC board....which reminds me. Look for broken connections from jack to PC board..a common failure point and resolder as needed.
May 01, 2014 | Sennheiser Audio Players & Recorders
What special tools do I need to remove the fuel tank from my 04 F250 for cleaning ?
Anyone special tool, just check this procedure to Removal & Installation
CAUTION Fuel injection systems remain under pressure, even after the engine has been turned OFF. The fuel system pressure must be relieved before disconnecting any fuel lines. Failure to do so may result in fire and/or personal injury.
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove or disconnect the following:
    Negative battery cable Fuel pressure Fuel tank skid plate bolts and lower the skid plate. Fuel Fuel tank filler pipe hose from the tank Fuel tank filler pipe vent hose from the tank Fuel lines from the fuel pump Front fuel tank connections Rear Evaporative Emissions (EVAP) hose clamp and the hose Electrical connector from the fuel pump
  3. Support the fuel tank with a jack.
    Fuel tank support strap bolts and the fuel tank straps Fuel tank
To install:
  1. Installation is the reverse of removal. Note the following torques:
    1. Tighten the fuel tank strap bolts to:
      F-150: 35 ft. lbs. (47 Nm) F-250 and F-350 mid-ships tank: 30 ft. lbs. (40 Nm) F-250 and F-350 aft-of-axle tank: 66 ft. lbs. (90 Nm) Mark LT: 35 ft. lbs. (47 Nm)
  2. Tighten the skid plate bolts to:
    F-150: 15 ft. lbs. (20 Nm) F-250 and F-350 mid-ships tank shield: 15 ft. lbs. (20 Nm) F-250 and F-350 aft-of-axle tank cover: 66 ft. lbs. (90 Nm) Mark LT: 15 ft. lbs. (20 Nm)
  3. Connect the negative battery cable.
Hope helps.
Dec 24, 2010 | 2004 Ford F250
I don't know where to plug the speakers in to the computer (labtec LCS-150) I just moved from Vancouver, B C.
hello vivian10
your speakers should have a headphone jack, and your computer should have a speaker-in jack and a mic-in jack. plug your speaker jack into the jack on pc
Nov 17, 2010 | Labtec LCS 150 Computer Speakers
HOW DO I INSTALL ROGER BEEP ON A GALAXY 33 CB RADIO
Does the roger beep come with instructions? It can vary between beep boards.
Typically it gets installed inline with the mic jack.
There is a wire or pin on the board where the tx wire, and the rx wires go.These wires get disconnected from the mic jack, then a wire goes to the tx pin. Then there is an audio wire that gets connected to the audio wire of the mic jack. Then the black wire to ground, and the red wire to switched 12v right off the power switch.
Here is a schematic of the board connected to the mic jack so you know what pin is what.
Again, I would need to know what roger beep board you would like to install.
Feb 22, 2010 | Galaxy Radios DX-33HML 40-Channels Base CB...
I cant make the onboard mic input work
Have you checked the settings in BIOS. That would be the first place I checked.
Dec 02, 2009 | MSI KM4M-L Motherboard
Fan not running on Heat Pum
That does not sound normal at all, I have a Goodman Heatpump and the Fan on the Evaporator (outside unit) should run as soon as it starts up!
The only delay you should be seeing is when the unit starts, the fan in the AHU starts 5 seconds after and runs for about 1.5 minutes after shutdown.
Sep 19, 2009 | Goodman CLQ36AR49 Air Conditioner
Installation
First you must determine if the mic's output from the receiver is low or high impedence. Tip: high imp. is usually a 1/4" jack , low imp. is a 3 pin XLR Conector. It also depends on your amplifier input jacks.But really you should connect the mic to a mixing console and then connect the console to the amp.But you could connect a high imp. mic via a 1/4" to 1/4",cable into the 1/4" jack on your guitar amp.
Mar 23, 2009 | Naxa Electronics NX984 Professional...
I have a shure microflex mic condencer 150 the led does not work and the mic is dead. Does the mic need a battery if so how do you instal it.
Try using a mixing console with phantom power ( + 48 ). A condenser mic needs 48 volts to operate. The led should light when the XLR microphone cable is connected to a console with phantom power.
Feb 19, 2009 | Shure (LX287CC) Professional Microphone
Canon XM2 -Audio Trouble
hi first: http://www.fixya.com/user-guide/p394384,m11809,gm57/Canon-GL2-Mini-DV-Digital-Camcorder.aspx yes you need to connect to the input jack: http://www.fixya.com/user-guide/p394384,m11809,gm75/Canon-GL2-Mini-DV-Digital-Camcorder.aspx if it wont work there is probeblya burned capacitor from the boosting good luck
May 05, 2006 | Canon GL2 Mini DV Digital Camcorder
 Grubhead
Grubhead
