Question about Toshiba Satellite A135-S2276 Notebook
Screen is black but computer works perfect.
It started randomly, now its always. computer comes on but i need a flashlight 2 log in and see anything else. light has completely gone 2 darkness but everything else works. i tried control panel- and nothing. toshiba #psaaku-009006
  • 2,229 Answers
Your display has a flourescent backlight. If the brightness control does nothing, then the display needs to be repaired.
It is possible to repair it yourself (much less expensive that buying a new one) but you may also try e-Bay to see if you can get a replacement.
Posted on Sep 07, 2009
  • 916 Answers
When this happens it means the back light needs to be replaced. The back light is a light bulb that lights up the screen from behind the LCD display.
Black screen on Droid A855
pull out the battery wait ten to thirty seconds then replace the battery switch on then check it
Mar 23, 2012 | Motorola Mobility A855 Droid
When i was playing a game my whole computer just shut down. when i started it back up nothing will show up on the screen. it just stays black,but the lights will come on the computer..what could be...
Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, Reg In Out to fix the random shutdown problem with my laptop. increase ur ram also
Sep 02, 2010 | Dell Inspiron 1525 Laptop
Dell LCD screen - powers up...i see the log on then black
I guess your monitor needs some maintenance.
Have it checked by a technician
Mar 28, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
My LCD screen stopped working. Playing a game when the monitor was blackened. This time the screen is black. If I start the monitor, the led is orange, if I connect to my PC led color turns green but does...
victorash02, Is screen black n blank, or just black? Do flashlight test! Yes it could be both! Most likely problem with unit's internal "switch-mode-power-supply"/"CCFL inverter supply". You or technician will need to investigate for probable cause of black screen of death. Need a little history of unit! Did it work just fine 2 weeks ago? How many "ON" hours of use on the unit? When was it made? Did you PROVE that PC not cause and works ok? Get back here with more info so we can help.
12fixlouie on fixya. Read my fixya profile for a little while.
Mar 09, 2010 | BenQ FP71G 17" LCD Monitor
Spectre x7, at startup, screen blinks on and off. blue light at bottom also goes on and off
leos343872, Black screen type of failure. Is anything still displayed even though screen is black when you hold flashlight 1 inch from lower left corner near start button??? Possible "switch-mode-power-supply" in shutdown mode. Tech or you will need to evaluate further!! Read more of my advice to other owners with BLACK screen monitor problems in my profile. or louie12fix profile. 12fixlouie
Dec 14, 2009 | Sceptre X7G-Naga 17" LCD Monitor
The l226wtq goes black
Try shining a flashlight on the screen, or without the flashlight, try to see if you can distinguish anything on the screen at all, if you do, the backlight is dead, or the monitor has an internal most likely unfixable problem.
May 01, 2009 | Computers & Internet
Monitor comes on, I can see everything perfect then goes black
"Most" newer monitors will let you know if the are no longer receiving a signal. Sounds like the backlight is burnt out. Try getting a bright (LED works best) flashlight and shining it at the screen at all angles to see if you can see any of what you were doing. If the backlight is on the fritz, either return it on warranty or buy a new one.
Jan 31, 2009 | Westinghouse L2046NV Monitor
Monitor goes blank less than a second after turning on.
there is an hardware issue in your lcd it needs to change one of the capaciter please take it to a lcd technician
thanks
Jan 24, 2009 | Acer AL1715 17" LCD Monitor
The screen goes blank at start up
If you can not see anything, then it may be your inverter (Replacement part cost is around $50.00), if you can see a dark image then your CCFL (Cold Cathode Fluorescent Lamp) is out. (Replacement part cost is around $15.00)
Check websites like http://www.ccfldirect.com/
Oct 16, 2007 | HP Pavilion zd7000 zx5000 zv5000 presario...
Laptop troubleshooting
When it turns black take a flashlight and shine it on the bottom of the screen where the start button would be. Look closely and see if you can seen any faint images there. If you do then your backlight is malfunction. That typically is not a self-fix for the typical user. If you don't see anything can you give us some more information. - Are any lights flashing just before or after the screen turn black? - If you restart the computer will it work again? - Will the screen go black even if you are actively working on the computer? If its not the backlight let us know the answer to these questions and we'll continue. As always please don't forget to rate this posting.
Feb 06, 2007 | NEC Versa E120 (VERHDGJ00B00T) PC Notebook
Toshiba Satellite A135-S2276 Notebook Logo
129 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
