CDs quit playing and changing. It says "CD Error". I removed unit and manually unloaded CDs. Will the CD changer correct itself through rebooting, or is it a system problem requiring repalcement?
CD player is not working. Motor will not unload or load discs. It will play CDs fine but cannot change them. Unit will need to be repaired by an audio specialoist or replaced.
Error 1"The changer is unable to load or unload a disc, the changer can't operate".
Means your machine is in need of repair (unable to load or unload a disc), remove the cd player and send it to the manufacturer for repair (that's what the car dealer will do if you ask them to repair it for you).
With the low current draw that a cd unit uses It would take some hours to affect a good battery. Remove the fuse for the cd unit and have a battery shop check the battery for a bad cell ( Load test on the battery). Pull the cd player and have a tecki look at it as I feel you have 2 faults not connected.
the problem could be just dirt. Take the changer out and removed
the lid from the case. With a can of squirty air or an airline (be
careful using the latter), blast the dust out of the unit. Also,
clean the laser lens with a correct cleaner,
I'm having the same problem and want to know how to fix it without having to take it to the dealer. my cd's won't come out or let me put any in and it keeps saying CD CHANGER ERROR
just replaced my 2006 Pontiac G6 GT Monsoon 6 CD changer with an identical model pulled from a totaled car.How do I reprogram it so it works on my car.
