Question about Samsung HL-P5063W 50" Rear Projection HDTV
I just replaced the lamp on my samsung HL-P5063W (DLP TV)...now the TV will not turn on (no picture...but I do get sound)...when I plug it in, it automatically starts to power on...then it starts making this humming sound (like it's about to take off and fly)...the "lamp" message continues flashing for about 15 seconds...then it goes into "stand by" mode for a second...and starts the same cycle again...the only way I get it to stop is to unplug it. Any help would be greatly appreciated.
    Problem Solver:
  • 6 Answers
Sounds like a bad color wheel. Generally when the color wheel goes bad, when you try and turn the TV on the lamp will ignite for a couple seconds and then turn off. It also makes a rather high pitch squealing noise.
www.Partstore.com should carry a replacement color wheel for your TV
Posted on Sep 17, 2009
2 Suggested Answers
  • 10 Answers
SOURCE: samsung HL-P5063W DLP rear projection LCD red
Make sure that, obviously it's plugged in at both ends properly, but also that none of the pins are bent or broken.
Posted on Jul 23, 2009
HI FOLKS, I HAVE A SAMSUNG HL-P5063W DLP TV THAT WON'T TURN ON. WHEN I PLUG IT INTO TO WALL I GET THE SOLID RED STANDBY/TEMP MESSAGE ON FRONT ON/OFF BUTTON. THEN WHEN I TURN IT ON, THE STANDBY/TEMP MESSAGE...
Bad Lamp Call FOX 1-800-227-5369 Lamp number is
BP96-00608A or BP96-00826A $109.00 Mats Electronics is another company for Lamps 1-800-628-1118 or Find one on E-Bay
Nov 30, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-P5063W DLP No. 1 fan problem
Defective Lamp,maybe and Ballast Board may well be the problem it is what turns Lamp on Look on line Encompass Parts Dist 1-800-638-3328 Ballast Board also has small fan mounted in front of it!
Nov 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
Samsung DLP TV, no picture, has sound
Try replacing the ballast next. Its the small circuit board directly underneath the lamp housing. You can access it through the lamp door. If the ballast is overheating or has a leaking capacitor, the tv won't stay lit for more than a minute or two.
Mar 12, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-P5063W 50" Rear Projection HDTV Logo
680 people viewed this question
Henry  Thomas
Henry Thomas
