Question about Polaroid Cameras
Turn camera on, lens comes out then everthing goes black and nothing works but the power button. it will yurn off and on and thats it. tried new battery and memory cards but it still not working, can you help me please?
    President:
  • 2,761 Answers
It may be something more serious, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion buildups may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment, clean the contacts at both ends of the batteries, and reinstall them in the camera. Assuming that the batteries are fresh/fully charged, this takes care of about 90% of the power-up problems. I hope it works for you.
Posted on Sep 07, 2009
WB610 Camera buttons & lens aren't working as they should?
As soon as the camera is switched on, the lens barrel will come out. Everything should be ready to shoot pictures. If it is not responding to the buttons, you could try to remove the battery for a few moments. It will cause the camera, to start from scratch. Call it a cold boot. But then after switching on, it should respond normal, like you used to work with it. If it stays frozen, visit your dealer or contact a Samsung certified repair centre.
Mar 10, 2015 | Samsung WB610 Digital Camera Black
Camera lens is stuck in out position, but screen is not on, beeps three times when i push the on/off button
This may help: connect the camera with the charging cord.
press and hold the ON/OFF button and the PLAY button.
(the one that allows you to see the pictures you just took).
hold them until the light on the charger cord starts flashing and then the screen turns on and the lens retracts.
Mar 16, 2017 | Samsung L100 Digital Camera
Turn camera on, lens comes out, goes back in ,and says lens error.
try these fixes
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable nimh 2500mah or better) and turn the camera on. If using rechargeables, and they're more than a year old, consider purchasing new rechargeable batteries as they may not be providing sufficient power to startup the camera. If new batteries didn't work, try pressing and holding the 'Function' or OK button while turning the camera on.
2.If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
3.Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
4.Insert the cameras audio/video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fix 3 as a means to provide extra power to help to this fix. Reinsert the cable only after tapping the camera.
Feb 07, 2011 | Nikon Coolpix S3000 Digital Camera
Screen is black for photo taking
Not really a solution, but I think you have the same problem I do. I believe that the shutter is sticking. Mine will work for one shot every 3 or 5 power cycles (turn it off and on again)
Oct 16, 2008 | Olympus FE-210 Digital Camera
Nikon D70 will not power on after the lens was changed~
EDAWinc,
Is this a new or different style lens? You may not have it all the way on and aligned - try removing it again. Just remember to always turn off the camera before removing the lens or the SD card. Malfunctions are sure to follow if that happens. Try resetting the camera by holding down the two buttons on the top with the green dots for longer than 2 seconds (that works with the D80) The camera will not come on if the lens is not "on".
randy320sgi
Sep 29, 2008 | Nikon D70s Digital Camera
Camera power problems?
It's not the battery. It turned out to be a memory card problem.
I took out my old memory card and put in a new one. It started working properly after that.
Sep 17, 2008 | Fuji FinePix J10 Digital Camera
Kodak Z1285 Won't Turn On?
HAd exactly the same issue! You turn on the camera, lense comes out then the screen goes black (turns off)
The blue light stays on and the only way to get it to turn off is to take out the batteries.
Next time you turn on the device, the blue light comes on and the green led flashes, sometimes it powers down and other times the blue light stays on but you have no screen still. The lense stays out.
I tried the "tap" it approach and it now works fine! My suggestion has always been, if it don't work, kick it!! why didn't I try this with this camera firstly instead of trying all sorts of different button combinations to see if there was some sort of hard reset for it?
Thanks for the advice everyone and happy snapping!! :)
Jul 28, 2008 | Kodak EASYSHARE Z1285 Digital Camera
Used FE-170 hardly powering on.
The lens need to be replaced or repaired. It is not fully extending. It may be that one or more of the plastic gears or plastic rods that hold the gears in place, are broken. I repaired two plastic rods in my lens, by drilling holes for new plastic rods,(I cut plastic rods from a plastic toilet bowl chain!!! It fit inside the gears perfectly), and super glue the rods in place. Replaced gears, put camera back together and BAM in worked! Nothing like a perfectly working refurbished rig job. Camera takes great pictures to this day.
May 10, 2008 | Olympus FE-170 Digital Camera
Cameras Logo
35 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
