Question about Averatec Tablets & eReaders
New owner /auctioned to me w/no password
Averatech 6200 10 2004 model year. How do I get it to reboot my win xp program?
0 characters
1 Points
Im locked out of tablet because forgot password. how can i reset or reboot?
Go online and look up ''password lockout'' and you will find free programs to solve your problem. WARNING: Do a virus scan with a (not free) virus scanner before opening the program. Otherwise, _buy_ a program if you cannot be certain of trusting the source.
May 18, 2015 | Tablets & eReaders
Was given a samsung ipad. old owner has password on it. how do I get into this tablet?
Samsung does not make iPads. Apple makes iPads. Is your device a Samsung tablet?
If it is, you can reset the device to factory settings - as if you had just purchased it new and pulled it out of the box. First: power off the tablet by holding the power button down until the screen turns off. This will take a few seconds.
Once it is powered off, press the Volume Up and Power buttons at the same time and hold them. Once you see the Samsung image come on the screen release the power button, but keep holding the Volume Up button. This will boot you into Recovery Mode.
Once the Recovery Mode menu shows on the screen you can release the Volume Up button. Now use the Volume Up and Volume Down buttons to highlight your choice from the menu. When you have highlighted the Factory Reset option, press the power button to choose that option and follow the on-screen instructions. The reset won't take long - a minute or two. Leave the tablet alone until it says that the reset is complete. Once it is complete use the Volume Up and Down buttons to choose the Reboot or Restart option. That will reboot your tablet. Don't hold any power or volume buttons while it boots. This will take a little longer than a normal boot up. Once it comes up, the tablet will no longer have any password on it and it will be as if it were brand new.
Jan 11, 2014 | Samsung Tablets & eReaders
Hi I have a toshiba portege m750 and my little brother was using it and I have decided to use it for college but the only thing is he cannot remember I was just wondering how would I go about changing the...
You can set a user password from inside Windows. From the configuration panel look for an icon that represents two persons and click on it. Follow instructions on setting a user password.
You can also set a password on boot but you have to be careful: If you forget it you cannot open the tablet to remove the password. You will need to take the computer to a Toshiba Certified Service Center.
To set the password on boot you can use the BIOS SetUp configuration or a Toshiba Windows applications (HRWset).
For Windows XP tablet PC edition 2005
If you have the CrossMenu application you can run the HRWsetup from there. You can also go to All programs, Toshiba Utilities and look for HRWSetUp.
For Windows Vista or Windows 7, the name of the application may be Toshiba Security Assist.
Be very careful. You must not lose the password
Jul 30, 2011 | Toshiba Portege M700-S7002 Tablet PC
I installed windows xp on my toshiba tecra m4. How stylus pen works?
Toshiba Tecra M4-S435 is Tablet PC. Windows XP (Profession) has no option of touch screen.
In order to use the feature, you need to install Windows XP Tablet PC Edition or you may install Windows 7, which supports this feature and you would definately be able to use stylus and touch screen, as I have installed Windows 7 and its working fine with all the drivers etc.
Hope it helps! Good Luck!
Apr 23, 2011 | Toshiba Tecra M4-S435 Tablet PC
Cannot access windows forgot password. I have an old work tablet and forgot my password for windows so I can get to my homescreen. Help
try this link:
If you have lost windows password, the best thing for you is creating a password reset disk.Actually,when you add a password to your pc,the first thing you should do is creating a disk in case you lost the password.But how to make a password reset disk after you have lost the password ? Follow these
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Key
Then let's begin
Step 1.Login to a PC which can link to internet,Download and install the program from in that PC
Step 2.Run the program and burn to CD/DVD OR USB flash drive
Step 3.Turn to your locked PC,insert the newly create CD or USB to your drive.Reboot the Computer and then follow the instructions,it is very easy to use.
Lost user password in XP with networking set-up on HP
The best way to do this is using the Offline NT Password & Registry editor.
You can download it at the following link:
This utility will enable you to reset the password of any user that has a valid (local) account on your Windows NT/2k/XP/Vista etc. system.
The link above includes some directions on how to use this utility.
Nov 17, 2010 | Fujitsu Stylistic ST4120P Tablet PC
Lost password and admin password. Need to reinstall Windows XP, but even after change boot order, the netbook keeps launching from the harddrive. How do I get around this and reformat/reinstall XP so that...
in win XP Go to the others computer and creat the same login as you had it in you laptop or desktop
after creating the user account in control panel
and then in the User account in control panel..
click your user id and
then click forgotten password and make a recovery disk and run it in the laptop it will clear the pass word
Sep 17, 2009 | Fujitsu LifeBook P1120 Tablet PC
I bought this computer at a garage sale and it is set up to log on by pressing ctl,alt,delet but I don't have the password is there any way around this
Try this:At startup, before you get the Windows splash screen,hit the F8 key to see if you can start in safe mode. If you can, the password for administrator may not have been set, in which case you can log on without entering one.Otherwise, you'll have to do a reinstall of Windows or, when starting the reinstall, when the computer says it's loading drivers, etc, you can press CTRL F10 and that should get you to the screen where you can see the passwords. Here's a link:
Jun 10, 2009 | Toshiba Portege 3505 Tablet PC
Win XP on Fujitsu stylistic lt c-500
Ok... after much slaving, trial and error, and just plain getting frustrated I finally figured out how to install XP on a Fujitsu Stylistic LT c-500 with EVERYTHING working!! The installation is difficult and time consuming but well worth it. Getting XP on the blasted thing is part of the difficult uphill battle... but Mr. Mark Rehorst does a wonderful job of explaining it here. Follow the directions carefully keeping in mind that you MUST have the cd-key for the EXACT CD you use... and that to install XP and get everything to work you really need at least a 20gb hdd and 256mb ram. Without those your system will be slow. Next once XP is up and 'running' you'll notice that your touchscreen is not working. Download the CIC XPen off of the Fujitsu support site... now here comes the interesting part. Unpack the driver to C:\Drivers\Pen once you've unpacked it find the file called fujpen.inf open it in notepad to edit it. You will see:
[ControlFlags] ExcludeFromSelect=*FUJ02B6
Make sure the last digit is 6 in that string... this is saying to exclude that model in the driver. If it's anything other than a 6 change it to a 6. Now then... further down you'll see:
[FPC.Mfg] %FPC.DeviceDesc0% = pendrv, *FUJ02B6
Now... remember what I said about the 6 above? Yeah... the driver is fighting with itself, help it out and change the last number to a 7. Save the .inf file. Go to your device manager right click on the unknown device and update it with the modified file... and presto changeo your touchscreen works!! Now for the other unknown device in there, it is called the Fujitsu FUJ02B1 Device Driver. Unfortunately Fujitsu dosen't include a driver for this... but if you google search it you should come across and they'll have it. You will have to sit through a few ads to get it... but wow... the world that is unlocked by xp on this tiny little pad is amazing! Good luck!
Jul 24, 2008 | Fujitsu Stylistic LT C-500 Tablet PC
Can't install XP
It could be bad RAM, but it could also be drive error.
Try running chckdsk.exe
If the drive is ok, try copying the win xp cd to the HD and try to install from the HD
First, you need to copy your Windows XP Setup CD contents to your harddrive. I recommend saving the xp install files/folders to a separate partition than where you're going to install xp to (ie. have setup files at d:\winxp\ and then install xp to c:\ drive)
restart your computer with the win 98 boot disk
at the command prompt change to the drive with the xp files
ie. cd d:\winxp\i386\
type winnt to start installing
install as usual
Dec 28, 2007 | ViewSonic Tablet PC V1100
Tablets & eReaders Logo
16 people viewed this question
Top Averatec Tablets & eReaders Experts
Arcadian Duran
Arcadian Duran
Are you an Averatec Tablet and eReader Expert? Answer questions, earn points and help others
