Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Kenmore elite utlrawash model 665 17469300 won't clean dishes on top rack. It appears no water is getting to the top rack.
5 Suggested Answers
  • 10865 Answers
SOURCE: Dishes on top rack don't get clean
The following suggestions will greatly enhance the ability of your dishwasher to clean all of the dishes thoroughly:
1. Rinse all of the food off of the dishes before you put them in the dishwasher.
2. Run the hot water into the sink until it is as hot as it gets before you start the dishwasher.
3. Do not pack the dishes into the dishwasher, just put in a reasonable number without crowding or stacking them on either shelf.
4. Pull the top shelf all the way out to be sure that the water connection at the rear of the top shelf is connected. Sometimes, this connector comes disconnected preventing the water from entering the top spray assembly.
THese things should make a huge difference.
Good luck with this and please rate my answer. Thanks. Joe
Posted on Feb 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite 665-16959000 dishwasher - soap door
It appears your dispenser wax switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: My model # 665-16264402, Kenmore Elite. It's not
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Posted on Feb 22, 2011
heatman101
  • 43501 Answers
SOURCE: kenmore elite model 665 17263402 The
Dishwasher
How to Buy
heatman101
Posted on Feb 24, 2011
On my Kenmore model 665.13489K900, it does not clean well and appears to have a problem with getting or circulating water inside to all areas, especially the top shelf.
Check the center wash arm assembly. If the center wash arm isn't getting water, all of the dishes in the upper rack will come out dirty. Check to be sure the center wash arm assembly is mating properly with the water supply nozzle in the back of the dishwasher. Also check to be sure the little holes in the center wash arm aren't clogged or blocked. * Run empty cycle using vinegar and baking soda lime scale problem will resolve.
Nov 13, 2013 | Kenmore 15912 Built-in Dishwasher
Kenmore Elite dishwasher won't clean and leaves white film
CHANCES ARE YOUR WATER TEMP IS TOO COOL and the 2nd
PROBLEM IS VERY HARD WATER THAT IS CAUSING THE WHITE RESIDUE. RAISE THE TEMP ON HOUSEHOLD WATER TO 140 F AND ADD SOME SALT TO THE WASH CYCLE. LASTLY USE A LIQUID DETERGENT LIKE LIQUID CASCADE.
Oct 13, 2012 | Kenmore Dishwashers
Kenmore 3380957 rev a won't get dishes clean
Make sure that that upper arm is free to turn. Check it while you have dished installed, because sometimes, dishes on the lower rack may stick up too high and hit it. Otherwise, check the back of the water-supply tube attached to that upper rack.... Is it lining up with the water feed port or hole at the backof the dishwasher? Is there a gasket that is either ripped or missing? And check that wash arm carefully.... Might it be split or bent? Are the holes on the bottom clear? (Those holes are usually angled to push the arm around; if they are clogged, the arm won't rotate.)
Mar 15, 2012 | Kenmore Dishwashers
Dishes not clean?
Check all the water jet orfices in the moving arm. Try cleaning without loading the top rack.
If cleans well, mostly the upper rack dishes not arranged properly.
I hope you are using the main wash detergents. Rinse aid is just to remove the stains after the main wash rinse.
Apr 01, 2010 | Dishwashers
Kenmore Dishwasher not cleaning dishes - especially top rack.
put a pump kit in the dishwasher..and the water coming up is a house drain problem
Aug 06, 2009 | Kenmore Elite 45986 Front Load Washer
The upper sprayarm flows water but does not turn. Therefore dishes in upper rack are not geting cleaned.
i have a kenmore elite dishwasher model 665.16059400, i need a lower spray arm nut, nobody can find this part, i've been to sears and also to their on line parts department 3 times and have come up empty, the last time i was assured that the nut would be included with a new spray arm if i ordered one, it was not,i know the spray arm was made by whirlpool, is there anyone out there who knows the solution to this simple problem? does whirlpool have a cross referance model number i can use to find this part
Apr 29, 2009 | Dishwashers
Feb 03, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
The top rack on my kenmore dishwasher is not cleaning the dishes!
check the inlet strainer at the bottom of the unit - and also the nozzles on the top are for clogs/sediment.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 16, 2009 | Kenmore Elite 45986 Front Load Washer
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
42 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
