Question about Goodman GMS90703BXA Heater
It will only cycle once and then it shuts off.. i have to turn off and then back on through the thermostat to get it it through another cycle , the system is three years old. i have tried two other thermostats
  • corchado41 Sep 12, 2009
    Thank you for responding. I tried what you suggested and you are right. It blinked 4 times and the code says "open high limit". Any idea as to what that means?? I do notice that the initial cycle seems long.
  • 1,420 Answers
Your furnace has a diagnostic light in the unit. Look for a small see-thru window either on the top panel or the bottom panel. Look for a blinking light. Record the number of blinks. Now remove the bottom panel and look at the wiring diagram. There will be a error code list explaining what the blinks represent. If you open the panel prior to looking thru the window, you will erase the code. Changing the thermostat is not the solution. Good Luck.
Posted on Sep 09, 2009
Testimonial: "Although I have yet to fix he problem, your suggestion has given me a direction and i dont feel so lost. Thank you!!"
  • Chandler Ede
    Chandler Ede Sep 12, 2009
    An open limit switch could be the little thermo-disc found over the flame box. It will have two wires going to it. If you connect the two wires together, the unit should fire. This procedure is to just test the thermo-disc, not to run it this way. You may have others in your furnace as well. Follow the wiring diagram to find the others. Good Luck! Glad to help.
Knot heating
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the therMOSTAT
Mar 04, 2015 | Dryers
How to reset the thermostat to shut off after 2 degrees/CT87B-4008?
on these thermostats remove the outer ring cover and in the lower right side you will see a slide adjustment. move it i believe left for closer cycles and right for longer cycles. it should be 2* on either side of set point. remember that the fan is not furnace shut off.and turning back and forth will not tell you anything. just set it and see how it works then change it again if you need to
Oct 13, 2014 | Honeywell CT87B ROUND HEATING&COOLING...
My danby dryer keeps shutting off and turning on and the clothes take forever to dry
GOD IS STILL GOOD !!!!
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Sep 09, 2014 | Danby DCD5505W Electric Dryer
My dryer works fine...heats tumbles the timer just doesnt advance once it starts therefore the dryer wont turn off on its own
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 11, 2014 | Whirlpool LEB6200 Electric Dryer
Not heating motor turns there is no heat
Apr 10, 2014 | Frigidaire FER641FS Electric Dryer
I have an upright Premium larder fridge,about 18/12 old. It keeps freezing everything. We have 'defrosted' it more than once but it keeps happening. Any ideas?
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 03, 2009 | Liebherr KDPes 3142 Premium
Gas heater shuts off & won't come back on
sounds like the thermostat replaceing it should help you could try cleaning the old one they can get dust it them
Feb 25, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Thermostate problem
leave off for 24hrs to completly defrost, turn back on allshould work. Regards Advisor
Aug 18, 2007 | Maytag MFC2061HES Stainless Steel French...
Goodman GMS90703BXA Heater Logo
167 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
