Question about Fedders Fans Indoor Air Quality Electronic Whole House Air Purifier
How tight should a whole house fan belt be? - Fedders Fans Indoor Air Quality Electronic Whole House Air Purifier
  • 252 Answers
Just tight enough that it does not squeel or squeek on start, any tighter and you put undue stress on the bearings. (Approx 1/2" deflection on the longest span)
Posted on Sep 08, 2009
I am rebuilding a 6.4 powerstroke and i can only turn the motor about 60°. Could the rocker arms be too tight?
es loosen all rocker arms very loose and try to spin if it still does not spin and you may have the timing off
Nov 21, 2014 | aFe 2008 Ford F-250 - 6.4L Powerstroke -...
Where do I register my Kenmore product on line
try going to the Kenmore website:
www.kenmore.com/customer-care/
Nov 15, 2014 | Kenmore Whole House Humidifier Replacement...
Why will my fan not work the lights both come on.
It could be a bad connection or corrosion on the wiring connectors. I would suggest that you unplug the electrical cord to inspect the fan motor connectors, they should be tight and free of debris. If you had a meter you could check for voltage at fan motor but would have to plug in to power to do so so be very careful not to touch other contacts while performing the check. If you are not comfortable or experienced with electrical work I suggest that you take the unit in for repair or buy a new unit which may be best depending on the age of the unit. The fan motor is likely bad or it could be a switch./Difficult to say without properly diagnosing.
Oct 28, 2014 | Lasko Humidifier Model 1128 With 2 Filters
Ep9r 500 speed button won't work keeps flashing f
The water level sensor fell into the fan. Unplug the humidifier from the wall, stick your hand in between the fan blade and locate the sensor. It is a small black rectangular piece the size of a nickel but rectangular and 3 nickels thick. It also has a 2 inch stem sticking out of that clicks back and forth when you push it. Stick the sensor back into the sensor whole and the flashing f will go away and the humidifier will come on again.
Feb 22, 2014 | Essick Air Whole House Digital Humidifier...
The belt won't stay on! I put it onto the silver piece that spins...as soon as I turn it on to test it it comes off...the brush doesn't spin...Am I missing a part??
Cathy
The brush roller only sits one way and must b free rotating not jammed up if roller is tight to turn disassemble and clean it when u put it back after u have put belt on turn by hand to see if it stays on, if it does ok done .
Cathy theirs ,
only to things that will cause this the brush roller running out of square, or jammed up and makes the belt jump of.
Oct 18, 2013 | Dirt Devil 0100 Handheld Bagless Vacuum...
My Fan is somehow loose and gets jammed. I don't see how the fan metal bracket fastens to anything and therefore is sort of floating loose and the blade keeps rubbing up against the plastic...
Fan should not be rubbing up against anything. I don't think the fan is secured properly to the motor shaft. Tighten down the metal clip that holds the fan onto the shaft. Make sure it's not back too far.
Jul 14, 2011 | Ecoquest Breeze AT Living Air Purifier
No Medium Fan Speed
sounds like ur medium speed has gone out
Feb 20, 2010 | Air Purifiers
Evcon Model EB15B Elements glow red for 3 minutes then cycles off. Fan stays off during the cycles. Manual fan switch will turn on the fan. Assistance requested, cls
the fan has to be on while the strips are on. knowing that the fan comes on when you switch it to on at the thermostat but not when your just calling for heat indicates that you have somting wrong with the heating relay or the fan isnt wired properly to the heating relay (posssibly a new motor during the summer) or just a bad relay. when the first stage heat comes on it should also energize the motor the first to come on is also the last to shut off which will make sure the fan runs during the whole heating cycle. until you remedy this you can run the heat just keep the fan switch set to on so its running, this will not hurt anything
Nov 24, 2009 | Air Purifiers
Clean fan area
NOTE:It is easier to remove the motor when the upper housing is still sitting on top of the lower housing unit.
  1. Turn the power off by unplugging the unit.
  2. Next to the speed directions buttons there are thumb tabs. Press the thumb tabs so that they pop up and unlock the upper housing flaps. a tumb tab on
  3. The four flaps should then drop down like the peddles of a flower.
  4. Grab the center of the motor and lift straight up, be careful when pulling the power chord.
  5. The motor, fan and gear assembly should not be seperated from the rest of the unit.
This will let you clean with vinegar and water.
Great product. Germany design at its best
Oct 30, 2008 | Venta - Airwasher LW44 Air Purifier
Fedders Fans Indoor Air Quality Electronic Whole House Air Purifier Logo
112 people viewed this question
Top Fedders Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Fedders Air Purifier Expert? Answer questions, earn points and help others
