Question about Maytag Performa PAV2200
I think the noise is coming from the blower - I took a lot of lint from there and the part that turns seems "unbalanced" And that is the noise I am hearing.
    President:
  • 1,776 Answers
Yes. A common problem is the center hole loses it's "D" shape and turns on the shaft. You may need a new blower wheel. I will attach a photo for reference. Hope this helped and best wishes.
Posted on Sep 07, 2009
Testimonial: "Thank you for your quick and accurate reply!"
Forgot lint trap, dryer making noise immediately after. Cleaned vent and blower wheel and housing- still making noise. What else could it be??
If its like a grateing metal on metal it sounds like the rear bearing has worn through which is quite common.
hope this helps a bit
Jun 24, 2016 | Dryers
Beko DRVS6W tumble dryer squeaks when the drum comes to a halt
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
May 22, 2015 | Beko DSV64W White Vented Tumble Dryer 6...
Hi, My maytag bravos dryer is one year and 2 months old. Suddenly it has stopped drying the clothes, it takes forever to dry a load and clothes are very warm and wet, lots of steam in the dryer, also the...
Sounds like the exhaust fan is not working. There's an electric blower at the back of the unit that forces air out through the exhaust vent. Unplug the unit, pull the vent off the back, and see if you can reach in and touch the fan blades and make them move. If it won't move something is probably caught in there. You may need to take off the back of the unit and remove the housing cover to the fan assembly in order to really tell what's going on, but it sounds like your fan has an obstruction. It could also be that the fan motor is fried but that seems less likely. Remember to have the unit unplugged, there's some dangerous voltage inside.
Jan 03, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Whirlpool ywed5800 dryer has loud noise coming from flint trap, almost a motor noise
Hello- If you take out the lint filter can you see anything down inside? It seems like there may be something hitting the blower wheel or the internal ducting may have come loose... You may have to have someone out the take it apart and try to locate the problem. Best regards.
Sep 26, 2010 | Whirlpool LER4634J Electric Dryer
When I turn on my dryer on it gives a rattling/vibrating noise.
There maybe a lot of lont build up in the blower wheel housing. Take off bottom panel and take apart the blower wheel house and check for any lint build up....if it check ok, your drum rollers maybe worn....try checkin the blower wheel housing...hope this helps
Aug 04, 2009 | LG DLE2516 Electric Dryer
My dyer is not turning. it makes a noise like the motor is trying to turn but does not have enough to do it. my husband took it apart, belt seems to be ok, but when he took off the top he can spin the drum...
Either the motor windings have too much electrical resistance or the start windings are shot. Replace the motor and install a new belt while your at it.
TIP OF THE DAY--To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer.
:?) DRRXR
Jan 31, 2009 | Dryers
Can't remove dryer blower wheel
I would start by taking off the top and checking the belt to see if part of it tore and is hitting the inside of the cabinet. I have not found a real good way to get the blowers out without having to break them sometimes. the part of the blower that you have to hold is access through the front behind the motor. problem is when you turn the motor shaft, the wrench strips out on the blower, then you have to break them, but unless you need a new motor, it should not have to come off.
Jan 27, 2009 | Whirlpool Dryers
My dryer will not come on at all
The duct fuse is probably blown. Mounted on the rear of the dryer on the blower housing. Make sure you get the lint out the dryer or you will be replacing this one a lot.5102b6e.jpg
Jan 19, 2009 | Roper REX3614KW Electric Dryer
Frigidaire dryer, lots of lint getting past screen.
Here is a link to an exploded view and parts list for your dryer. http://www.pcappliancerepair.com/model-display.php
If you are certain that the filter is not compromised or damaged and is properly seated into the housing , you may have a problem with the housing itself whereby lint is getting into the blower thru a break in that housing.. I would examine that area for damage.. and make sure when you reinsert the filter, it is seated all the way down.. Hope this helps you... BTW: over time, it is not unusual for lint to build up in the duct since some of that lint is smaller than the filter media and will work its way thru.. If you are getting that degree of lint build up very quickly then you may have a problem as mentioned above..
Regards,
Rick
Dec 03, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Have a "finshing" noise even when drum stops a turn
I had a similar problem and found a screw had backed out on one of the turning paddles inside the drum but the screw was on the under side , and could reach it through the access door , just had to turn the drum by hand till the screw was in sight.
just turn the drum inside by the paddles and shake them to make sure they are tight , thats how i found my problem and noise
good luck hope this helps , wayne t
Jul 14, 2008 | Dryers
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
