How do I remove front panel of my Admiral Capacity Plus washer?
How do I remove the front panel of my Admiral Capacity Plus washer. It is approx. 10 years old. It looks like it should just pop off but I dont know how hard to pry it without bending something.
Thanks
  • 15,935 Answers
The front panel does not come off.
To access the inside - there are a few screw on the back - then the shroud is removed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Our capacity plus Admiral washing machine has a problem with the mixing valve. How do we get to it? It was fixed once before. We don't know how to get into back of washer.
Take top two screws out of back. Lift top at back control panel. Pull out brackets.Take out screw securing mixing valve. Pull mixing valve up through top. Unhook hose and 4 wires and WA LA! There you are.
Nov 01, 2009 | Admiral AW22 Top Load Washer
Walking ge super capacity plus washer
the drum straps are probebly broken just remove the front then remove the 2 1\4 inch screws that hold the top on remove the top the straps are located on top of the tub they are black rubber
Aug 28, 2009 | GE WBSR3140DW Top Load Washer
Sometimes does not spin enough to wring out water from clothes.
The spin cycle should be on a timer,and shouldn't be able to change how long it spins.The same timer that controls all the cycles of your washer.Your pump may be trying to go out,and isn't removing the water fast enough.This will keep water in the tub,and the normal spin cycle isn't long enough to let the pump get the job done.Another problem might be a clog in your drain hose.Another problem could be the drain hose is set to high above the pump,and the pump can't push it up that high (shouldn't be a problem if you are using the hose that came with the washer,and not extending it with another hose or something.)
Jun 05, 2009 | Admiral AW22 Top Load Washer
My Admiral Washing Machine (5 years old) is leaking.
Isolate the machine, use a knife or thin bladed tool and insert between the front panel and the top panel approx 4" from each side to release the clips, the top should lift up,2 screws at the top inside will release the front panel for a better view.
Apr 11, 2009 | Admiral AW22 Top Load Washer
My admiral capacity plus washer does not stop filling with water. What would the problem be
I had this happen last year to mine. Check the hose that goes to water level adjustment switch. It may have a hole or crack in it. It may be small and hard to find but if there are any leaks in this hose the switch cannot sense the water level because it works on pressure through the hose to the diaphragm on the switch. You will need to remove the top panel of the washer to access this. I was able to replace the hose with some I had on hand. Saved me big $$$!
Jan 25, 2009 | Admiral AAV7000A
Admiral washer lnc6160b71
If you mean the inner drum - remove the agitator, pull off the sofetener cup and remove the 15mm bolt down inside to remove agitator, then secure inner drum to center bearing.
If you mean the outer drum, check the holding down springs visually, remove the front panel by inserting a flat blade approx 4" from each side at the front to release clips, then remove 2 small bolts to remove front panel.
Also check and replace drive belt, tilt machine backwards to gain access underneath.
Jul 15, 2008 | Admiral AW22 Top Load Washer
Admiral Leaking
Possibly rinsing with cold water, washing with hot.
Check inlet valves for leaks, especially cold (rinse)
Lift the top panel by inserting a flat blade approx 4" from each side at the front to release clips, then top will hinge backwards.
You can see the valves at the rear behind the drum..
You can run the machine with top lifted to see any more leaks.
Also remove front panel via 2 small screws to gain better view.
Jul 12, 2008 | Admiral AW22 Top Load Washer
My admiral super capacity washing machine
remove the front panel and check the securing springs at the bottom, probably one has snapped, replace the set.
Check for dust - evidence that the snubber washer has worn also
Jun 02, 2008 | Admiral AW22 Top Load Washer
Admiral top load Admiral washer
Could be the motor or belt, tilt the machine backwards and look underneath to inspect the belt, try turning by hand see if everything is free (will only freely turn in one direction only as brake acts in one direction). Check motor for rotation, remove the front panel for a look, to remove the front panel, at the seam between the front panel and lid push in a flat knife or screwdriver approx 4" in at each side to release the clips (one at each side). this will allow you to lift the top and then remove the two front panel fixing bolts 7-8mm to remove the front panel.
Mar 24, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
765 people viewed this question
Top Washing Machines Experts
