Question about RCA Universal Remote Control
Want to know how to program a rca rcr3273n remote control thats got no code search button
  • RCA Master
  • 5,568 Answers
If you have a later set and an older remote, it will not have a compatible code.
If you are just missing the codes for your remote, try here:
Some RCA remote codes
Posted on Sep 07, 2009
Need Owner's Manual RCA Model RP 7977A Boombox AM/FM Stereo Radio/Cassette Recorder Compact Disc
Posted on Aug 05, 2010
What to use a rca universal remote butdont know the code
3 Ways to Program an RCA Universal Remote - wikiHow
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowJump to Remotes Without "Code Search" Button - Using Brand Code Search ... (for example, many stereos don't support remotes). ... in this article to program the remote,but ... If you know the exact code that you need ...
Program an RCA Universal Remote Without a "Code Search"
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a "code ...Don't let go of the TV button. ... Please tell us everything you know about.
Programming the RCA RCRN04GR Universal Remote
Dec 25, 2015 | RCA Televison & Video
What to use a rca universal remote but i dont know the code
2 Easy Ways to Program an RCA Universal Remote Us
I have a World tv with an rca remote(RCR3273N). Please, help find a code
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Apr 18, 2012 | RCA Universal Remote Control
Prgram old RCA removte
I also have an early RCA universal remote with the number 97P04730 stamped on the battery cover. I do know if that is the part number for the remote. There are buttons labelled TV and VCR, presumably to select which device the buttons will work for. This remote has a "search" button, but no "code search" button that is found on later RCA remotes. I have spend several hours searching the net for any information on this device. The only thing I found was a post that claimed this early remote is programmed by pressing and holding the device button (TV or VCR) and simultaneously entering the device code. Because this is a very old remote, it probably uses 3 digit codes. There are several places that list RCA 3 digit remote codes. I have tried to program mine this way, but I have not been successful. Possibly my remote is not working correctly, but it is putting out IR.
Jan 29, 2012 | RCA Universal Remote Control
I have a RCA universal remote control, RCR3273N 1/RCR3373N, and I use it to record shows on my VCR, which I have programmed, but I want to change the program and the Remote does not have a...
No,just take out the battery for it sourced of power like for 24 hours the old codes will erase itself out of the universal remote memory or just read and follow ur instructional manual program in a new codes the old one will automaticly will earase itself.
Aug 10, 2011 | RCA Universal Remote Control
Dont know code # my rca remote rcr3273n or the sequence to program it for a rca tv
Make sure the device is on. Hold down the tv (or whichever device your trying to program) button first and then the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and keep pressing slowly letting it flash until the device turns off. Then press the stop button...and it is programmed.
Nov 26, 2010 | RCA RCR311B Remote Control
I HAVE A UNIVERSAL REMOTE.MODEL #RCR3273N BUT I HAVE A LG FLAT SCREEN T.V.COULD YOU PLEASE HELP WITH THE CODE?THANK YOU. JULIELEON.0003@YAHOO.COM
Hi welcome to fixya the codes for the LG tv are .
LG................................. 11423, 10017, 11265, 10178, 10856, 11178
If you need the manual or the code list you can get it on the links below.
http://audiovox2.info/docs/common/RCR3273N/RCR3273N_OTHER_CL.pdf
http://audiovox2.info/docs/common/RCR3273N/RCR3273N_OM.pdf
Good luck
Nov 12, 2010 | RCA Universal Remote Control
I have an RCA rcr3273n and it does not have the code search button, what button do I use to sync it with my TV?
These are the steps for the auto code search function for your remote.
  • Manually turn on the device you want to control.
  • Press and hold the device key you want to program. While you’re holding down the device key, use your other hand to press and hold the remote’s POWER key at the same time.
  • Wait until the remote’s indicator comes on and stays on. Then release both keys.
  • Point the remote directly at the front panel of the device you want to control. Press PLAY on the remote and wait 5 seconds. The remote is testing a batch of 10 codes on your device.
  • Did your device turn off?
  • YES: Go to step 5.
  • NO: Press PLAY again. The remote tests the next batch of 10 codes. Keep pressing PLAY every 5 seconds until your device turns off.
  • When your device turns off, press the REVERSE key on the remote and wait at least 2 seconds. The remote tries the last of the previous ten codes.
  • Did your device turn on?
  • YES: Press the STOP key. You’re done!
  • NO: Press REVERSE again. The remote tests the next code in the batch.
  • Keep pressing REVERSE every 2 seconds until your device turns back on. When it does, press STOP.
Because there are a couple other methods you can use to search for codes I included a link to the manual for your remote.
Hope this helps.
http://audiovox2.info/docs/rca_acc/man/RCR3273N_DOC_OM.PDF
Oct 17, 2009 | Televison & Video
Televison & Video Logo
6,729 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
