Question about Samsung Televison & Video
My Samsung DVD-P241 won't turn on. - Samsung Televison & Video
MNfisherman
  • 11896 Answers
SOURCE: region hack code for samsung dvd-p241
You can try to use this tip, which is generally used for all these Samsung models: DVD-709,DVD-809,DVD-909,DVD-511,DVD-611,DVD-615,DVD-811,DVD-M105,DVD-M105 E,DVD-M108,DVD-M203,DVD-M204,DVD-M205,DVD-M305,DVD-M405,DVD-P233,DVD-V530. I think that P-241 is about the same of P-233, which is unlocked with this tip. You can try, and then answer me if worked.
1. Make sure that there is no disc in the tray and switch on the player.
2. Cold start the player, by holding down the PLAY and STOP buttons on the player.
3. You should see a set of language options. Release the PLAY and STOP buttons.
4. Select your language.
5. Press REPEAT then the following codes for the required region the player is already set to (region you bought the player in) do not confuse this with the A-B button:
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
("E series M105", M205 and M305 users try: 57538)
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
6. A code will appear, indicating the region setting of your player.
7. Press 9 for region-free, or 1 for region 1, 2 for region 2, etc.
8. Press OPEN/CLOSE on the Player to open the disc tray. You may need to push the tray shut rather than use the player button, in order for the region not to be changed to 4 (M203).
9. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified. If the player halts on the FBI Warnings, press Forward Search x2 or faster.
On some models, you will have the ability to disable Macrovision, but you will have to turn off the Quasi-PAL option and set the SCART output type to Video rather than RGB.
Posted on Jul 09, 2009
  • 133 Answers
SOURCE: new lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
Posted on Jun 04, 2010
SOURCE: can't open dvd drawer
My daughter put a second dvd on top of one already in the drawer and closed the tray, which then would not open. Solution: Unplug player. Remove 3 screws on back of player and remove cover. On the top right is the sliding tray. Over the tray is a plastic "bridge" with a white disk on top. Gently pry up the back of this bridge unit and gently slide out the top dvd. Replace cover and 3 screws holding it. Plug in player and hit Eject, which should now work.
Posted on Dec 21, 2010
eagle338
  • 4889 Answers
SOURCE: what dvd laser lens cleaner
You can use any branded DVD-lens cleaner. I recommend Sony. It is just like a normal DVD except that brushes will pop out to clean the lens when you play it. After the cleaning is complete the sample video file on the DVD will be played indicating that it has been cleaned. Otherwise clean again.
Posted on Apr 04, 2011
homearceo
  • 66 Answers
SOURCE: Dvd is stuck in my
unplug the unit from the wall socket, unscrew to remove the protected cover... ty
Posted on Jun 21, 2011
Testimonial: "I greatly appreciate the advice. I was able to retrieve the DVD, return it and saved on a repair fee. Liz"
I am looking for a manual for a Samsung DVD Model number P241/XAA-B DCan you direct me to where I can get one?
you can download direct on
http://downloadcenter.samsung.com/content/UM/200312/20031230162616265_P241-XAA.pdf
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 19, 2011 | Samsung Cameras
Dvd is stuck in my Samsung dvd player P241. How do I get it out? Tried unplugging it.
Jun 21, 2011 | Samsung Televison & Video
What dvd laser lens cleaner should I use for my Samsung p241 dvd/cd player?
Apr 04, 2011 | Samsung P241
Wont eject dvd
Pull out the power plug leave it out for a while and then put it back in and then hold open/eject button until the DVD player says open/eject let go..the DVD tray should come out.
Please vote if this helps..thankyou!
Aug 13, 2009 | Samsung DVD-P241 DVD Player
Disk drive won't open & lights flash
samsung told me it was defective and to send it in at my own expense. Throw it out and dont buy samsung
Jan 07, 2009 | Samsung DVD-P241 DVD Player
I cant open the dvd tray on my SamsungDVD-P241
turn off unplug ...turn upside down...this may dislodge it disk...gently shake...this may take a few tries
Dec 10, 2008 | Samsung DVD-P241 DVD Player
DVD Freeze-Ups
Sounds like the transverse motor is bad.
Dec 03, 2007 | Samsung DVD-P241 DVD Player
Video on P241 DVD player
replace the bigger IC of the module
Oct 23, 2007 | Samsung DVD-P241 DVD Player
Televison & Video Logo
124 people viewed this question
Jerry Greenberg
Jerry Greenberg
