Question about Brother MFC-465CN InkJet Printer
Printing everything is hooked up but will not print. It doesn't do anything.
Replaced the Magenta cart. and it still doesn't print anything red. I did clean the contacts that HP suggests.
You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
Jul 14, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
!My printer works fine but doesn't print in color. I have checked all the ususal culprits and can't finnd anything wrong, HELP
Check that your Print Preferences is not set to print in greyscale or print only in black.Also you could reset the printer by turning the printer off, unplug printer from outlet, wait awhile,.then plug printer back in and turn printer on.
Nov 15, 2011 | Office Equipment & Supplies
My printer doesn't print word documents (it doesn't print in black, but it does in colour), it prints everything else. I already checked the port (it's USB), changed the cartridge, uninstalled...
try the following
1.power on your peinter
2.while press and hold the power button ,open and close the top cover times.
printer pick the paper and print the test page and alignment pattern for black and color.
if any of the black or color alignment pattern is not print ,then u have to change the cartridge accordingly.
Aug 01, 2011 | HP Deskjet D2360 InkJet Printer
My printer won't print. my computer is hooked up to it, and it doesn't give any error messages. it just doesn't do anything.
Go to Control Panel/Printers. Right click on your printer's name, and hit Print Test Page. If printer prints a page out, then the problem is likely with the software you're using to print - make sure you have selected the right printer in the dropdown. If the printer's name doesn't show in the Printers folder of Control Panel, the driver for it has not been installed. Do so and try again.
Jun 18, 2011 | Lexmark X2670 All-In-One Printer
Epson stylus photo r300 removed print head, flushed out all nozzels with water, dried everything, reasembled everything, including the flat ribbons, two different times. After dozens of times trying to...
If an inkjet printer has not been used for some time and several print head cleaning has been done and it still does not print properly then the nozzles in the print head are blocked.
Inkjet printers need to be used frequently to prevent nozzles blocking with dried ink.
You need to replace the print head to get the printer functioning again.
But these print heads are expensive to replace, it may be better to buy a better and a later model printer for not much more costs.
Feb 24, 2011 | Epson Stylus Photo R300 InkJet Printer
I just bought this printer today and everything is hooked up fine, but it is not printing anything from microsoft word. It does copy and scan. What could be wrong and how should I fix it.
If it's only in Microsoft Word that it's not printing, then you should open up Word, go to File, select Print (the Print menu window or the Print Drop-down menu will open depending on your version) in there make sure there is NOT a "check" next to Print To File and make sure you have the printer you just bought as your Default printer (it should have a Black or Green check mark next to it's icon). Hope this helps!
Dec 14, 2010 | Computers & Internet
Can't seem to get anything to print everything hooked up OKI c3300
Check to see if the toner is finish and also check to see if the papers are correctly place into the printer.If the paper is not push into the printer properly the printer will not be able to grab the paper and you can also clean the print head on the printer. .
Aug 14, 2010 | Oki Electric Industry C3300n Laser Printer
I have not had my printer hooked up to my computer in about 5 months or so. I went to hook it up to my MacBook Pro, and it will not print anything. Can you help?
I have not had my printer hooked up to my lap top. I tried to hook it up to my Windows Vista, and it will not print anything, it has the documents in the print que, but won't print.
Aug 10, 2009 | HP Deskjet 6940 InkJet Printer
Printer won't print in some softwares but will print in others.
Hai
pls reinstall the os and try it will work otherwise there is problem in printer port pls check the setting it will work
Oct 25, 2007 | Computers & Internet
Brother MFC-465CN InkJet Printer Logo
55 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
