Question about Honda 6370C - Parallel Power Kit For EU3000i
EU3000is running rough and idle hunting.
I have cleaned the carb, sparkplug, charged the battery and put in clean fuel. It does not idle smoothly and backfires sometimes. Any other ideas? Is there something wrong electronically?
    Problem Solver:
  • 7 Answers
I'VE SEEN THIS BEFORE ON 1 I REPAIRED IT IS THE INVERTER THAT IS BAD!!! THEY COST ABOUT $600.00 JUST FOR THE INVERTER!!!!
Posted on Sep 10, 2009
  • Durwood
    Durwood Jan 01, 2014
    mine did some rought running then quit all togeter found rotor magnet come in glued took some work , too fix but its runninng now..
1987 Nissan D21 with a Z24 motor: Continuous stalling at idle, runs when choked using a rag or hand, has new plugs, wires, distributor cap, rotor button, fuel pump, will not idle unless choked, i do n
need to clean the idle jet out in the carb. you need to take the carb float chamber apart and you will see 2 copper jets. unscrew one jet at a time and clean them out. screw back firm not to tight. wile open clean the filter out of the main fuel line if its black replace with new one or leave to soak in some white vinegar and brush with a old tooth brush put new seal on float chamber and put back on engine. see if its fine then it should be.
Jan 19, 2014 | Cars & Trucks
I have a 92 dodge dakota I chanhed sparkpluge distibutor and rotor it still has rough idle hessitates and back fires on take off
With the engine running try spraying a couple shots of carb spray into the throttle body. If the idle smooths out then your running lean. The next step is to check fuel pressure, vacuum leaks, and try unplugging the upstream oxygen sensor. It could be stuck rich which would make the computer drive fuel trims lean.
Apr 12, 2013 | 1992 Dodge Dakota
My 2001 dodge carvan se 3.3 will not idle and run very rough
remove the idle air control valve and clean with spray carb cleaner.
Nov 08, 2012 | 2001 Dodge Caravan
Our HMSK 80-110 electric start snowblower starts up right away, but the idling is very rough. It runs very smoothly when it is engaged in snow throwing.
The Tecumseh snow motors are notorious for idling rough. Especially the last few years of production. Most service techs just say "live with it" But there are a couple of things you can do to help.
It is not a carb adjustment issue. It's usually a fuel, clean carb issue.
First, use a premium grade fuel without ethanol and a fuel stabilizer. This will give you the best fuel mix.
Second, Remove the carburetor shield and clean the inside and outside of the carb with carb cleaner. Even though you can't see the carb usually, they do get varnish build up and cleaning it will help some.
Third, Put the recommended amount of fuel system cleaner in the gas. I use Sea Foam brand. Over a tank full or two you will notice a difference in how the engine idles.
Fourth, Use a high quality spark plug and use a new one every year. Make sure the gap is correct.
Good Luck! Feel free to as any other questions you may have. Don't forget to rate this answer!
Jan 14, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Atv will not idle without choke
Carb. needs cleaned, its starving for fuel and by choking it you reduce the air flow and increase the fuel.
Rate my answer witht the thumbs..........Thanks
Dec 03, 2010 | Yamaha RD 250 Motorcycles
4.5hp B&S engine on a bolens mower..won't idle steadily
This is called hunting, your fuel-air ratio is not right. Your carb. jets need cleaned
Sep 02, 2009 | Garden
Bike sat for awhile, runs but doesnt idle very good. cuts out
I would remove and clean the sparkplugs - sounds like one may be fouled.
Aug 18, 2009 | 1994 Yamaha FZR 600
Honda 6370C - Parallel Power Kit For  EU3000i Logo
1,570 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
