Question about Evolis Pebble Color Card Printer
Evolis pebble 3 printer problem
Evolis pebble 3 printer alternately blinks push button on control panel,ribbon light ,cards light and cleaning light blinks one after the other. How can i solve this problem. Cleaning card or normal card is not feeding in the printer
SOURCE: Evolis Peb3le
There is a good chance that your main board is blown out. Depending upon the age of the printer, it may or may not be cost effective to have repaired. If purchased within the past two years as a new unit, your printer would be under warranty and you should contact your dealer to obtain repair authorization.
Hope this is helpful.
Our Evolis representatives can be reached at www.safecardid.com.
Posted on Sep 09, 2008
  • 54 Answers
SOURCE: Evolis Pebble Cleaning Kit
Check if feedr Roller is moving.
Look at backside of printer . There is a card thickness adjustment lever where you feed the cards . Make it positioned at 1 mm.
Posted on May 21, 2008
SOURCE: evolis pebble 3 ribbon problem
Hi, did you change the ribbon type at the printer properties? You must choose the black ribbon or monochrome in old drivers.
Posted on Aug 07, 2008
  • 54 Answers
SOURCE: My Evolis Pebble 3 says feeder error but there is
You must take following approach
1. There is a lever at feeder for thickness adjustment . Check it for proper thickness.
2. There is a hanging lever which acts as a card presence detector just where you place cards check if it is stuck and try to clean sensors aside it by blowing air .
3.Check if feeder motor is working by giving Mf;+ command
4.Check for proper ribbon setting.
5. Try downloading firmware which is available as an exe file for different models on Evolis site.
6. diagnostic software is also available on site.
7. You can also do self adjustment to adjust sensors.
Posted on Aug 29, 2009
SOURCE: have a Pebble 4 card printer and the ribbon breaks after each card is printed.
the card are not being fed when printing a test card...
Posted on Dec 11, 2009
Hi I got Evolis Pebble 4 and I have problem with printing the ribbon light is always ON and it does not print with YMCKO, but when I change to black ribbon K it prints. What is the problem.
It sounds like your ribbon setting in the printer-driver is set to the R2011 (or R2211) K ribbon. It should be set to R3011 for the full-color YMCKO ribbon. Check by locating the printer in the Windows Devices & Printers view (Win7: Start Button => Devices and Printers; WinXP: Start Button => Printers and Faxes). Locate your Pebble printer; right-click; select "Printing Preferences". Check your ribbon setting here and match to the ribbon that is loaded. NOTE that you can only make changes to this driver setting if you have Windows Admin rights with your Windows log-in ID. If you don't, have your systems administrator assist you with this by logging in with their ID.
May 04, 2015 | Evolis PEBBLE 4 Led Card Printer
Evolis pebble 4 shows the end of ribbon light...
Not card, not ribbon, not cleaning, not driver setting.
Does your black ribbon roll and never stops?
Sep 10, 2012 | Evolis PEBBLE 4 Led Card Printer
Fault light showing hand is lit - what does this mean please ? Evolis Pebble 3 ID card printer
It means you need to insert a cleaning card for cleaning cycle of printer.
Open printer properties Click on Tools tab click on Printer self cleaning button. You will get a new dialog box asking to remove ribbon and cards and insert a cleaning card in feeder.
Insert a cleaning card in feeder . Adjust thickness pointer to maximum remove ribbon and just cleck to proceed for cleaning.
Mar 31, 2011 | Evolis Pebble 3 ID Card Printer Package...
Card are stuck in evolis perbelle 4 so we get it by hand and then we have mechanical issues
First check for your card's thickness and adjust thickness lever accordingly.
Take a soft cotton cloth soaked with Isopropyl Alcohol with minimum water content.
Clean all Rollers including one roller below the feeder.
For cleaning Rollers you can take out ribbon and press the push button on front panel.
This will move Rollers and you will be able to clean rollers easily.
Clean the rollers below ultraviolet ribbon sensor and the roller set at output hopper also.
Feb 02, 2011 | Evolis PEBBLE 4 Led Card Printer
At the moment blank cards are not feed into the printer. The cards are always been jammed and the 3 lights are displaying a MechanicalProblem. I would be extremely happy if you can advise me on how...
You may try cleaning all Rollers including feeder roller.
To move rollers just remove ribbon , feeder and press front panel button and keep it pressed with top cover open . All Rollers will start moving and you can clean them easily using cleaning kit.
Also check for thickness adjustment pointer.
Oct 12, 2010 | Evolis Pebble 3 ID Card Printer Package...
My Evolis Pebble 3 ink ribbon breaks after I print 2 cards.
First clean Rollers and print head . Check if you have increased luminosity and contrast too much in printer Graphic properties. If this doesn't solves your problem increase x offset little bit using Px;+ command in Dialog with printer
Aug 04, 2010 | Evolis Pebble Color Card Printer
My ink ribbon breaks after it prints 2 cards. I have an Evolis Pebble 3.
Clean all transport rollers . check for X offset by giving Rx command in Properties/Tools/dialoge with printers. Increase offset little bit using Px command
My Evolis Pebble 3 says feeder error but there is not. It won't pick up a card when you try to print but when you press the push button it feeds out a card without printing. It will alos not print a test...
Aug 16, 2009 | Evolis Pebble 3 ID Card Printer Package...
Evolis Pebble 3 printer: the varnish is being put on as black
Check if ribbon type is proper.
Do self adjustment at once.
Clean optical sensors emitting blue light just below you install ribbon in printer
Jun 28, 2009 | Evolis Pebble 3 ID Card Printer Package...
Evolis Peb3le
Check settings for ribbon in driver . Whether it is correct or not.
Clean the ribbon sensor panel with Iso propyl alcohol and brush.
Panel is just situated below ribbon . You will find blue coloured LED type thing it is sensor only.
Try self adjustment using command Sa;c , Sa;r and Sa;h from Dialog with printer window..
Jul 08, 2008 | Evolis Pebble Color Card Printer
Evolis Pebble Color Card Printer Logo
214 people viewed this question
Top Evolis Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Evolis Office Equipment and Supply Expert? Answer questions, earn points and help others
