Question about Philips 60P8342 60" Rear Projection Television
Convergence module Hi, I need some sort of help with replacing a convergence module in a Panasonic pt-53tw53g and where I can purchase the part. If anyone can help me with a guide on where to find it and a step by step on how to do it... I would greatly appreciate it. Thanks!
To start on how to dissasemble the whole thing I went to
www.techghetto.com but this was for my philips 60 inch TV, the process is the same, you need to open the back of tv then start numbering all the cables it was for me about 22 cables & then remove the chassis out, then you will see two stk's 392-120??? or depending for your model may be different these are 2 black modules, also when they burn out usually 2 resistors will burn as well you need to check their resistance with a multimeter. It's easy you can get a multimeter at a near Electronic components store I found it on the yellow pages for my city the stk modules are $8.50 & the resistors are .25 cents each I spent about $35 dlls for the whole thing cause I had the mulitmeter & solder & the ironing solder You can buy everything at www.intertexelectronics.com try to buy everything you need online only one time cause they charge around $7.90 dlls for shipping so take advantege on ordering all together I made the mistake I ordered the stk's modules & not the resistors but I found them like I said in a local Electronics components store.
P.S. the stk's are more expensive at Ebay, good luck abamendez@aol.com
Posted on Dec 13, 2007
Convergence problem Panasonic PT-53TW53G
First I know this set well, did you pull out the board or the light box to replace the chips?
Convergence problems are usually easy to see...
see attached photos and tell me as much as possible.
SD TECH
Nov 10, 2011 | Panasonic PT-53TW53 53" Rear Projection...
I have a Panasonic Projection HDTV that i recently adopted. When i took it home I found a blue "bowing" at the bottom of the video. The experts i spoke to said i need to replace the convergence chips and...
The 2 STK convergence ICS are dead,all the resistors too,if it is smoking and glowing.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it again.Find the correct tv make and model.The convergence kit buy from one of these website's will have all the parts to repair it right this time.
Jul 16, 2010 | Panasonic PT-53TW53 53" Rear Projection...
How do you replace the convergence ICs on a pt-53tw53g
Look in the tips section here; I have posted complete instructions for do it yourself panasonic convergence repair or let me know and I will post them here for you.
SD TECH
Jan 22, 2010 | Panasonic PT-53TW53 53" Rear Projection...
I have a Panasonic PT-53TW53G that stopped working. Red LED light blinks 3 times. Any advice?
the 3 blink error means the convergence has failed and has shut the set down. You can get the convergence repair kit for your model at the following link www.tvrepairworld.com The kit contains the parts and the Cd with detailed instructions
Sep 12, 2009 | Panasonic PT-53TW53 53" Rear Projection...
My panasonic TV Model: pt 53tw53g turns off by it self
My Panasonic has exactly the same problem. The repair man just came in and said that the convergence and resistor burned under heat and have to be replaced. Will cost $400.
May 13, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53G 1 Blinking red light, will not stay on.
just got back today for same problem. convergence went out. took to repair shop. $200 part plus $60 labor. second time in a year convergence went out. was told it will happen again.
Mar 19, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Double image the second showing in red PT 53TW53G
replace the convergence ic's or look for loose connections that should do the job
Dec 16, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Tv trouble
djbone30, you need two STK392-110 convergence amplifiers.
Sep 25, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Philips 60P8342 60" Rear Projection Television Logo
162 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
