Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
Newish mixer just stopped while mixing...no motor smell or strange sounds...
Kitchen aid heavy duty.k5ss. While mixing on this 4 yr old mixer it stopped all motion. No motor smell or strange sound noted. Does this sound like a gear problem? I am handy fixing things. Is this a repair for a non pro? Or once I open it up will the problem be obvious? Any help would be appreciated.
  • mvextramail Feb 12, 2009
    I have a similar issue, we were making pizza dough, the paddle stopped, and the mixer began to click. The my motor seems fine. It can still change speeds accurately, the mechanism engages (but it makes a clicking noise), and it disengages with the slightest resistance. Is this the worm gear?
    Vincent
    Scholar:
  • 58 Answers
I think this link will help you understand what is needed to fix your mixer.
You will need to purchase a gear. Here is link MarBeck should have it.
You may need to replace some grease. Make sure to use a non-toxic food grade grease.
Posted on Feb 02, 2008
How can I adjust bowl depth?
KitchenAid K5SS Heavy Duty Commercial Stand Mixer ...
www.fixya.com/...kitchenaid...k5ss_heavy_duty/adjust_beater_height
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust beater height related issues. Get free ... Beater hits bowl beater height adjustment screw does not fix problem ... beater ... ...adjust beater depth-it is scraping the bottom of the bowl.
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Adjust
www.fixya.com/search/p105880-kitchenaid...k5ss_heavy_duty/adjust
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust related issues. Get free help ... How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen ... How do I adjust the depth of the dough hook. how do I adjust ...
How To Adjust the Bowl Height of Your Stand Mixer ' The ...
www.thekitchn.com/how-to-adjust-the-...
Apartment Therapy's The KitchnFeb 10, 2011 - In the world of stand mixers, there's two different types. ... It's easier than you think and will make your appliance last longer and food taste better! ... If yourbowl height is too high, you'll hear the adjustment needing to be made before you ... I have a different issue with my KitchenAid Artisan mixer (tilt head).
Dec 25, 2015 | KitchenAid K5SS Heavy Duty Commercial...
My kitchen aid K5SS won't run
first check the motor brush and replace them with a new pair. if you never do that check youtube and see a video how to do it.
Dec 05, 2012 | KitchenAid K5SS Heavy Duty Commercial...
Kitchen Aid Manual for RRK90 mixer I need one
http://forum.kitchenaid.com/forums/pdfs/u_c_classic4.5_5qtmodels.pdf
old model k5ss
http://downloads.mendingshed.com/KitchenAid_Service_Manual.pdf
Mar 16, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid Heavy Duty 325 stand mixer. Making cookies and now the motor runs but it doesn't turn to mix. PLease help/.
kITCHEN AID ARTISAN 325 WATTS TILTING HEAD PIN CAME OF WHILE MIXING DOUGH. HOW IS THE EASIEST WAY TO INERT PIN BACK OR LINE UP THE HOLES TO INSERT PIN?.
FRANKAMOR
Feb 06, 2010 | KitchenAid KSM5PS Heavy Duty Stand Mixer
My Kitchenaid mixer (k5ss lift bowl?) smells hot
I think you have a K45SS. It sounds like there is a problem with one of the gears, probably the worm gear. The worm gear is designed to be the first to fail if the mixer has struggled with a heavy dough or other difficult to mix substance. The best way to establish the cause will be to open the head up and check the gears for signs of damage.
Jan 25, 2010 | KitchenAid K5SS Heavy Duty Commercial...
I have disassembled my K5SS Kitchen Aid mixe with all gears removed in order to solve its electrical problem. When I plug in the motor and move the speed lever, there is no movement or sound of the motor...
Unless it sits at the back of the motor behind the vent cover. I couldn't find one anywhere on ours either. Check the motor brushes for broken or badly worn carbons, or collapsed springs. It could be a broken wire at the plug end or something wrong with the speed switch. Some strategic voltmeter sleuthing is required. Try turning the motor shaft while the power is on. It may have a dead commutator segment.
Aug 25, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Kitchen Aid Mixer has a sound but it doesn't have power to mix
Hi. Goto www.mendingshed.com and download the free Kitchenaid Service Manual.
You may have overloaded the mixer with bread or cookie dough, causing internal damage to the gears.
If you plan to do the repair yourself, you might also consider removing the old grease and oil. Remove, clean and regrease the planetary gear assembly as well. This will add years of life to your mixer.
Regrease with Chevron FM ALC EP-2 product.
If this solution has assisted you, please rate it. Good luck! ricardok45
Jan 27, 2009 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
365 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
