Question about Samsung SCX 4200 All-In-One Laser Printer
Fails to recognise cassete - Samsung SCX 4200 All-In-One Laser Printer
Hello! the problem is that the cassete holder failed to switch to "compact cassete mode", and it is blocking.
vhc-c adapters? is that what you mean, is the battery that brings the tape out of the shell dead (aa)
retracting the tape means that the vcr does not recognise one of 4 safety states and rejects the tape to avoid damage
Apr 11, 2016 | Televison & Video
Vcr/tv how to get the carriage unstuck
It sounds as if the drive belt or wheel that controls the carriage has perished and failed. There is normally a micro switch on the side or rear of the tray, that senses the presents of a casset. If it is closed with stikky tape or clay you may be able to simulate a casset in the machine and with manual force help the casset to open or close. alternatively a small lamp in the centre of the tray senses the tape. then you have to cover the lamp or two sensors on left and right side of the tray, to prevent detection of the broken or missing tape.
Nov 15, 2015 | Televison & Video
How to change A4 display to LTR display
Go to Printers and Faxes, right click on the printer icon and select Printer Properties.
then select the paper type as LTR.
If in case you do not get the option, re-install the printer drivers.
Sep 08, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
Supply rec. paper cassete thats all it said
assure the replace of paper cassete.
if still like that.
remove the paper cassete
find the sensor cassete in side
and you clean up.
May 10, 2011 | Canon ImageClass D880 Copier
Cassete not getting inserted.[message comes as remove cassete]
Does this happen with all cassets???
If So then....
1. try using a head cleaner casset.
2. connect the cam to your p.c. and check it for viruses.
Nov 06, 2010 | Canon ZR85 Mini DV Digital Camcorder
Code forget for car casset grundig wkc 3904 i cant turne on the casset because of rong code what i can do ?
Hiya try 1993.
If that fails, email Grundig, there web is www.grundig.com with the serial number of the unit. Anywhere else you will probably pay!
Good luck
Jul 10, 2009 | Car Audio & Video
REINSERT THE CASSEETE
Me also getting the same problem.. but some times it is getting okk...  what i m doing is, put the casset while pushing the cassete hold little bit down.. i think it is due to the improper position of the cassete holder...
Jul 20, 2008 | Sony Handycam DCR-HC28 Mini DV Digital...
Canon ZR60 Mini DV Digital, remove the cassete message
This is a tape transport problem and is expensive to fix. Unless you know a cheap tech, it's time for a new one. Be patient loading and unloading tapes. This is usually what causes this problem. The Yellow warning sticker is REALLY important. Another important item is to always use the same brand of tape because switching tapes causes a gummy build-up the makes tapes get caught in the machine.
Videoteacher
Dec 08, 2007 | Canon ZR60 Mini DV Digital Camcorder
DHR- 1000
Recently repaired one of these with what appeared to be a power supply problem; found several defective capacitors on the drive board. The symptoms were similar to what you are seeing.
Aug 20, 2007 | Sony DHR-1000 DVHS VCR
Samsung SCX 4200 All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
