Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
AIR FILTER DIRECTION OF PADS - Kenmore 25512/ 25513 Progressive Canister Vacuum
  • 430 Answers
Normally white side in. If you have foam and felt foam first closest to bag, then felt
Posted on Sep 08, 2009
Testimonial: "Thank you for your help"
Filter in the ball keeps popping out even though it is clipped in place.
Air filter is not getting air flow.air must pass thru filter or it will pop off.I placed filter against exhaust end of shop-vac ( NOT SUCTION END) untill I got air coming out.
Mar 12, 2015 | Filter Vacuums
I cleaned the filters on my dc 25, after cleaning it started to make a whistle noise. Opened the ball will running and touched the filter and noise stopped. Do I need to replace filter or rubber gasket...
You are hearing the air whistling past the gasket. Touching it may make it come and go. It is a small air leak bypassing the filter. It is more of a nuisance than anything. A bit of fine dust may be getting past the filter too so It's best to try to adjust it so it does not make the noise. If your filter was still wet or is clogged it will cause a restriction which makes it more likely for the air to try to get past the filter because it is having a hard time going through the filter.
Sep 01, 2013 | Dyson DC25 All Floors Bagless Upright...
Dust goes to filter
is the canister sealing properly? The air enters the canister under high pressure and it should slow down greatly in there so the heavier (dust) particles will fall to the bottom of the canister and the air should then pass through the filter under a reduced pressure. If the air is easily escaping the canister area without slowing down the dust cannot settle. It should look like a cyclone in the canister, if it's not swirling in one direction but rather bouncing around, look at the inlet to the canister for build up or an obstruction also. If the canister is not sealing the the air will remain moving rapidly and carry the dust along with it. I would also check your filter for a tare along the seam.
Apr 03, 2013 | Dyson DC08 Cylinder Bagless Canister...
I have a bagless cyclonic vacuum but filter in cylinder is not spinning
The filter doesn't spin The air creates a vortex as it is drawn through to the motor and this action is what spins the dirt out of the air. It is the sudden change of direction that does the trick
Mar 24, 2013 | Vacuums
How to install the back hepa filter on canister vacuum cleaner. We are not sure which direction the air flows and therefore which way the arrows should point. Should the arrows point into the vacuum...
The arrows in this case should point out of the machine. not into the machine. This is because you want the black rubber seal to seal on the machine and force the air through the filter.
Good luck.
Mark
Nov 10, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Hoover steam cleaner I
E-mail me for the parts manual (firehead@rogers.com)then do the following.
Go to figure 3.1 and clean the filter if necessary. Goto figure 3.8 and make sure pate E is clear. Make sure the part isslides up against when inserted downward is clear. Go to figure 3.11.The slotted holes in the recovery tank lid must be clear. Finally therecovery tank lid must fit snugly and air tight. I hope this works
Feb 01, 2009 | Hoover F5835900 Upright Steam Vacuum
My vax rapide has lost suction unless you press down on the front.It worked fine the first few times I used it but now it leaves the carpet soaking!
I fixed mine by taking the spongey filter out and washing it through. Then, important step, dry it with a hairdryer and test the direction of air flow by putting the dryer up close to it and feeling if it comes out the bottom. For me, only one way worked, and I put it back that way into the head, and hey presto, full suction back again! Thank goodness.
Apr 14, 2008 | Vacuums
Nilfisk advance floor scrubber vacuum problem
CAN YOU HELP? I AM LOOKING FOR A SMALL FLOOR POLISHER AND SCRUBBER FOR MY OWN USE AT HOME. i SHOULD HAV TWO 5_6" SCRUBBER PADS AND FLOOR POLISHING PADS. THANK YOU AND GOD BLEES. NORSANRAIDERS@MSN.COM LOWTON , OK
Mar 12, 2008 | Vacuums
Step Switch replacement
Take off the cap on top, remove the 3 screws, then the top comes apart and you can get to the switch.
Feb 04, 2008 | Filter Queen Cheetah II Ash - MU305...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
113 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
