Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
My brother mfc 440cn sasys that there is a paper jam,thereis not. I have rebooted,. opened every panel, yet it claims the paper I remove days ago isstill there.
  • 49 Answers
Try turning off the printer.
Posted on Sep 08, 2009
My brother mfc 440cn had a paper jam & after i removed the paper "unable to print 50" & "unable to print 30" showed on the screen. i went to brother web site & went to the...
You have to open the printer and set it back into the ph carrier.
1) Remove Plastic wire covers from inside printers, and release plastic stay on lower edge, tilt cover to 90 Degrees 2) make a note of where each connector goes 3) release the Ribbon and 3 Multicolor cables, removing grounding screw, then remove scanner module by sliding it off the hinges at 90 degrees. 4) Remove Three Front Panel Screws, carefully leaver front panel upwards releasing front side clips.5) Remove front panel by disconnecting ribbon and wiring on both sides.6) Remove 6 Screws (2 on back, three at front and one middle right7) Carefully remove speaker cable (Red Connector) and lift up plastic casing, leaving printer uncovered.8) Re-Seat Encoder Strip.9) Re-assemble in reverse.
Nov 08, 2011 | Brother MFC-440CN InkJet Printer
I have a jam in my Brother MFC-440CN. I pulled out torn bits of paper four times. IT makes a horrible cranking sound when I try to start it up and still says "Paper Jam". Can I unscrew the...
You may unscrew the screws to look through it to look for remaining paper in the printer if the printer is disconnected from the wall outlet.
Paper Jams can be frustrating to repair.
Good luck on this.
Jan 01, 2011 | Brother MultiFunction Center MFC-440CN...
All new to this mfc 440cn, how do i get front
this printer is notorious for the paper drawer breaking so it won't easily open. If this happens, a good rough **** will usually work. When it won't, open the access panel in the rear. It is flat but looks like a papertowel tube is molded under it. remove that door (it is for clearing paper jams)
Then look inside there. On the floor. You will see a tab that bouces when you tug on the drawer. Lift that tab and the drawer will freely slide out. Let me know if u figure out a way to repair this problem!
Aug 19, 2009 | Brother MultiFunction Center MFC-440CN...
Paper jam message brother MFC-440CN
Generally theres still a small piece stuck somewhere. Remove the back where the paper feeds through and check there. Then open the top so you can see the ink head and check around there. That should do it. The printer sometimes wont remove the jam until you open that top lid.
Also try switching it on and off again just to be sure.
If it's still there, the only other way is ripping it apart to find that pesky bit of paper still stuck.
Mar 24, 2009 | Brother MultiFunction Center MFC-440CN...
Torn paper jam Brother mfc 440cn
I pull paper out to remove it too, no worries, who doesn't.
You may be able to open the back of the unit up and there are a few rollers there than can be manipulated. Make sure it's unplugged. Don't force too hard but a little push or pull wont hurt.
Try rolling all the rollers that are in reach to see if you find anything, and they may need to be cleaned a little (not with anything wet!) with your finger is fine...they collect paper dust. You can blow in any area to try and clear any other paper dust also.
Let me know if this helps.
Jan 26, 2009 | Brother MFC-440CN InkJet Printer
Brother 440cn error 51
Uninstall the printer.
Reboot.
Install printer and try to print a test page.
Nov 22, 2008 | Brother MFC-440CN InkJet Printer
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
64 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
