Question about Sewing Machines
The reverse on my Elna Air Electonic does not work. Is this an easy fix?
  • Sewing Machines Master
  • 1,388 Answers
Unplug machine....Remove the base and while pressing the reverse lever identify where the connecting rod attaches....add a little lubricant at the point of seizing. This may need several applications...possibly over several days in extreme cases. Causes are usually lint and oil forming a "glue" or mild corrosion.
Jiggle the stiff joint or collar manually to ease it more free and keep this routine going until it resolves..... If it is still sluggish, rubbing alcohol directed on the joint (sparingly) while jiggling may assist the disolving of any "clag" Sometimes it is never fully resolved and even if it seems to come good, if you do not keep it moving regularly into the future it will continue to be a problem.
Best Wishes Martyn
Bargain Box in Australia
Posted on Sep 08, 2009
Will not sew in reverse when reverse button pushed
my kenmore 385.17526 will not go in reverse when I push ...
www.shopyourway.com > Manage My Life > Questions
my kenmore 385.17526 will not go in reverse when I push the button ... Having asewing machine that doesn't reverse can be a bit disappointing, especially ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home_and_Garden/.../Sewing.../index.html
Sewing Machine Won't Sew in Reverse. My Elna 3007 became temperamental atsewing in reverse some years ago. On occasion, I will need to push the button ...
Bernina 1230 Reverse Button Fix ' Temecula Valley Sewing ...
https://tv-sewingcenter.com/bernina/bernina-1230-reverse-button-fix
Aug 30, 2010 - The reverse button of the 1230 had been pulled or popped out of ... All I had to do to fix the button was to hold the button in, and then push the cap forward. ... My 1120 Bernina reverse button will not work and the person who ...
Dec 28, 2015 | Sewing Machines
How do we fix reverse lever on Elna 3230 sewing machine?
This sounds like a job for a repair shop. More than likely the presser foot lever is broken internally. Newer model or not. I think a repair shop will be able to repair this easily.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Nov 29, 2014 | Elna Sewing Machines
Why doesn't my elna model 300375 work in reverse?
the reverse button or lever could be broken or stuck, it would be a good idea to have the machine checked to see why the reverse isn't working.
Apr 29, 2014 | Elna Sewing Machines
I have an Elna Elnita air electronic and cannot figure out how to backstitch. I have always owned Elna Su air electronics but this little machine I can't figure out the backstitch
Unless there is a specific button to do reverse stitching, you could try pressing the foot peddle 'backwards' .. in other words, press with your heel rather than your toe. Some foot peddles are configured this way.
Apr 09, 2014 | Elna Sewing Machines
Elna 600 manual
I'm not sure about your machine but I've used an Elna that had a leaver for stitch length and when you pushed the leaver up all the way it would activate reverse stitching.
Apr 22, 2013 | Elna Sewing Machines
My "new" elna type 722010 only sews in reverse.
What is the stitch length lever set to (4 in the diagram below)? these models have a lever that slides from positive to negative (ie) reverse, so you need to set it to the positive area, between 2 and 3 above zero. If you move it below zero then it sews that stitch length backwards.
If this machine is new to you, you might want to join the yahoo group called "Elna Heirlooms" there is lots of helpful members who share info on these old machines there.
Jul 15, 2011 | Elna Sewing Machines
Elna dealers my elna super is stuck in reverse. Nearest repair shop is 200 mi. They recently servised it. can a person with better than average mech skills fix it ?
I just had the same problem.
I had a look around inside the machine, without taking off too many covers. By taking off the bottom panel I was able to look up inside and see what the 'reverse' lever was doing . The lever appeared to be moving another part inside the machine, except it wasn't returning to its original position (so it was stuck in 'reverse'). I used a long stick to push it back, and sprayed some WD40 onto it and after that the lever was able to move the part back and forth, and hey presto the machine works forward and reverse again.
Hope this helps if anyone else has this problem
Jun 09, 2011 | Elna 2007 Mechanical Sewing Machine
I have an elna 1010. It seems to be stuck in reverse, and I can't get it to go forwards. Can you help me?
try spraying some wd-40 or silicon spray on the reverse button or lever & let it set for awhile & try to work it
Nov 23, 2010 | Elna 1010
My elna SU air electronic model 68 is not working I need to fix it. How can I find a repair expert.
I have a Elna air electronic No 69 I am having trouble with the tension . How can I fix this.
Jul 13, 2009 | Elna Sewing Machines
Sewing Machines Logo
69 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
