Question about Mitsubishi WS-65311 65" Rear Projection HDTV-Ready Television
Color goes to blurry green and purple... tap set... sometimes it goes back.... When shut off for a while... works fine... for less and less time...
  • qualitycanva Sep 07, 2009
    Thanks Telly Head But that may be a little over my head... Oh... it is purple and green double vision BTW...
    A TV repair guy said (on the phone) that he thought it was a conversion chip(s) Wanted $100 to come out...$140 to Fix plus $125 for parts...
    So.. I give you the first $100 For what? LOL
    HELP!! I lOVE this TV!! I don't want a flat screen yet!! Thanks...and GOd Bless...
  • 59 Answers
Sounds like there is a dry solder joint somewhere
look first on main pcb for bad connections.
Posted on Sep 07, 2009
I have a Sony KP-65XBR10W 65-inch HDTV - green flashes shut down
Most likely you have a Green CRT that is failing. Sony no longer stocks the CRT assemblies for most of the older Projection sets. Instead what is required is to send the Green CRT assembly back to Sony (minus the Delta Lens), so they can replace the Tube on the Optical Coupler. This is a major cost of about 400.00 to 500.00 for the CRT plus the the tear down and reassembly time. Then you need to do a major Convergence alignment because the other two CRTs are aligned to the Green CRT. Due to the cost and the fact that Sony will not be supporting the older sets much longer, I would not invest the money into it.
I hope this helps,
Skyassoc
Feb 09, 2010 | Televison & Video
Screen is distorted with purple and green kind
your crts have gone bad.remove the front
cover and tap on the kneck of the red and green crt.if you see a change.crts are defective.
Jul 29, 2009 | Televison & Video
Color Resolution
Sounds like a piture tube or internal video driver in your monitor. You probably lost the green channel. If the monitor is dated I would replace it.
Aug 31, 2008 | X2Gen MG19MY 19" LCD Monitor
KP51ws500 turns green and shuts itslelf off
There may be several causes but, one is that when any color gun is being over driven, the Sony shuts down the gun to protect it. Try this. Remove the front of the set by removing the two screws from each lower corner. Next remove the black panel held on by 5 or 6 screws. Now you should see a panel with 6 potentiometers on it. Turning the ones on the bottom row CCW reduces the drive. Turn the color down and if all the guns stay lit, SLOWLY turn them up until you get the color balance that you like.
May 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Sony 46" RPT color problems
Hello BlueKalel,
It looks like your green CRT is malfunctioning. You should try to see if the voltages are correct on the socket of the green CRT and check the high voltage on the green CRT using a high voltage probe. Use a schematic diagram to reference these voltages to.
I am positive that the problem is the green CRT or the circuitry leading to the green CRT. Please use caution when checking these voltages.
Thank you,
Shuttle83
Sep 29, 2007 | Sony KP-46WT500 46" Rear Projection...
HCL4715W Green Color intermittently projecting
It sounds like the common problem with this set. It is an intermittant picture tube, or there is a loose connection on the green drive board on the green picture tube. Try lightly tapping all around on the green drive board while the set is on and see if you have any change. BUT BE VERY CAREFUL! Lots of high voltage on the board. Also use a plastic or wooden device to do the tapping. If you do great, you know you need to resolder the connections on the board or clean the CRT socket on the green drive board. If there is no change, I would bet the green CRT is on its way out. But try tapping the green drive board all over as I said before, that is a very very common fault with these types of TV sets. Good Luck
Aug 16, 2007 | Samsung HCL4715W 47" Rear Projection...
Mitsubishi WS-65311 65" Rear Projection HDTV-Ready Television Logo
130 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
