Question about Epson Perfection 3170 Flatbed Scanner
Epson Perfection 3170 scanner will not turn on.
My Epson Perfection 3170 scanner will not turn on. It has worked great in the past, all the software is properly installed, and yes, I did check to see if it was plugged in. Is there something that might have burned out that would need to be replaced?
  • Epson Master
  • 1,879 Answers
Having the scanner repaired will cost more than a new one.
Posted on Sep 07, 2009
Is there a driver for my Epson Perfection 1200U scanner which is compatible with Windows 10?
Its working perfectly with Epson 2400U drivers.
  • Download and install the Perfection 2400U drivers from Epson USA, version 3.04A http://www.epson.com/cgi-bin/Store/s...rm=OSF_W_10-64
  • Connect and turn on your scanner
  • Run Device Manager
  • The Perfection 1200U will be shown under under Other Devices
  • Select Update Driver
  • Choose 'Browse my computer for driver software"
  • Choose 'Let me pick from a list of device drivers on my computer'
  • UNCHECK the 'Show compatible hardware'
  • Click on 'Epson' in the Manufacturer box, and the scroll down through model until you find "Epson Perfection 2400', and choose that, and press Next
  • Ignore the 'Update Driver warning - choose 'Yes'; to continue to install.
  • The Perfection 2400 will now be shown in Device Manager. Note that the Perfection 1200 will still be shown under Devices & Printers
  • Run Epson Scan and test the scanner. You may need to log out and log in again for program to work
Nov 03, 2016 | Epson Perfection 1200U USB Flatbed Scanner
My epson perfection scanner doesn't work since i upgraded my iMac to OSX.10.8
Make sure you have installed the scanner drivers bcos sometimes it only installs printer drivers. I suggest you install the scanner drivers again. Make sure the scanner is turned in first b4 computer.
Oct 03, 2017 | Epson Perfection V700 PHOTO Flatbed...
Suddenly doesn't warm up epson 3170 and windows says it is malfunctioning.
Sounds like the bar inside off the scanner isn't working properly, if thats the case then that means the scanner is bad and it would need to be replaced.
Only thing you can try would be to unplug the scanner for about 5 minutes and then plug it back in. Then turn it on and see if it can initialize properly. If it still cant then you know the scanner is bad for sure.
Jul 05, 2010 | Epson Perfection 3170 Flatbed Scanner
Software available with Perfection 3170 Scanner?
yes this option is inclussive with your epson scan program, learn to play with the different modes of the scanner ex: professional, home mode etc. usually these modes have these options.
Sep 08, 2009 | Epson Perfection 3170 Flatbed Scanner
Epson Scanner Perfection 3170 can I down load a
Go here
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=25021&prodoid=35836301
Aug 31, 2009 | Epson Perfection 3170 Flatbed Scanner
No light when scanner turns on; can bulb be replaced? where to buy?
Unfortunately the bulb on the scanner is not available on retail stores. Epson does not allow end users to take the scanner apart because they might not be able to put the scanner back in together because of the scanner's engineering design.
Please log on to support.epson.com. Click on help me find a service center to the right of the page to search for an epson certified servicer near to your area.
May 11, 2009 | Epson Perfection 3170 Flatbed Scanner
Can not start my scanner
Have you unlock the scan optic? Its usually located at the bottom of the scanner
Apr 27, 2009 | Epson Perfection 3170 Flatbed Scanner
Epson Perfection 3170 Flatbed Scanner Logo
457 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
